ValueError: too many values to unpack (expected 1), while solving 2D elasticity problem
I have the following dolfinx code, where I am trying to solve a 2D linear elasticity problem on a 2D plate with 2 materials
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace,
                         form, locate_dofs_geometrical)
from ufl import (TestFunction, TrialFunction,
                 dx, grad, inner)
from dolfinx.io import gmshio
rve_mesh, cell_tags, facet_tags = gmshio.read_from_msh("/mnt/c/Users/ABC/sfepy/simplerve.msh", MPI.COMM_WORLD,gdim=2)
ds = ufl.Measure("ds", domain=rve_mesh, subdomain_data=facet_tags)
dx = ufl.Measure("dx", domain=rve_mesh, subdomain_data=cell_tags)
from dolfinx.fem import VectorFunctionSpace
V = VectorFunctionSpace(rve_mesh, ("Lagrange", 1))
def clamped_boundary(x):
    return np.isclose(x[0], 0)
lam_values = [0.005,121]
mu_values = [0.007, 81.9]
mu  = Function(V)
lam = Function(V)
for cell_no in range(len(cell_tags.values)):
    subdomain_no = cell_tags.values[cell_no]
    subdomain_no = int(subdomain_no-1)
    mu.x.array[cell_no] = mu_values[subdomain_no]
    lam.x.array[cell_no] = lam_values[subdomain_no]
fdim = rve_mesh.topology.dim - 1
boundary_facets = mesh.locate_entities_boundary(rve_mesh, fdim, clamped_boundary)
u_D = np.array([0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
    return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma_matrix(u):
    return lam_values[0] * ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu_values[0]*epsilon(u)
def sigma_fiber(u):
    return lam_values[1] * ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu_values[1]*epsilon(u)
u = ufl.TrialFunction(V)
f = fem.Constant(rve_mesh, ScalarType((0, 0.01)))
T = fem.Constant(rve_mesh, ScalarType((0, 0)))
a = (ufl.inner(sigma_matrix(u), epsilon(v)) * ufl.dx(1) + ufl.inner(sigma_fiber(u), epsilon(v)) * ufl.dx(2))
L = (ufl.dot(f, v) * ufl.dx(1) + ufl.dot(f, v) * ufl.dx(2) + ufl.dot(T, v) * ds)
problem = fem.petsc.LinearProblem(a, L,[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
The 2nd to last line throws the error.
I am following the following tutorial
https://jorgensd.github.io/dolfinx-tutorial/chapter2/linearelasticity_code.html
You would need to make the problem reproducible for others, by:
  1. Using a mesh that is accessible for everyone
  2. Making sure that all import statements are included.
As a side note, I do not understand why you are creating two different sigmas
as you could just use mu and lam from
and have a single sigma.
Thank You for the side note
I have linked my mesh (a .msh file) below. Code has been edited in the post to import modules
GDrive link for .msh file
I tried running the again, and now I get a different error
Error: error code 73
[0] KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:1078
[0] KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:843
[0] KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:407
[0] PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/pc/interface/precon.c:990
[0] PCSetUp_ILU() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/pc/impls/factor/ilu/ilu.c:141
[0] MatILUFactorSymbolic() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/mat/interface/matrix.c:6697
[0] MatILUFactorSymbolic_SeqAIJ() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/mat/impls/aij/seq/aijfact.c:1675
[0] Object is in wrong state
[0] Matrix is missing diagonal entry 0
I looked it up and found this, where you have instructed to create a ‘submesh’
I wish to get the solution over the whole domain, which is divided into 2 subdomains. Is it required for me to create a submesh . (Since this step was not required in dolfin).
Unfortunately I am unable to figure out and implement your tip regarding the mu and lambda values. Since the sigma function depends on lambda and mu values, how will I pass the input which will indicate which value of mu/lambda to take, give that the mu.x.array has around 560 entries?
Also regarding the error with missing diagonal, I believe it is happening because I am not implementing the subdomains properly. I do not get any error if I use 1 equation with only ‘dx’, instead of using dx(1) and dx(2) as given in my code. Please refer to my message above
EDIT
I have redefined sigma to accept 2 inputs, one is u, the other being an integer which will either be one or two.
def sigma(u, v):
    return lam_values[v]* ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu_values[v]*epsilon(u)
f = fem.Constant(rve_mesh, ScalarType((0, 0)))
a = (ufl.inner(sigma(u, 0), epsilon(v))) * ufl.dx(1) + (ufl.inner(sigma(u, 1), epsilon(v))) * ufl.dx(2)
L = (ufl.dot(f, v)) * ufl.dx(1) + (ufl.dot(f, v)) * ufl.dx(2) + ufl.dot(T, v) * ds
If you instead of defining mu and lambda in V
And use W = FunctionSpace(mesh, DG,0), the relationship between the cell index and the degree of freedom is 1 to 1, and the relationship
is correct, as explained in:
https://jorgensd.github.io/dolfinx-tutorial/chapter3/em.html#meshing-a-complex-structure-with-subdomains
then any integral with lam or mu will have the correct value in the correct subdomain.
