Good morning, I’m trying to modify the code written by @bleyerj for the Von Mises elasto-plasticity example: Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation
considering a holed rectangular plate subjected to an incremental traction load, from 0 up to
1.15 \sigma_0. The load is applied on the top boundary.
Here I show my code:
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
# elastic parameters
E = Constant(70e3)
nu = Constant(0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
sig0 = Constant(250.) # yield strength
Et = E/100. # tangent modulus
H = E*Et/(E-Et) # hardening modulus
domain = Rectangle(Point(0.,0.), Point(1., 2.)) - Circle(Point(0., 0.), 0.2)
mesh = generate_mesh(domain, 50)
plot(mesh)
def bottom(x):
return np.isclose(x[1], 0)
def top(x):
return np.isclose(x[1], 2)
def left(x):
return np.isclose(x[0],0)
D = mesh.topology().dim()
print(D)
neumann_domain = MeshFunction("size_t", mesh, D-1)
neumann_domain.set_all(0)
CompiledSubDomain("near(x[1], side) && on_boundary", side=2.0, tol=10e-15).mark(neumann_domain, 1)
ds = Measure("ds", subdomain_data=neumann_domain)
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
bc = [DirichletBC(V.sub(1), 0, bottom), DirichletBC(V.sub(0), 0, left )]
q_lim = float(sig0*1.15)
loading = Expression("q*t", q=q_lim, t=0, degree=2)
def F_ext(v):
return loading*dot(n, v)*ds(1)
def eps(v):
e = sym(grad(v))
return as_tensor([[e[0, 0], e[0, 1], 0],
[e[0, 1], e[1, 1], 0],
[0, 0, 0]])
def sigma(eps_el):
return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
return as_tensor([[X[0], X[3], 0],
[X[3], X[1], 0],
[0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
sig_n = as_3D_tensor(old_sig)
sig_elas = sig_n + sigma(deps)
s = dev(sig_elas)
sig_eq = sqrt(3/2.*inner(s, s))
f_elas = sig_eq - sig0 - H*old_p
dp = ppos(f_elas)/(3*mu+H)
n_elas = s/sig_eq*ppos(f_elas)/f_elas
beta = 3*mu*dp/sig_eq
new_sig = sig_elas-beta*s
return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
beta, dp
def sigma_tang(e):
N_elas = as_3D_tensor(n_elas)
return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma_tang(eps(u_)))*dxm
res = -inner(eps(u_), as_3D_tensor(sig))*dxm + F_ext(u_)
dv = TrialFunction(V)
v_ = TestFunction(V)
a_proj = inner(dv, v_)*dxm
b_proj = inner(v, v_)*dxm
solver.factorize()
if u is None:
solver.solve_local_rhs(u)
return u
return
file_results = XDMFFile("plasticity_results.xdmf")
P0 = FunctionSpace(mesh, "DG", 0)
p_avg = Function(P0, name="Plastic strain")
Nitermax, tol = 200, 1e-8 # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr+1)[1:]**0.5
results = np.zeros((Nincr+1, 2))
for (i, t) in enumerate(load_steps):
loading.t = t
A, Res = assemble_system(a_Newton, res, bc)
nRes0 = Res.norm("l2")
nRes = nRes0
Du.interpolate(Constant((0, 0)))
print("Increment:", str(i+1))
niter = 0
while nRes/nRes0 > tol and niter < Nitermax:
solve(A, du.vector(), Res, "mumps")
Du.assign(Du+du)
deps = eps(Du)
sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
local_project(sig_, W, sig)
local_project(n_elas_, W, n_elas)
local_project(beta_, W0, beta)
nRes = Res.norm("l2")
print(" Residual:", nRes)
niter += 1
u.assign(u+Du)
p.assign(p+local_project(dp_, W0))
sig_old.assign(sig)
file_results.write(u, t)
p_avg.assign(project(p, P0))
file_results.write(p_avg, t)
I don’t know if the code is correct or not.
I get this result for the displacement correspondent to the maximum load:
Could you help me understand if the results are correct?
