Von mises plasticity displacement control problem
I am trying to convert the plasticity tutorial given in Elasto-plastic analysis of a 2D von Mises material — Numerical tours of continuum mechanics using FEniCS master documentation to displacement control loading on a square plate. I am able to get the solutions only when displacements are really small( Also when I introduce a crack, this gets worse). Can someone help me to write a better code?
from matplotlib import pyplot
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
# material parameters
E = Constant(180e3)
nu = Constant(0.28)
lmbda = Constant(89633)
mu = Constant(70300)
sig0 = Constant(443)  # yield strength
H = Constant(300)  # hardening modulus
mesh = UnitSquareMesh(200,200)
top = CompiledSubDomain("near(x[1], 1.0) && on_boundary")
bot = CompiledSubDomain("near(x[1], 0.0) && on_boundary")
deg_u = 2
deg_stress = 2
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
load = Expression("t", t = 0.0, degree=1)
bcbot= DirichletBC(V, Constant((0.0,0.0)), bot)
bctop = DirichletBC(V.sub(1), load, top)
bc_u = [bcbot,bctop]
boundaries.set_all(0)
top.mark(boundaries, 1)
ds = Measure("ds")(subdomain_data= boundaries)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
def eps(v):
    e = sym(grad(v))
    return as_tensor([[e[0, 0], e[0, 1], 0],
                      [e[0, 1], e[1, 1], 0],
                      [0, 0, 0]])
def sigma(eps_el):
    return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
    return as_tensor([[X[0], X[3], 0],
                      [X[3], X[1], 0],
                      [0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
    sig_n = as_3D_tensor(old_sig)
    sig_elas = sig_n + sigma(deps)
    s = dev(sig_elas)
    sig_eq = sqrt(3/2.*inner(s, s))
    f_elas = sig_eq - sig0 - H*old_p
    dp = ppos(f_elas)/(3*mu+H)
    n_elas = s/sig_eq*ppos(f_elas)/f_elas
    beta = 3*mu*dp/sig_eq
    new_sig = sig_elas-beta*s
    return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
           as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
           beta, dp
def sigma_tang(e):
    N_elas = as_3D_tensor(n_elas)
    return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
# Global problem and Newton-Raphson procedure
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma_tang(eps(u_)))*dxm
res = -inner(eps(u_), as_3D_tensor(sig))*dxm
    dv = TrialFunction(V)
    v_ = TestFunction(V)
    a_proj = inner(dv, v_)*dxm
    b_proj = inner(v, v_)*dxm
    solver.factorize()
    if u is None:
        solver.solve_local_rhs(u)
        return u
        return
u_r = 0.03
print("\n Loading: u_r ", float(u_r))
Nitermax, tol = 100, 1e-8  # parameters of the Newton-Raphson procedure
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr+1)[1:]**0.5
print("time step", Nincr)
for (i, t) in enumerate(load_steps):
    load.t = t*u_r
    A, Res = assemble_system(a_Newton, res, bc_u)
    nRes0 = Res.norm("l2")
    nRes = nRes0
    Du.interpolate(Constant((0, 0)))
    print("Increment:", str(i+1))
    niter = 0
    while nRes/nRes0 > tol and niter < Nitermax:
        solve(A, du.vector(), Res, "mumps")
        Du.assign(Du+du)
        deps = eps(Du)
        sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
        local_project(sig_, W, sig)
        local_project(n_elas_, W, n_elas)
        local_project(beta_, W0, beta)
        nRes = Res.norm("l2")
        print("    Residual:", nRes)
        for bc in bc_u:
            bc.homogenize()
        niter += 1
    u.assign(u+Du)
    p.assign(p+local_project(dp_, W0))
    sig_old.assign(sig)
is it just the problem of choosing the right time step and mesh, or am I making any serious mistake?
i am attaching the post-processing part below
Vs = FunctionSpace(mesh, "DG", 1)
PP = FunctionSpace(mesh, "DG", 0)
# VON MISES EQUIVALENT STRESS
sig_n1 = as_3D_tensor(sig)
s1 = dev(sig_n1)
sig_eq1 = local_project(sqrt(3/2.*inner(s1, s1)), Vs)
# plastic strain
ep_eq = local_project(sqrt(2/3)*p, PP)
did you find any answer?
