What is the "default" linear solver/preconditioner?
I am wondering what the default solvers are. When I check the default options I get:
info(LinearVariationalSolver.default_parameters(), True)
linear_variational_solver  |    type    value
linear_solver              |  string  default
preconditioner             |  string  default
I had the impression that it was PetSc, but I can’t find what the default means (some built-in solver)?
With the standard build with a PETSc backend: UMFPACK in serial and MUMPS in parallel.
