I’ve calculated the eigen functions of a certain operator, one of the calculated eigen functions is plotted below with the plot() function. What are the white marks in the region where the function is supposed to be very small?
It looks like numerical noise. Unfilled areas in matplotlib plots are typically indicative of NaN entries.
If you want help as @dokken has stated, please succinctly articulate the operator you’re attempting to discretise, and the methods you’ve employed to do so.
I suspect you’re either plotting one of the trivial eigenvectors corresponding to the DoFs set for BCs, or your system is ilposed.
