I am using gmsh to generate a 3D domain. The output from gmsh states that there are “no ill-shaped tets in the mesh.” However, when I import the mesh using df.io.gmshio.model_to_mesh, I find that the resulting dolfinx mesh has singular tetrahedra (whose 4 points lie in a 2D plane).
The behavior is somewhat non-deterministic. I find singular cells when I run mpiexec -n 2 python test_singular_cells.py and the same with 4 MPI processes, but I do not find singular cells when I run with 3 MPI processes.
Am I generating this mesh incorrectly, or am I perhaps converting it to a dolfinx mesh incorrectly? I don’t know what relevance it may or may not have, but note that I am having gmsh generate a mesh with boundary faces that match periodically. (See the use of “setPeriodic” in the code below.)
Thank you for any help!
# test_singular_cells.py
import dolfinx as df
mpi_comm = MPI.COMM_WORLD
root_rank = 0
this_rank = mpi_comm.rank
gdim = 3
dLengths = [1,1,1]
tgt_cell_size = .1
if this_rank == root_rank:
gmsh.model.add(f'rectangular_{gdim}D_mesh')
# Add geometry
Lx, Ly, Lz = dLengths
p1 = gmsh.model.occ.addPoint(0, 0, 0)
p2 = gmsh.model.occ.addPoint(Lx, 0, 0)
p3 = gmsh.model.occ.addPoint(0, Ly, 0)
p4 = gmsh.model.occ.addPoint(0, 0, Lz)
p5 = gmsh.model.occ.addPoint(Lx, Ly, 0)
p6 = gmsh.model.occ.addPoint(Lx, 0, Lz)
p7 = gmsh.model.occ.addPoint(0, Ly, Lz)
p8 = gmsh.model.occ.addPoint(Lx, Ly, Lz)
lx1 = gmsh.model.occ.addLine(p1, p2)
lx2 = gmsh.model.occ.addLine(p3, p5)
lx3 = gmsh.model.occ.addLine(p4, p6)
lx4 = gmsh.model.occ.addLine(p7, p8)
ly1 = gmsh.model.occ.addLine(p1,p3)
ly2 = gmsh.model.occ.addLine(p2,p5)
ly3 = gmsh.model.occ.addLine(p4,p7)
ly4 = gmsh.model.occ.addLine(p6,p8)
lz1 = gmsh.model.occ.addLine(p1,p4)
lz2 = gmsh.model.occ.addLine(p2,p6)
lz3 = gmsh.model.occ.addLine(p3,p7)
lz4 = gmsh.model.occ.addLine(p5,p8)
loop_xy1 = gmsh.model.occ.addCurveLoop([lx1, ly2, -lx2, -ly1]) # Surface orientation: inward
loop_xy2 = gmsh.model.occ.addCurveLoop([lx3, ly4, -lx4, -ly3]) # Surface orientation: outward
loop_yz1 = gmsh.model.occ.addCurveLoop([ly1, lz3, -ly3, -lz1]) # Surface orientation: inward
loop_yz2 = gmsh.model.occ.addCurveLoop([ly2, lz4, -ly4, -lz2]) # Surface orientation: outward
loop_zx1 = gmsh.model.occ.addCurveLoop([lz1, lx3, -lz2, -lx1]) # Surface orientation: inward
loop_zx2 = gmsh.model.occ.addCurveLoop([lz3, lx4, -lz4, -lx2]) # Surface orientation: outward
surf_xy1 = gmsh.model.occ.addPlaneSurface([loop_xy1])
surf_xy2 = gmsh.model.occ.addPlaneSurface([loop_xy2])
surf_yz1 = gmsh.model.occ.addPlaneSurface([loop_yz1])
surf_yz2 = gmsh.model.occ.addPlaneSurface([loop_yz2])
surf_zx1 = gmsh.model.occ.addPlaneSurface([loop_zx1])
surf_zx2 = gmsh.model.occ.addPlaneSurface([loop_zx2])
sloop = gmsh.model.occ.addSurfaceLoop([surf_xy1, surf_yz1, surf_zx1, surf_yz2, surf_zx2, surf_xy2])
gmsh.model.occ.addVolume([sloop])
# Synchronize, before gmsh.model.mesh is used
gmsh.model.occ.synchronize()
# Periodicize
gmsh.model.mesh.setPeriodic(2, [surf_yz2], [surf_yz1], [1,0,0,Lx, 0,1,0,0, 0,0,1,0, 0,0,0,1]) # Affine transformation: A*(vx;vy;vz;1)
gmsh.model.mesh.setPeriodic(2, [surf_zx2], [surf_zx1], [1,0,0,0, 0,1,0,Ly, 0,0,1,0, 0,0,0,1]) # Affine transformation: A*(vx;vy;vz;1)
gmsh.model.mesh.setPeriodic(2, [surf_xy2], [surf_xy1], [1,0,0,0, 0,1,0,0, 0,0,1,Lz, 0,0,0,1]) # Affine transformation: A*(vx;vy;vz;1)
# Now generate the mesh for the gmsh model
cells = gmsh.model.getEntities(gdim)
tagPhys = 1+np.arange(len(cells)) #gmsh starts count at 1 (not 0)
gmsh.model.addPhysicalGroup(gdim,tagPhys,name=f'Rectangular {gdim}D Domain') #needed by df.io.gmshio.model_to_mesh
meshsize_field = gmsh.model.mesh.field.add('MathEval')
gmsh.model.mesh.field.setString(meshsize_field, 'F', str(tgt_cell_size))
gmsh.model.mesh.field.setAsBackgroundMesh(meshsize_field)
#output: df_mesh, cell_tags, facet_tags
df_mesh, _, _ = df.io.gmshio.model_to_mesh(gmsh.model, mpi_comm, root_rank, gdim, \
partitioner = df.mesh.create_cell_partitioner(df.mesh.GhostMode.shared_facet))
gmsh.finalize()
assert(gdim==df_mesh.topology.dim)
for idim in range(gdim+1):
df_mesh.topology.create_entities(idim)
nV = df_mesh.topology.index_map(0).size_local
nC = df_mesh.topology.index_map(gdim).size_local
xcoor = df_mesh.geometry.x
df_mesh.topology.create_connectivity(gdim, 0)
for iC in range(nC):
v_of_c = df_mesh.topology.connectivity(gdim, 0).links(iC)
if np.linalg.matrix_rank(xcoor[v_of_c])<gdim:
print(f"PROCESS #{this_rank}: SINGULAR CELL: Vertices {v_of_c} of {nV} local vertices. Coordinates: {xcoor[v_of_c]}.")
