Why are there discontinuities in the dolfinx solution compared to the dolfin?
I was recently working to get a solenoid model working in dolfinx using the magnetostatic equations from the magnetostatics example of the FEniCs tutorial. I was able to get the example working in two dimensions, however adapting it to 3D has led to some issues. Although I am able to reproduce theoretical results for the B field in some examples (the Helmholtz Coil) I have noticed discontinuities in my solution for the vector potential (\vec{A}) that do not appear when I run similar code in dolfin.
To test this, I made a simple solenoid mesh using pygmsh and meshio and used the same mesh to solve for A_x in both dolfin and dolfinx. Comparing the results in paraview, the peak values are different (1.5e-7 vs 2.2e-7) and the dolfinx solution shows noticeable visual artifacts that are also visible clearly when I do a Plot Over Line in paraview. I have pasted two images below comparing the two solutions. I used the stable:current docker image for dolfin and the latest dolfinx docker image.
Here is the dolfin solution image:
And here is the dolfinx solution image:
Here is the MWE code for mesh generation, dolfin, and dolfinx solutions:
Mesh Generation:
from pygmsh.opencascade import Geometry
from pygmsh import generate_mesh
domain_radius = 20.0
length = 15.0
rect1_r = 2.0
rect2_r = .5
geom = Geometry()
rect1 = geom.add_box([-rect1_r/2,-rect1_r/2,-length/2], [rect1_r,rect1_r,length], char_length=0.2)
rect2 = geom.add_box([-rect2_r/2,-rect2_r/2,-length/2], [rect2_r,rect2_r,length], char_length=0.2)
solenoid = geom.boolean_difference([rect1], [rect2])
sphere = geom.add_ball([0,0,0], domain_radius, char_length = 4.0)
sphere_domain = geom.boolean_difference([sphere], [solenoid], delete_other=False)
geom.boolean_fragments([solenoid], [sphere_domain], delete_first = False, delete_other=False)
geom.add_raw_code("Physical Volume(1) = {{{}}};".format(solenoid.id)) # Torus 1
geom.add_raw_code("Physical Volume(2) = {{{}}};".format(sphere_domain.id))
geom.add_raw_code("Physical Surface(3) = {{{}}};".format("17")) # Sphere border
# Build the .geo file.
mesh = generate_mesh(geom, geo_filename="mesh.geo", )
# Mesh Conversion
tetra_cells    = None
tetra_data     = None
triangle_cells = None
triangle_data  = None
print(mesh.cell_data_dict["gmsh:physical"].keys())
for key in mesh.cell_data_dict["gmsh:physical"].keys():
    if key == "triangle":
        triangle_data = mesh.cell_data_dict["gmsh:physical"][key]
    elif key == "tetra":
        tetra_data = mesh.cell_data_dict["gmsh:physical"][key]
for cell in mesh.cells:
    if cell.type == "tetra":
        if tetra_cells is None:
            tetra_cells = cell.data
            tetra_cells = np.vstack([tetra_cells, cell.data])
    elif cell.type == "triangle":
        if triangle_cells is None:
            triangle_cells = cell.data
            triangle_cells = np.vstack([triangle_cells, cell.data])
tetra_mesh = meshio.Mesh(points=mesh.points,
                         cells={"tetra": tetra_cells},
                         cell_data={"name_to_read":[tetra_data]})
triangle_mesh =meshio.Mesh(points=mesh.points,
meshio.xdmf.write("tetra_mesh.xdmf", tetra_mesh)
meshio.xdmf.write("triangle_mesh.xdmf", triangle_mesh)
Dolfin solution:
import dolfin
r = 1    #Approx radius
J = 1    #Current density in A/m^2
mesh = Mesh()
with XDMFFile("tetra_mesh.xdmf") as infile:
    infile.read(mesh)
mvc_tetra = MeshValueCollection("size_t", mesh, 3)
    infile.read(mvc_tetra, "name_to_read")
markers = dolfin.cpp.mesh.MeshFunctionSizet(mesh, mvc_tetra)
mvc_triangle = MeshValueCollection("size_t", mesh, 2)
with XDMFFile("triangle_mesh.xdmf") as infile:
    infile.read(mvc_triangle, "name_to_read")
mf_triangle = dolfin.cpp.mesh.MeshFunctionSizet(mesh, mvc_triangle)
# Define function space and integration measure
V = FunctionSpace(mesh, "P", 1)
dx = Measure('dx', domain=mesh, subdomain_data=markers)
# Define Dirichlet boundary condition
bc = DirichletBC(V, Constant(0), mf_triangle, 3)
# define current densities as function of subdomains
class CurrentDensity_x(UserExpression):
        super().__init__(**kwargs)
        self.markers = markers
        if (self.markers[cell.index] == 1):
            values[0] = -x[1]/r*J
            values[0] = Constant(0.0)
mu = Constant(4*np.pi*10**-7)
# initialise current densities
Jx = CurrentDensity_x(markers, degree = 1)
# Define Variational Problem
Ax = TrialFunction(V)
vx = TestFunction(V)
# left hand sides of variational problems
ax = (1/mu)*dot(grad(Ax), grad(vx))*dx
# right hand sides of variational problems
Lx = Jx*vx*dx
# solve variational problems for magnetic Ax (in Vs/mm)
Ax = Function(V)
solve(ax == Lx, Ax, bc)
with XDMFFile(MPI.COMM_WORLD,"A_x_dolfin.xdmf") as outfile:
    outfile.write(mesh)
    outfile.write_checkpoint(Ax, 'Ax')
Dolfinx Solution:
from dolfinx import Mesh, geometry, Function, DirichletBC, Constant, solve, FunctionSpace, VectorFunctionSpace
from ufl import TrialFunction, TestFunction, dot, grad, dx, inner, Measure
r = 1    #Approx radius, coil
with XDMFFile(MPI.COMM_WORLD,"tetra_mesh.xdmf",'r') as infile:
    mesh = infile.read_mesh(dolfinx.cpp.mesh.GhostMode.none, name="Grid")
with XDMFFile(MPI.COMM_WORLD, "tetra_mesh.xdmf", "r") as xdmf_infile:
    mt = xdmf_infile.read_meshtags(mesh, name="Grid")
with XDMFFile(MPI.COMM_WORLD, "triangle_mesh.xdmf", "r") as xdmf_infile:
    mt_triangle = xdmf_infile.read_meshtags(mesh, name="Grid")
V = FunctionSpace(mesh, ("CG", 1))
outer_facets = mt_triangle.indices[mt_triangle.values == 3]
dofs_outer = dolfinx.fem.locate_dofs_topological(V, 1, outer_facets)
ubcOuter = Function(V)
ubcOuter.vector.set(0)
bc = DirichletBC(ubcOuter, dofs_outer)
# Define subdomain markers and integration measure
dx = Measure('dx', domain=mesh, subdomain_data=mt)
#Define Current Density and Mu0
J_x = -x[1]/r*J
mu = Constant(mesh, 4*np.pi*10**-7)
#Define Variational Problem
A_x = TrialFunction(V)
ax = (1 / mu)*inner(grad(A_x), grad(vx))*dx
Lx = inner(J_x ,vx)*dx(1)
#Solve Variational Problem
A_x = Function(V)
solve(ax == Lx, A_x, bc)
#Store solution
with XDMFFile(MPI.COMM_WORLD, "A_x_dolfinx.xdmf", "w") as file:
    file.write_mesh(mesh)
    file.write_function(A_x)
I have tried experimenting with different preconditioners and ksp types but have not seen any differences. I have also tried many different methods to assign J in dolfinx thinking that it might be an issue with the discontinuous nature of J and found the way shown above to be the shortest code-wise but other methods (vector.set_local(i,___), etc) all yielded the same result. These issues with A_x yield further issues when taking the curl later to calculate the magnetic field, yielding even more numerical discontinuities. Are numerical discontinuities a known issue in Dolfinx, and what steps can I take to mitigate this?
The issue is this line.
This should be
dofs_outer = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, outer_facets)
as the indices you are tagging is of the topological dimension -1 (i.e. facets).
Changing this gives the correct answer.
