Hello.
I am implementing a code for the 2D wave equation. I have a Mixed formulation:my function space is the product of space for the pressure (u1) and a vector space for the 2D velocity (u2).
The code seem to work, however if I try different function space combination, such as P1-RT1, P2-RT2 or P1_-BDM1 I get same results but scaled differently. For example, if I use P1-RT1 after 0.4 seconds my simulation gives me a minimum pressure of -0.256, while if I change Lmix to P2-RT2 I get the same pressure distribution but the minimum is -0.64.
Does anyone can explain me why? Shoud not get the same solution?
Here is my code:
import dolfin
from mpl_toolkits.mplot3d import Axes3D
from matplotlib import cm
from matplotlib.ticker import LinearLocator, FormatStrFormatter
from matplotlib import rc
# Constants
dt = 0.0005 # time step size
FT = 0.5 # final time
t = 0 # initialize time
# Mesh
N = 20
M = 20
mesh = RectangleMesh(Point(0,0), Point(1,1), N, M, "left")
# plot(mesh)
# Finite element spaces
P1 = FiniteElement("P-", triangle, 1, 0)
P2 = FiniteElement("P-", triangle, 2, 0)
P3 = FiniteElement("P-", triangle, 3, 0)
RT1 = FiniteElement("P-", triangle, 1, 1)
RT2 = FiniteElement("P-", triangle, 2, 1)
RT3 = FiniteElement("P-", triangle, 3, 1)
P1_ = FiniteElement("P", triangle, 1, 0)
P2_ = FiniteElement("P", triangle, 2, 0)
P3_ = FiniteElement("P", triangle, 3, 0)
BDM1 = FiniteElement("P", triangle, 1, 1)
BDM2 = FiniteElement("P", triangle, 2, 1)
BDM3 = FiniteElement("P", triangle, 3, 1)
# Define mixed Functional Space
Lmix = FunctionSpace(mesh, P1*RT1)
# Trial functions
u1, u2 = TrialFunctions(Lmix)
# Test functions
v1, v2 = TestFunctions(Lmix)
# Functions - previous step - boundary inputs
u_n = Function(Lmix) # previous step (respect to n+1)
u_b = Function(Lmix) # boundary inputs
u_s = Function(Lmix) # solution (to be updated at each time step in the iteration loop)
# Compute the solution at each time step
while(t < 0.4):
#1 Update "gaussian" boundary conditions in velocity on Omega left
u_D = Expression(("0", "pow(sin(pi*t), 2)*near(x[0],0)*(t<1)", "0"), degree = 2,t = t)
u_b = project(u_D, Lmix)
# Variational problem for harmonic bc
F = v1*u1*dx - v1*u_n.split()[0]*dx + dot(v2, u2)*dx - dot(v2, u_n.split()[1])*dx - dt*dot(grad(v1), u2)*dx + \
dt*dot(v2, grad(u_n.split()[0]))*dx - dt*v1*dot(u_b.split()[1], n)*ds
a, L = lhs(F), rhs(F)
solve(a == L, u_s)
# Assign solution to previous step vector
u_n.assign(u_s)
print(t)
# Plot u_1 (pressure)
p = plot(u_s.split()[0])
plt.colorbar(p)
# Update current time
verticesD = {}
for cell in cells(mesh):
local_to_global_map0 = Lmix.sub(0).dofmap().cell_dofs(cell.index())
index = 0
for vertex in vertices(cell):
verticesD[tuple(vertex.point().array()[0:2])] = local_to_global_map0[index]
index += 1
xx = np.linspace(0,1,M+1)
yy = np.linspace(0,1,N+1)
XX, YY = np.meshgrid(xx,yy)
vector = u_s.split()[0].vector()[:]
Z = np.zeros((N+1,M+1))
for i in range (0, N+1):
for j in range(0,M+1):
Z[j][i] = vector[verticesD.get((i*1/N, j*1/M), "none")]
fig = plt.figure()
ax = fig.gca(projection='3d')
c = ax.plot_surface(XX, YY, Z, cmap=cm.coolwarm,
linewidth=0, antialiased=False)
ax.view_init(60, 250)
fig.colorbar(c, shrink=0.5, aspect=5)
Moreover, in my code I implemented an external harmonic boundary input sin^2(pi*t) that act on the left boundary (x=0). Is there an intelligent way to implement such an input only on point, the origin for example? Because if I put in the code something like
u_D = Expression(("0", "pow(sin(pi*t), 2)*(near(x[0],0) && near(x[1],0))*(t<1)", "0"), degree = 2,t = t)
it does not work. I tried also PointSource function in the loop but I do not get proper results.
A, b = assemble_system(a, L)
# create a DirichletBC
delta = PointSource(Lmix, Point(0, 0), pow(sin(pi*t), 2))
delta.apply(b)
# Define solver (iterative)
solver = LUSolver(A,method='mumps')
solver.parameters['symmetric'] = True
solver.parameters['report'] = True
solver.parameters['verbose'] = True
solver.solve(u_s.vector(),b)
