3D linear elasticity code with fixed facets and tranction facets not converging
I made a simple setup with a rectangular box, one side has a zero displacement boundary condition within a circle, and the other side has a traction boundary condition that integrates to 1 N. The material parameters are E=1e4 and nu=0.2.
When I run the code, reducing the mesh size from 2 mm, dividing by 2^0.25, the displacement at the center of the traction circle, and the maximum principal stress seem to diverge instead of converging to a fixed value. A self-contained code with the loop computing these values, together with the mesh sizes, is shown below.
Why is this happening? I thought this only happens with a nodal loading, is it because the traction is a step function at the edge of the circle? Could this be fixed by having something like a cosine function going from 0 at the circle’s edge to 1 (or some other value to compensate so the total traction integrates to 1 N) at a smaller circle? How is this done in practice? The contact used in a corresponding setup was with a 1 mm thick and 4 mm diameter rubber pad. Is the zero displacement condition also causing this? How could that be fixed?
Thank you,
Alex
import time
from dolfinx import mesh, fem, io, default_scalar_type
import dolfinx.fem.petsc
r_loading = 2.0e-3
def in_sphere(x, point, r_range):
    return ((x[0]-point[0])**2 + (x[1]-point[1])**2 + (x[2]-point[2])**2) < r_range**2
def mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal):
    dim = domain.topology.dim
    fdim = dim - 1
    domain.topology.create_connectivity(fdim, dim)
    def left_facets(xq):
        return in_sphere(xq, facet_node, r_loading)
    def right_facets(xq):
        return in_sphere(xq, grasp_node, r_loading)
    facets_left  = mesh.locate_entities(domain, fdim, left_facets)
    facets_right = mesh.locate_entities(domain, fdim, right_facets)
    facet_indices = np.concatenate([facets_left, facets_right])
    facet_markers = np.concatenate([np.full_like(facets_left,  1, dtype=np.int32),
                                    np.full_like(facets_right, 2, dtype=np.int32)])
    # Sort by facet index
    sort_perm = np.argsort(facet_indices)
    facet_indices = facet_indices[sort_perm]
    facet_markers = facet_markers[sort_perm]
    mt = mesh.meshtags(domain, fdim, facet_indices, facet_markers)
    return mt
def elasticity_parameters(E=10.0e4, nu=0.20):
    """Lamé parameters from E, nu."""
    lambda_ = E * nu  / ((1.0 + nu) * (1.0 - 2.0 * nu))
    mu      = E * 0.5 /  (1.0 + nu)
    return lambda_, mu
    return ufl.sym(ufl.grad(u))
def sigma(u, lambda_, mu):
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2.0 * mu * epsilon(u)
def build_primal_problem(domain, facet_tags, lambda_, mu, node_normal,
                         p_traction=1.0/(np.pi*r_loading**2), body_force=(0.0, 0.0, 0.0)):
    fdim = dim - 1
    ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
    V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
    u = ufl.TrialFunction(V)
    f_vec = fem.Constant(domain, default_scalar_type(body_force))
    # Traction direction: push along +x (change sign if needed)
    T = fem.Constant(domain, -p_traction * default_scalar_type((node_normal[0], node_normal[1], node_normal[2])))
    a = ufl.inner(sigma(u, lambda_, mu), epsilon(v)) * ufl.dx
    L = ufl.dot(f_vec, v) * ufl.dx + ufl.dot(T, v) * ds(2)
    # Dirichlet BC on left jaw (tag 1)
    left_facets = facet_tags.find(1)
    left_dofs = fem.locate_dofs_topological(V, fdim, left_facets)
    u_D = np.array((0.0, 0.0, 0.0), dtype=default_scalar_type)
    bc_left = fem.dirichletbc(u_D, left_dofs, V)
    return V, a, L, [bc_left]
def principal_stress(domain, uh, lambda_, mu):
    #Compute principal stresses via invariants (analytical eigenvalue solution)
    sigma_uh = sigma(uh, lambda_, mu)
    q = ufl.tr(sigma_uh) / 3                            # mean stress (I1/3)
    B = sigma_uh - q * ufl.Identity(3)                  # deviatoric stress tensor
    j = ufl.tr(B * B) / 2                               # J2 = 1/2 tr(B^2)
    b = ufl.tr(B * B * B) / 3                           # J3 = 1/3 tr(B^3)
    p = 2 / ufl.sqrt(3) * ufl.sqrt(j + 1e-14)           # p = 2/sqrt(3)*sqrt(J2) (small eps**2 added)
    r = 4 * b / (p**3)                                  # r = 4 J3 / p^3
    r = ufl.max_value(ufl.min_value(r,+1-1e-7),-1+1e-7) # clamp r to [-1+eps, 1-eps] to avoid acos domain error
    phi = ufl.acos(r) / 3
    lambda2 = q + p * ufl.cos(phi)                      # largest principal stress (max)
    V_dg = fem.functionspace(domain, ("DG", 0))
    pmax_expr = fem.Expression(lambda2, V_dg.element.interpolation_points)
    pmax = fem.Function(V_dg, name="PrincipalStress")
    pmax.interpolate(pmax_expr)
    return pmax, V_dg
def array_dist_squared(x, p):
    return (x[:,0]-p[0])**2 + (x[:,1]-p[1])**2 + (x[:,2]-p[2])**2
def fea_solve(domain, facet_node, grasp_node, grasp_node_normal):
    #lambda_, mu = elasticity_parameters2(domain, grasp_node, 4.0e-3)
    lambda_, mu = elasticity_parameters()
    facet_tags  = mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal)
    Vp, a_p, L_p, bcs_p = build_primal_problem(domain, facet_tags, lambda_, mu, grasp_node_normal)
    problem = dolfinx.fem.petsc.LinearProblem(a_p, L_p, bcs=bcs_p,
                                              petsc_options_prefix="linear_problem",
                                              petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"})
    uh = problem.solve()
    # Principal stress field
    pmax, V_dg = principal_stress(domain, uh, lambda_, mu)
    # MPS maximum value not considering low E area
    dof_coords = V_dg.tabulate_dof_coordinates()
    indices    = np.where(np.logical_and(array_dist_squared(dof_coords, facet_node) > 5.0e-3**2, \
                                         array_dist_squared(dof_coords, grasp_node) > 5.0e-3**2))
    max_pmax   = np.sort(pmax.x.array[indices])[-1]
    # Get displacement at node where load is applied
    dof_coords = Vp.tabulate_dof_coordinates()
    distances  = np.linalg.norm(dof_coords - grasp_node, axis=1)
    dof_index  = np.argmin(distances)
    u_node     = np.sqrt(uh.x.array[3*dof_index]**2 + uh.x.array[3*dof_index+1]**2 + uh.x.array[3*dof_index+2]**2)
    return domain, uh, pmax, max_pmax, u_node
# Part FEA
length = 20.0e-3
width  = 10.0e-3
grasp_facet_node   = np.array([0.0,    width/2, width/2])
grasp_node2        = np.array([length, width/2, width/2])
grasp_node_normals = np.array([1.0,    0.0,     0.0    ])
cell_size = 2.0e-3
num_loops = 9
cell_sizes = np.empty((num_loops,1))
u_disps    = np.empty((num_loops,1))
stresses   = np.empty((num_loops,1))
for n in range(num_loops):
    n_l = int(length/cell_size)
    n_w = int(width/cell_size )
    domain = mesh.create_box(MPI.COMM_WORLD, ((0.0, 0.0, 0.0), (length,width,width)), (n_l,n_w,n_w), mesh.CellType.tetrahedron)
    t_start = time.perf_counter()
    domain_f, uh, pmax, max_stress, u_node = fea_solve(domain, grasp_facet_node, grasp_node2, grasp_node_normals)
    t_end   = time.perf_counter()
    print(f"FEA elapsed time: {t_end  - t_start:.6f} seconds")
    cell_sizes[n] = cell_size
    u_disps[n]    = u_node
    stresses[n]   = max_stress
    cell_size = cell_size/2.0**0.25
with io.XDMFFile(domain_f.comm, "max_p_stress_part.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain_f)
    uh.name   = "u"
    xdmf.write_function(uh)
    pmax.name = "PrincipalStress"
    xdmf.write_function(pmax)
print('\n')
print(cell_sizes)
print('\n')
print(u_disps)
print('\n')
print(stresses)
To me it looks like it is not done converging.
I.e. if you look at the stresses in paraview for each refinement, you get something like
import time
r_loading = 2.0e-3
    fdim = dim - 1
    return mt
    return lambda_, mu
    fdim = dim - 1
    return pmax, V_dg
                                         array_dist_squared(dof_coords, grasp_node) > 5.0e-3**2))[0]
    max_pressure = np.argmax(pmax.x.array[indices])
    print(dof_coords[indices[max_pressure]], pmax.x.array[indices[max_pressure]])
    return domain, uh, pmax, max_pmax, dof_coords[dof_index], u_node
# Part FEA
length = 20.0e-3
width  = 10.0e-3
cell_size = 2.0e-3
num_loops = 15
xdmf = io.XDMFFile(MPI.COMM_WORLD, "max_p_stress_part.xdmf", "w")
    domain_f, uh, pmax, max_stress, point, u_node = fea_solve(domain, grasp_facet_node, grasp_node2, grasp_node_normals)
    u_disps[n]    = u_node
    domain_f.name = f"Domain{n}"
    mesh_path = f'Xdmf/Domain/Grid[@Name="Domain{n}"]'
    uh.name   = "u"
    xdmf.write_function(uh,n, mesh_xpath=mesh_path)
    xdmf.write_function(pmax,n, mesh_xpath=mesh_path)
    print(n, point, u_node, max_stress)
print('\n')
print(cell_sizes)
print('\n')
print(u_disps)
print('\n')
print(stresses)
Step 10:
Step 11
Furthermore, by swiching to a hexahedral grid, you can see that it converges in a much nicer fashion:
Step 10:
Step 11:
Step 12:
It looks like it from that view, but the nodal displacement at the sides at the center where the load is applied keeps incrasing. I think it has to do with the load and fixed area having a step function.
The load and fixed area are supposed to represent rubber pads, maybe I can simulate that as a traction with a constant value but a smooth drop on the circle side like using a cosine. For the fixed side I could use an elastic bed bounday with the spring contstant also dropping off like the load. I think that will produce the equivent load on that side. How could I do an elastic bed bc in fenics? Is that like a Robin bc?
I checked both ends instead of the sides and the traction side is converging but very slowly, I think this is due to the step change in traction, and the fact that different facets are being added when the mesh is finer.
The zero displacement side shows lower stresses but it seems to be diverging (checking the % change from the max stress on that face). I think this is because this case is like a rigid punch being pushed on an elastic half-plane (Ch 2.5 in Handbook of Contact Mechanics: Exact Solutions of Axisymmetric Contact Problems | Springer Nature Link), which gives a normal pressure singularity at the edge of the circle.
One simple set of bcs could be: keeping the traction side the same but smoothing it at the edge of the circle with a cosine function (while making it add up to 1N). For the zero displacement side changing that to an elastic bed (Robin bc?), with E changing smoothly in the same way as the traction, such that it produces the same applied force, and fixing the nodes in the two orthogonal directions like for the traction side.
Do you have a reference for a Robin bc being used for elasticity in Fenics?
Hi, I tried running the exact same code and its not converging. Maybe there is something wrong with my fenics installation?
Could it be possible to run my code and see what the output is? When I check the output for iteration 11 in Paraview I get something like 9.3e4 for the max stress in the same view you showed. The number from you output is 3.6e3 and it looks like it converged. Mine doesn’t (see last array with the stresses). Here is the code output in my machine:
FEA elapsed time: 0.022660 seconds
FEA elapsed time: 0.023861 seconds
FEA elapsed time: 0.090254 seconds
FEA elapsed time: 0.204266 seconds
FEA elapsed time: 0.451327 seconds
FEA elapsed time: 0.905795 seconds
FEA elapsed time: 2.832070 seconds
FEA elapsed time: 6.305377 seconds
FEA elapsed time: 25.222612 seconds
FEA elapsed time: 56.110813 seconds
FEA elapsed time: 195.115314 seconds
[[0.002 ]
[0.00168179]
[0.00141421]
[0.00118921]
[0.001 ]
[0.0008409 ]
[0.00070711]
[0.0005946 ]
[0.0005 ]
[0.00042045]
[0.00035355]]
[[0.00144235]
[0.00145875]
[0.00755909]
[0.01369466]
[0.01771337]
[0.02434975]
[0.03383505]
[0.0467272 ]
[0.06021858]
[0.07392636]
[0.0972786 ]]
[[ 1841.58226109]
[ 2034.78366816]
[11929.89750367]
[12856.75539342]
[15471.79283942]
[26687.19345534]
[28523.12707249]
[42557.26616307]
[54022.69178219]
[69590.04903438]
[92535.84861181]]
Here is the code:
import time
r_loading = 2.0e-3
    fdim = dim - 1
    return mt
    return lambda_, mu
    fdim = dim - 1
    return pmax, V_dg
# Part FEA
length = 20.0e-3
width  = 10.0e-3
cell_size = 2.0e-3
num_loops = 11
    u_disps[n]    = u_node
    with io.XDMFFile(domain_f.comm, f"max_p_stress_part_iter_{n+1}.xdmf", "w") as xdmf:
        uh.name   = "u"
print('\n')
print(cell_sizes)
print('\n')
print(u_disps)
print('\n')
print(stresses)
A collaborator tried the same code and got the same stress array, it seems to be diverging (using fenics 0.10.0:
[[ 1841.58226109]
[ 2034.78366816]
[11929.89750367]
[12856.75539342]
[15471.79283942]
[26687.19345534]
[28523.12707249]
[42557.26616307]
[54022.69178219]
[69590.04903438]
[92535.84861181]]
What version of fenics are you using? Is there anything you changed in the code not shown in the code you posted?
I got the same numbers that converge with fenicsx v0.11, I installed it using the method using conda in the fenics website, but to change this line to add the fenicsx version:
conda install conda-forge fenics-dolfinx=0.11.0 …
Running your code with the additional line:
print(dolfinx.__version__, dolfinx.git_commit_hash) yields:
FEA elapsed time: 0.013041 seconds
FEA elapsed time: 0.009913 seconds
FEA elapsed time: 0.022576 seconds
FEA elapsed time: 0.033547 seconds
FEA elapsed time: 0.082800 seconds
FEA elapsed time: 0.129380 seconds
FEA elapsed time: 0.373714 seconds
FEA elapsed time: 0.700876 seconds
FEA elapsed time: 2.039325 seconds
FEA elapsed time: 4.543628 seconds
FEA elapsed time: 12.998073 seconds
0.11.0.post0 fefdb2201b80a8f59527de2d461b9056906661d8
[[0.002     ]
 [0.00168179]
 [0.00141421]
 [0.00118921]
 [0.001     ]
 [0.0008409 ]
 [0.00070711]
 [0.0005946 ]
 [0.0005    ]
 [0.00042045]
 [0.00035355]]
[[0.00145655]
 [0.00147336]
 [0.00089138]
 [0.00265791]
 [0.00206985]
 [0.00304512]
 [0.00301411]
 [0.00394732]
 [0.00352334]
 [0.00390616]
 [0.00401537]]
[[1841.58226109]
 [2034.78366816]
 [1075.04116855]
 [2240.10755091]
 [1554.49175714]
 [2822.55699444]
 [2325.71849015]
 [3492.19236626]
 [2919.02979709]
 [3469.49339551]
 [3544.64612005]]
code:
import time
r_loading = 2.0e-3
    fdim = dim - 1
    return mt
    return lambda_, mu
    fdim = dim - 1
    return pmax, V_dg
# Part FEA
length = 20.0e-3
width  = 10.0e-3
cell_size = 2.0e-3
num_loops = 11
    u_disps[n]    = u_node
        uh.name   = "u"
print('\n')
print(cell_sizes)
print('\n')
print(u_disps)
print('\n')
print(stresses)
Running on 0.10.0 yields the results that you are seeing:
FEA elapsed time: 0.706027 seconds
FEA elapsed time: 0.010824 seconds
FEA elapsed time: 0.023024 seconds
FEA elapsed time: 0.034646 seconds
FEA elapsed time: 0.084435 seconds
FEA elapsed time: 0.129224 seconds
FEA elapsed time: 0.367234 seconds
FEA elapsed time: 0.691599 seconds
FEA elapsed time: 2.003611 seconds
FEA elapsed time: 4.567333 seconds
FEA elapsed time: 13.119260 seconds
0.10.0 b8375fa9fb932cbfce43005eeb4a3d52293f428b
[[0.002     ]
 [0.00168179]
 [0.00141421]
 [0.00118921]
 [0.001     ]
 [0.0008409 ]
 [0.00070711]
 [0.0005946 ]
 [0.0005    ]
 [0.00042045]
 [0.00035355]]
[[0.00145655]
 [0.00147336]
 [0.00849693]
 [0.01369466]
 [0.01771337]
 [0.0261431 ]
 [0.03383505]
 [0.0467272 ]
 [0.06021858]
 [0.07440669]
 [0.0972786 ]]
[[ 1841.58226109]
 [ 2034.78366816]
 [11929.89750367]
 [12856.75539342]
 [15471.79283942]
 [26687.19345534]
 [28523.12707249]
 [42557.26616307]
 [54022.69178219]
 [69590.04903437]
 [92535.84861181]]
while 0.9 is back to what 0.10 had
FEA elapsed time: 0.170569 seconds
FEA elapsed time: 0.010710 seconds
FEA elapsed time: 0.022907 seconds
FEA elapsed time: 0.033624 seconds
FEA elapsed time: 0.083407 seconds
FEA elapsed time: 0.129651 seconds
FEA elapsed time: 0.367752 seconds
FEA elapsed time: 0.694417 seconds
FEA elapsed time: 2.005706 seconds
FEA elapsed time: 4.524475 seconds
FEA elapsed time: 13.015335 seconds
0.9.0 4116cca8cf91f1a7e877d38039519349b3e08620
[[0.002     ]
 [0.00168179]
 [0.00141421]
 [0.00118921]
 [0.001     ]
 [0.0008409 ]
 [0.00070711]
 [0.0005946 ]
 [0.0005    ]
 [0.00042045]
 [0.00035355]]
[[0.00145655]
 [0.00147336]
 [0.00089138]
 [0.00265791]
 [0.00206985]
 [0.00304512]
 [0.00301411]
 [0.00394732]
 [0.00352334]
 [0.00390616]
 [0.00401537]]
[[1841.58226109]
 [2034.78366816]
 [1075.04116855]
 [2240.10755091]
 [1554.49175714]
 [2822.55699444]
 [2325.71849015]
 [3492.19236626]
 [2919.02979709]
 [3469.49339551]
 [3544.64612005]]
which to me indicates that what you are seeing is this bug:
as the facets marked with 2 in your code includes interior nodes, i.e. the following would trigger:
 domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
    f_to_c = domain.topology.connectivity(domain.topology.dim-1, domain.topology.dim)
    for facet in facet_tags.find(2):
        cells = f_to_c.links(facet)
        assert len(cells) == 1, "Facet should be on the boundary"
this has been corrected in the 0.11 release.
