A problem of numerical anomaly during calculate
Hello! I am doing a simulation of a physic model through fenicsx. The model is about the electromagnetic field. I haven’t finished PML outside the domain I set, and I tried to run my semi-finished project. Some of PDEs are time dependent and it’s a mixed finite element problems. I calculate a integration of a variable I need to get on the domain. At first, the integration didn’t change for a few steps, after few steps of calculation, the value of a variable seem to tend to infinity(nan). I guess this is due to the insufficient boundary conditions I set and the I don’t finish PML yet. I have some problems from this:
1.Does the insufficient boundary conditions could cause a numerical anomaly when solve a matrix? How to judge the number of boundary conditions in a system?
2.Implicit iteration is better than explicit iteration, right?
So I want set
F_continuity = (
    ((n - n_n)/dt * v_n
    + ufl.div(n * velocity) * v_n) * ufl.dx
rather than
F_continuity = (
    ((n - n_n)/dt * v_n
    + ufl.div(n_n * velocity_n) * v_n) * ufl.dx
But
a_compiled = dolfinx.fem.form(a)
doesn’t accept this. Are there some solutions?
I tried to simplify my code, it doesn’t have a nan problem ,but still has the integration didn’t change.
import dolfinx.fem.petsc
import basix.ufl
from dolfinx import mesh, fem
numberofmesh = 2
domain = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, numberofmesh, numberofmesh, numberofmesh)
T_element = basix.ufl.element("Lagrange", "tetrahedron", 1)
E_element = basix.ufl.element("N1curl", "tetrahedron", 3)
Mix = basix.ufl.mixed_element([T_element, E_element])
W = dolfinx.fem.functionspace(domain, Mix)
(T, E) = ufl.TrialFunctions(W)
(v_T,  v_E) = ufl.TestFunctions(W)
t = dolfinx.fem.Constant(domain, 0.0)
dt = dolfinx.fem.Constant(domain, 1e-15)
w = dolfinx.fem.Function(W)
w_n = dolfinx.fem.Function(W)
T_n, E_n = w_n.split()
domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
boundary_dofs_T = dolfinx.fem.locate_dofs_topological(W.sub(0), domain.topology.dim - 1, boundary_facets)
bc_T = dolfinx.fem.dirichletbc(dolfinx.fem.Constant(domain, 300.0), boundary_dofs_T, W.sub(0))
bcs = [bc_T]
w_n.sub(0).interpolate(lambda x: np.full(x.shape[1], 300.0))  # 温度场
w_n.sub(1).interpolate(lambda x: np.zeros((3, x.shape[1])))  # 电场
def top_surface(x):
    return np.isclose(x[2], 1, atol=1)
marker_value=1
top_facets = mesh.locate_entities_boundary(domain, domain.topology.dim - 1, top_surface)
facet_tags = mesh.meshtags(domain, 2, top_facets, np.full(len(top_facets), marker_value, dtype=np.int32))
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
F_heat =  (
        ((T - T_n) / dt * v_T
         + ufl.div(T_n * E_n) * v_T) * ufl.dx
F_ampere =  (
        ufl.inner((E - E_n) / dt, v_E) * ufl.dx
        +  ufl.inner(ufl.grad(2 / 3 * T_n), v_E) * ufl.dx
        +  ufl.inner(E_n, v_E) * ufl.dx
F = F_heat +  F_ampere
a, L = ufl.system(F)
L_compiled = dolfinx.fem.form(L)
petsc_options = {
    "ksp_type": "preonly",
    "pc_type": "lu",
    "pc_factor_mat_solver_type": "mumps"
problem = dolfinx.fem.petsc.LinearProblem(a_compiled, L_compiled, u=w, bcs=bcs, petsc_options=petsc_options)
T_final = 1e-12
num = 0
while t.value < T_final:
    t.value += dt.value
    problem.solve()
    integrate = fem.assemble_scalar(fem.form(T * ufl.dx))
    print(integrate)
    w_n.x.array[:] = w.x.array
    num += 1
The whole code is this, it has a nan problem:
import basix.ufl
import scipy.sparse
import scipy.sparse.linalg
numberofmesh = 2
n_element = basix.ufl.element("Lagrange", "tetrahedron", 1)
v_element = basix.ufl.element("Lagrange", "tetrahedron", 3, shape=(3,))
H_element = basix.ufl.element("N1curl", "tetrahedron", 3)
Mix = basix.ufl.mixed_element([T_element, n_element, v_element, E_element, H_element])
(T, n, velocity, E, H) = ufl.TrialFunctions(W)
(v_T, v_n, v_v, v_E, v_H) = ufl.TestFunctions(W)
wh = dolfinx.fem.Function(W)
T_n, n_n, velocity_n, E_n, H_n = w_n.split()
D = 1.1e-4
nu = 1e15
epsilon_F = 5.5
m_e = 9.1e-31
e = 1.6e-19
omega_p = 1.4e16
epsilon_0 =  8.854e12
mu_0 = 4 * np.pi * 1e-7
c0 = 299792458.0
Q = dolfinx.fem.functionspace(domain, ("Lagrange", 1))
E_energy = dolfinx.fem.Function(Q, name="Electric_Energy")
H_energy = dolfinx.fem.Function(Q, name="Magnetic_Energy")
total_energy = dolfinx.fem.Function(Q, name="Total_Energy")
bc_value = np.array([0.0, 0.0, 0.0],dtype=float)
boundary_dofs_v = dolfinx.fem.locate_dofs_topological(W.sub(2).sub(0), domain.topology.dim - 1, boundary_facets)
bc_v = dolfinx.fem.dirichletbc(dolfinx.fem.Constant(domain, 0.0), boundary_dofs_v, W.sub(2).sub(0))
bcs = [bc_T, bc_v]
w_n.sub(1).interpolate(lambda x: np.full(x.shape[1], 8.8e22))
w_n.sub(2).interpolate(lambda x: np.zeros((3, x.shape[1])))
w_n.sub(3).interpolate(lambda x: np.zeros((3, x.shape[1])))
w_n.sub(4).interpolate(lambda x: np.zeros((3, x.shape[1])))
def laser_function(t):
    tau_p = 100e-15
    return np.exp(-(t - 2*tau_p)**2 / tau_p**2)
laser_source = dolfinx.fem.Constant(domain, 0.0)
t.value = 0
def top_surface(x):
    return np.isclose(x[2], 1, atol=1e-8)
marker_value=1
F_heat = (
    (T - T_n)/dt * v_T * ufl.dx
    + D * ufl.inner(ufl.grad(T), ufl.grad(v_T)) * ufl.dx
    - (nu * e**2 * 100 / (2 * m_e * omega_p**2)) * laser_source * v_T * ds(1)
F_momentum = (
    ufl.inner((velocity - velocity_n)/dt, v_v) * ufl.dx
    + (1/(m_e * n_n)) * ufl.inner(ufl.grad(2/3 * n_n * T_n), v_v) * ufl.dx
    + (e/m_e) * ufl.inner(E_n, v_v) * ufl.dx
    + nu * ufl.inner(velocity_n, v_v) * ufl.dx
F_continuity = (
    ((n - n_n)/dt * v_n
F_ampere = (
    ufl.inner(ufl.curl(H_n), v_E) * ufl.dx
    - epsilon_0 * ufl.inner((E - E_n)/dt, v_E) * ufl.dx
    + (4 * np.pi * e/c0) * n_n * ufl.inner(velocity_n, v_E) * ufl.dx
F_faraday = (
    ufl.inner(ufl.curl(E_n), v_H) * ufl.dx
    + mu_0 * ufl.inner((H - H_n)/dt, v_H) * ufl.dx
F = F_heat + F_momentum + F_continuity + F_ampere + F_faraday
T_final = 1e-12  # 1 ps
num = 0
    t.value += dt.value
    laser_source.value = laser_function(t.value)
    A = dolfinx.fem.create_matrix(a_compiled)
    b = dolfinx.fem.create_vector(L_compiled)
    A_scipy = A.to_scipy()
    dolfinx.fem.assemble_matrix(A, a_compiled, bcs=bcs)
    dolfinx.fem.assemble_vector(b.array, L_compiled)
    dolfinx.fem.apply_lifting(b.array, [a_compiled], [bcs])
    b.scatter_reverse(dolfinx.la.InsertMode.add)
    [bc.set(b.array) for bc in bcs]
    A_inv = scipy.sparse.linalg.splu(A_scipy)
    wh.x.array[:] = A_inv.solve(b.array)
    total_em_energy = fem.assemble_scalar(fem.form(T_n * ufl.dx))
    w_n.x.array[:] = wh.x.array
    num += 1
    print(f"Step {num} | Time: {t.value:.2e} s | Energy: {total_em_energy:.4e} J")
First of all, this should be replaced with:
T_n, E_n = ufl.split(w_n)
and
with
    t.value += dt.value
    problem.solve()
    integrate = fem.assemble_scalar(fem.form(w.sub(0) * ufl.dx))
    print(integrate)
    num += 1
For your second issue, please simplify your example and adjust it as done with the first one.
Thank you Prof. dokken.
I simplify the code behind.
It’s strange that integration doesn’t change.
import basix.ufl
import scipy.sparse
numberofmesh = 2
(v_T,v_E) = ufl.TestFunctions(W)
T_n , E_n = ufl.split(w_n)
bcs = [bc_T]
def top_surface(x):
marker_value=1
F_heat = (
    (T - T_n)/dt * v_T * ufl.dx + 10*T*v_T*ufl.dx
F_ampere = (
    ufl.inner(ufl.grad(T), v_E) * ufl.dx - ufl.inner((E - E_n)/dt, v_E) * ufl.dx
num = 0
petsc_options = {
    "pc_type": "lu",
problem = dolfinx.fem.petsc.LinearProblem(a_compiled, L_compiled, u=wh, bcs=bcs, petsc_options=petsc_options)
    t.value += dt.value
    problem.solve()
    total_em_energy = fem.assemble_scalar(fem.form(w_n.sub(0) * ufl.dx))
    num += 1
    print(f"Step {num} | Time: {t.value:.2e} s | integration of T in domain: {total_em_energy:.4e} ")
I guess this should be wh.sub(0).
You are solving for an incredibly small time interval. Imagine multiplying your PDE by st. Then you have
T=T_n + dt*f(T,T_n).
If f(T,T_n) is massive you will still not get a large average chance when multiplied by 1e-15, which is close to machine precision.
Absolutely a precise insight. I forget I remove the small parameters to simply the code. Then I will check my code again to see what causes integration resulting “nan”.
