Adding rows of Matrix
I want to add two rows of an assembled matrix, and reinsert the result in the original Matrix in place of the first of the added rows, and set the second row to the identity matrix, see the MWE below.
Unfortunately I get an error when trying to set the new values in the Matrix, see below, everything else seems to work.
Am I using the set() function from the Matrix class wrong, or is there another way to do this?
mesh = UnitSquareMesh(5,5)
V = VectorFunctionSpace(mesh, 'CG', 2)
A = assemble( inner(u, v) * dx )
row_block_0 = np.ndarray( ( 1, V.dim() ), dtype=np.float_)
row_block_1 = np.ndarray( ( 1, V.dim() ), dtype=np.float_)
A.get( row_block_0, [0], list(range(V.dim())) )
A.get( row_block_1, [1], list(range(V.dim())) )
A.set( row_block_0+row_block_1, [1], list(range(V.dim())) )
A.ident([1])
File “960_Test.py”, line 19, in
RuntimeError:
*** Error: Unable to successfully call PETSc function ‘MatSetValues’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /build/dolfin-ltzKbC/dolfin-2019.1.0/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
Have you tried using the petsc4py API as mentioned here? Something like
addMode = PETSc.InsertMode.ADD
identityRow = np.identity(V.dim())[1] #row to set to identity
print(A.array())  # original
Am = as_backend_type(A).mat()
Am.setOption(PETSc.Mat.Option.NEW_NONZERO_ALLOCATION_ERR, False)
# setting the first row to the sum of first two rows
Am.setValues([0], list(range(V.dim())), row_block_0 + row_block_1)
# setting the row-1 to identity: assuming this is what A.ident([1]) does
Am.setValues([1], list(range(V.dim())), identityRow)
Am.assemble()
print(A.array())  # modified
Thank You, @bhaveshshrimali, this works and solves this part of my problem.
However I would still like to know how the set() function for matrices is supposed to be used, so if someone knows I would appreciate an explanation.
