yaoyn
1
Hi all,
I tried to calculate the volume average but the results are different for the two methods.
assemble(sol[1]*dx)/assemble(Constant(1)*dx)
sol[1].vector().sum()/mesh.num_cells()
From what I understand, these two should yield the same results.
Thanks.
dokken
2
In your second average, you are using number of cells, where you should use the length of the vector you are summing over, i.e.
def average(N):
mesh = UnitIntervalMesh(N)
x = SpatialCoordinate(mesh)
u = project(x[0], V)
dx = Measure("dx", domain=mesh)
print(N, assemble(u*dx)/ assemble(Constant(1)*dx), u.vector().sum()/len(u.vector()))
for n in [3, 10, 20, 40, 80]:
average(n)
yielding:
3 0.5 0.5
10 0.5 0.5000000000000001
20 0.5000000000000001 0.5000000000000002
40 0.5000000000000001 0.5
80 0.5000000000000001 0.5000000000000001
