Block form fails with 1D mesh and HDG scheme
Hello everyone,
I am currently experiencing difficulties with form creation in an HDG scheme for compressible Euler equations when the mesh is one-dimensional with trace elements defined at the extremities. More specifically, there appears to be an issue during the block form creation. This error also manifests when I run the Poisson equation tutorial and replace the 3D mesh with a 1D mesh. Would anyone have advice to tell me what I’m missing?
Here is the code:
from dolfinx import fem, mesh
from dolfinx.cpp.mesh import cell_num_entities
def compute_cell_boundary_facets(msh):
    """Compute the integration entities for integrals around the
    boundaries of all cells in msh.
    Parameters:
        msh: The mesh.
    Returns:
        Facets to integrate over, identified by ``(cell, local facet
        index)`` pairs.
    tdim = msh.topology.dim
    fdim = tdim - 1
    n_f = cell_num_entities(msh.topology.cell_type, fdim)
    n_c = msh.topology.index_map(tdim).size_local
    return np.vstack((np.repeat(np.arange(n_c), n_f), np.tile(np.arange(n_f), n_c))).T.flatten()
# Number of elements
n = 8
# Create the mesh
comm = MPI.COMM_WORLD
rank = comm.rank
dtype = PETSc.ScalarType
#Not working
msh = mesh.create_unit_interval(comm, n)
#Working
# msh = mesh.create_unit_square(comm, n, n)
# msh = mesh.create_unit_cube(comm, n, n, n)
# We need to create a broken Lagrange space defined over the facets of the
# mesh. To do so, we require a sub-mesh of the all facets. We begin by
# creating a list of all of the facets in the mesh
fdim = tdim - 1
msh.topology.create_entities(fdim)
facet_imap = msh.topology.index_map(fdim)
num_facets = facet_imap.size_local + facet_imap.num_ghosts
facets = np.arange(num_facets, dtype=np.int32)
# Create the sub-mesh
# NOTE Despite all facets being present in the submesh, the entity map
# isn't necessarily the identity in parallel
facet_mesh, facet_mesh_to_mesh = mesh.create_submesh(msh, fdim, facets)[:2]
# Define function spaces
k = 0  # Polynomial order
V = fem.functionspace(msh, ("Discontinuous Lagrange", k))
Vbar = fem.functionspace(facet_mesh, ("Discontinuous Lagrange", k))
# Trial and test functions in mixed space
W = ufl.MixedFunctionSpace(V, Vbar)
u, ubar = ufl.TrialFunctions(W)
v, vbar = ufl.TestFunctions(W)
# Define integration measures
# Cell
dx_c = ufl.Measure("dx", domain=msh)
# Cell boundaries
# We need to define an integration measure to integrate around the
# boundary of each cell. The integration entities can be computed
# using the following convenience function.
cell_boundary_facets = compute_cell_boundary_facets(msh)
cell_boundaries = 1  # A tag
# Create the measure
ds_c = ufl.Measure("ds", subdomain_data=[(cell_boundaries, cell_boundary_facets)], domain=msh)
# Create a cell integral measure over the facet mesh
dx_f = ufl.Measure("dx", domain=facet_mesh)
# We write the mixed domain forms as integrals over msh. Hence, we must
# provide a map from facets in msh to cells in facet_mesh. This is the
# 'inverse' of facet_mesh_to_mesh, which we compute as follows:
mesh_to_facet_mesh = np.full(num_facets, -1)
mesh_to_facet_mesh[facet_mesh_to_mesh] = np.arange(len(facet_mesh_to_mesh))
entity_maps = {facet_mesh: mesh_to_facet_mesh}
# Define forms
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
gamma = 16.0 * k**2 / h  # Scaled penalty parameter
c = 1.0 + 0.1 * ufl.sin(ufl.pi * x[0])
a = (
    ufl.inner(c * ufl.grad(u), ufl.grad(v)) * dx_c
    - ufl.inner(c * (u - ubar), ufl.dot(ufl.grad(v), n)) * ds_c(cell_boundaries)
    - ufl.inner(ufl.dot(ufl.grad(u), n), c * (v - vbar)) * ds_c(cell_boundaries)
    + gamma * ufl.inner(c * (u - ubar), v - vbar) * ds_c(cell_boundaries)
# Define block structure
a_blocked = ufl.extract_blocks(a)
a_blocked_form = dolfinx.fem.form(a_blocked, entity_maps=entity_maps)
Which raises the error:
TypeError                                 Traceback (most recent call last)
File /nfs/home/bouteillerp/Téléchargements/demo_hdg(1).py:107
    105 # Define block structure
    106 a_blocked = ufl.extract_blocks(a)
--> 107 a_blocked_form = dolfinx.fem.form(a_blocked, entity_maps=entity_maps)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py:337, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
    334     else:
    335         return form
--> 337 return _create_form(form)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py:333, in form.<locals>._create_form(form)
    331         return _form(form)
    332 elif isinstance(form, collections.abc.Iterable):
--> 333     return list(map(lambda sub_form: _create_form(sub_form), form))
    334 else:
    335     return form
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py:333, in form.<locals>._create_form.<locals>.<lambda>(sub_form)
    334 else:
    335     return form
    334 else:
    335     return form
    334 else:
    335     return form
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py:331, in form.<locals>._create_form(form)
    329         return None
    330     else:
--> 331         return _form(form)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/forms.py:254, in form.<locals>._form(form)
    252 if mesh is None:
    253     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 254 ufcx_form, module, code = jit.ffcx_jit(
    255     mesh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
    256 )
    258 # For each argument in form extract its function space
    259 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/jit.py:62, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     58 @functools.wraps(local_jit)
     59 def mpi_jit(comm, *args, **kwargs):
     60     # Just call JIT compiler when running in serial
     61     if comm.size == 1:
---> 62         return local_jit(*args, **kwargs)
     64     # Default status (0 == ok, 1 == fail)
     65     status = 0
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/jit.py:212, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    210 # Switch on type and compile, returning cffi object
    211 if isinstance(ufl_object, ufl.Form):
--> 212     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    213 elif isinstance(ufl_object, ufl.Mesh):
    214     r = ffcx.codegeneration.jit.compile_coordinate_maps([ufl_object], options=p_ffcx, **p_jit)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:225, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    223     except Exception:
    224         pass
--> 225     raise e
    227 obj, module = _load_objects(cache_dir, module_name, form_names)
    228 return obj, module, (decl, impl)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:205, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    202     for name in form_names:
    203         decl += form_template.format(name=name)
--> 205     impl = _compile_objects(
    206         decl,
    207         forms,
    208         form_names,
    209         module_name,
    210         p,
    211         cache_dir,
    212         cffi_extra_compile_args,
    213         cffi_verbose,
    214         cffi_debug,
    215         cffi_libraries,
    216         visualise=visualise,
    217     )
    218 except Exception as e:
    219     try:
    220         # remove c file so that it will not timeout next time
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/codegeneration/jit.py:330, in _compile_objects(decl, ufl_objects, object_names, module_name, options, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    326 libraries = _libraries + cffi_libraries if cffi_libraries is not None else _libraries
    328 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    329 # unique across modules
--> 330 _, code_body = ffcx.compiler.compile_ufl_objects(
    331     ufl_objects, prefix=module_name, options=options, visualise=visualise
    332 )
    334 # Raise error immediately prior to compilation if no support for C99
    335 # _Complex. Doing this here allows FFCx to be used for complex codegen on
    336 # Windows.
    337 if sys.platform.startswith("win32"):
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/compiler.py:113, in compile_ufl_objects(ufl_objects, options, object_names, prefix, visualise)
    111 # Stage 2: intermediate representation
    112 cpu_time = time()
--> 113 ir = compute_ir(analysis, _object_names, _prefix, options, visualise)
    114 _print_timing(2, time() - cpu_time)
    116 # Stage 3: code generation
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/ir/representation.py:135, in compute_ir(analysis, object_names, prefix, options, visualise)
    129     for itg_index, itg_data in enumerate(fd.integral_data):
    130         integral_names[(fd_index, itg_index)] = naming.integral_name(
    131             fd.original_form, itg_data.integral_type, fd_index, itg_data.subdomain_id, prefix
    132         )
    134 irs = [
--> 135     _compute_integral_ir(
    136         fd,
    137         i,
    138         analysis.element_numbers,
    139         integral_names,
    140         finite_element_hashes,
    141         options,
    142         visualise,
    143     )
    144     for (i, fd) in enumerate(analysis.form_data)
    145 ]
    146 ir_integrals = list(itertools.chain(*irs))
    148 ir_forms = [
    149     _compute_form_ir(
    150         fd,
    159     for (i, fd) in enumerate(analysis.form_data)
    160 ]
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/ir/representation.py:396, in _compute_integral_ir(form_data, form_index, element_numbers, integral_names, finite_element_hashes, options, visualise)
    391 integrand_map: dict[QuadratureRule, ufl.core.expr.Expr] = {
    392     rule: integral.integrand() for rule, integral in sorted_integrals.items()
    393 }
    395 # Build more specific intermediate representation
--> 396 integral_ir = compute_integral_ir(
    397     itg_data.domain.ufl_cell(),
    398     itg_data.integral_type,
    399     expression_ir["entity_type"],
    400     integrand_map,
    401     expression_ir["tensor_shape"],
    402     options,
    403     visualise,
    404 )
    406 expression_ir.update(integral_ir)
    408 # Fetch name
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/ir/integral.py:91, in compute_integral_ir(cell, integral_type, entity_type, integrands, argument_shape, p, visualise)
     88     if domain.topological_dimension() != cell.topological_dimension():
     89         is_mixed_dim = True
---> 91 mt_table_reference = build_optimized_tables(
     92     quadrature_rule,
     93     cell,
     94     integral_type,
     95     entity_type,
     96     initial_terminals.values(),
     97     ir["unique_tables"],
     98     use_sum_factorization=p["sum_factorization"],
     99     is_mixed_dim=is_mixed_dim,
    100     rtol=p["table_rtol"],
    101     atol=p["table_atol"],
    102 )
    104 # Fetch unique tables for this quadrature rule
    105 table_types = {v.name: v.ttype for v in mt_table_reference.values()}
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/ir/elementtables.py:444, in build_optimized_tables(quadrature_rule, cell, integral_type, entity_type, modified_terminals, existing_tables, use_sum_factorization, is_mixed_dim, rtol, atol)
    442             t["array"] = np.vstack([td["array"] for td in new_table])
    443 else:
--> 444     t = get_ffcx_table_values(
    445         quadrature_rule.points,
    446         cell,
    447         integral_type,
    448         element,
    449         avg,
    450         entity_type,
    451         local_derivatives,
    452         flat_component,
    453         codim,
    454     )
    455 # Clean up table
    456 tbl = clamp_table_small_numbers(t["array"], rtol=rtol, atol=atol)
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/ir/elementtables.py:153, in get_ffcx_table_values(points, cell, integral_type, element, avg, entity_type, derivative_counts, flat_component, codim)
    151         raise RuntimeError("Codimension > 1 isn't supported.")
    152     tbl = component_element.tabulate(deriv_order, entity_points)
--> 153     tbl = tbl[basix_index(derivative_counts)]
    154     component_tables.append(tbl)
    156 if avg in ("cell", "facet"):
    157     # Compute numeric integral of the each component table
File /nfs/home/bouteillerp/miniforge3/envs/fenicsx-env/lib/python3.13/site-packages/ffcx/element_interface.py:17, in basix_index(indices)
     15 def basix_index(indices: tuple[int]) -> int:
     16     """Get the Basix index of a derivative."""
---> 17     return basix.index(*indices)
TypeError: index() missing 1 required positional argument: 'p'
Thanks for your advice, sincerely,
Paul
This is a bug in FFCx, addressed in:
Feel free to test this branch to verify that it works in your use-case.
Smaller MWE:
n = 8
# Create the mesh
rank = comm.rank
# Not working
# Working
fdim = tdim - 1
u = fem.Function(V)
u.interpolate(lambda x: np.full(x[0].shape, np.sin(2.3)))
v = fem.Function(Vbar)
v.interpolate(lambda x: np.full(x[1].shape, np.cos(1.2)))
ds_c = ufl.Measure("ds", domain=msh)
J = ufl.inner(u, v) * ds_c
J_compiled = dolfinx.fem.form(J, entity_maps=entity_maps)
Jh = msh.comm.allreduce(dolfinx.fem.assemble_scalar(J_compiled))
assert np.isclose(Jh, 2 * np.sin(2.3) * np.cos(1.2))
It works smoothly, thanks a lot !
