Can't create the form of the navies stokes equations,
Hi guys,
Could anyone help me with the following problems? Thanks!
I try to solve navier stokes on parallel, and when I define my form and solve for the assemble system:
a = form([[((1.0 / dt) * inner(u, v) + b(2 * un - unMinus1, u, v) + 2.0 * nu * a_sym(u, v)) * dx, -c(p, v) * dx],
[c(q, u) * dx, None]])
L = form([(1.0 / dt) * inner(un, v) * dx, None])
#a = form((1./dt)inner(u,v) dx + b(2un-unMinus1,u,v)dx + 2.nua_sym(u,v) dx -c(p,v)dx + c(q,u) dx )
#L = form((1./dt)
(inner(un,v))*dx)x
unPlus1, pnPlus1 = solve_u(a,L,t)
Where solve u is a function that takes care of solving the system. It returns me error:
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py”, line 185, in _compile
self.spawn(compiler_so + cc_args + [src, ‘-o’, obj] + extra_postargs)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py”, line 1041, in spawn
spawn(cmd, dry_run=self.dry_run, **kwargs)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/spawn.py”, line 70, in spawn
raise DistutilsExecError(
distutils.errors.DistutilsExecError: command ‘/ix/wlayton/rui/miniconda/envs/fenicsx-env/bin/x86_64-conda-linux-gnu-cc’ failed with exit code 1
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/cffi/ffiplatform.py”, line 51, in _build
dist.run_command(‘build_ext’)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/dist.py”, line 1244, in run_command
super().run_command(command)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/dist.py”, line 988, in run_command
cmd_obj.run()
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/command/build_ext.py”, line 84, in run
_build_ext.run(self)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py”, line 345, in run
self.build_extensions()
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py”, line 467, in build_extensions
self._build_extensions_serial()
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py”, line 493, in _build_extensions_serial
self.build_extension(ext)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/command/build_ext.py”, line 246, in build_extension
_build_ext.build_extension(self, ext)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py”, line 548, in build_extension
objects = self.compiler.compile(
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py”, line 600, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py”, line 187, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command ‘/ix/wlayton/rui/miniconda/envs/fenicsx-env/bin/x86_64-conda-linux-gnu-cc’ failed with exit code 1
File “/ix/wlayton/rui/para.py”, line 404, in
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/fem/forms.py”, line 176, in form
return _create_form(form)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/fem/forms.py”, line 173, in _create_form
return list(map(lambda sub_form: _create_form(sub_form), form))
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/fem/forms.py”, line 171, in _create_form
return _form(form)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/fem/forms.py”, line 145, in _form
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/jit.py”, line 56, in mpi_jit
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/jit.py”, line 204, in ffcx_jit
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/ffcx/codegeneration/jit.py”, line 186, in compile_forms
impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/ffcx/codegeneration/jit.py”, line 270, in _compile_objects
ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/cffi/api.py”, line 725, in compile
return recompile(self, module_name, source, tmpdir=tmpdir,
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/cffi/recompiler.py”, line 1564, in recompile
outputfilename = ffiplatform.compile(‘.’, ext,
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/cffi/ffiplatform.py”, line 22, in compile
outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
File “/ix/wlayton/rui/miniconda/envs/fenicsx-env/lib/python3.10/site-packages/cffi/ffiplatform.py”, line 58, in _build
raise VerificationError(‘%s: %s’ % (e.class.name, e))
cffi.VerificationError: CompileError: command ‘/ix/wlayton/rui/miniconda/envs/fenicsx-env/bin/x86_64-conda-linux-gnu-cc’ failed with exit code 1
Please provide a minimal reproducible example with 3x` formatting, i.e.
```python
#add code that reproduces your error here
