I made a simple meshes.The solution should consistent with u =(sin(2piy)/(2pi)+jy)sin(pix)
The main code is following
import math
from dolfinx import fem, mesh, plot
from ufl import ds, dx, grad, inner, sin
from petsc4py.PETSc import ScalarType
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (2.0, 1.0)), n=(32, 16),
cell_type=mesh.CellType.triangle,)
V = fem.FunctionSpace(msh, (“Lagrange”, 1))
facets = mesh.locate_entities_boundary(msh, dim=1,
marker=lambda x: np.logical_or(np.isclose(x[0], 0.0),
np.isclose(x[0], 2.0)))
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
u = ufl.TrialFunction(V)
v = ufl.TestFunction(V)
x = ufl.SpatialCoordinate(msh)
pi = math.pi
x0 = pi * x[0]
x1 = sin(x0)
y1 = sin(2 * pi * x[1])
f = pi * x1 * (2.5 * y1 + 1j * pi * x[1])
g = (1 + 1j) * sin(pi * x[1])
a = inner(grad(u), grad(v)) * dx
L = inner(f, v) * dx + inner(g, v) * ds
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={“ksp_type”: “preonly”, “pc_type”: >“lu”})
uh = problem.solve()
Here are my problems:
1.In the analytical solution, u(y=0)=0, u(y=1)=jsin(pix). But the figure in pyvista is not consistent.The figure is as follow:
2.I try to understand “ds” by:
print(fem.assemble(fem.Constant(msh,1) * ds))
But I get:
RuntimeError: Unsupported dtype
I know this way from the answer of this web
print(assemble(Constant(1)*dx))
I have tried “print(assemble(Constant(1)*ds))”. But “assemble” and “Constant” are not defined.
So, how can I do?
Thank you.
