I am able to reproduce the error I am getting in the following minimal example: Consider
\begin{align*}
&\sigma \boldsymbol{u} - div(\nu \nabla \boldsymbol{u}) = \boldsymbol{f}(T) \;\; \mbox{in} \;\; \Omega := [0,1] \times [0,1], \\
&-div(D \nabla T) + (\boldsymbol{u} \cdot \nabla) T = 0 \;\; \mbox{in} \;\; \Omega, \\
&\frac{\partial T}{\partial \boldsymbol{n}} = 0 \;\; \mbox{on} \;\; \Gamma_{U}, \Gamma_{D}, \; \boldsymbol{u} = \boldsymbol{0} \;\; \mbox{on} \;\; \Gamma, \; T = T_0 \;\; \mbox{on} \;\; \Gamma_L, \; T = T_1 \;\; \mbox{on} \;\; \Gamma_R.
\end{align*}
Here, \boldsymbol{f}(T) := (G_r T)g is a linear function of T and G_r is a positive constant and g is a vector. I tried solving this problem using the built in Newton solver (with parameter choices specified in the code):
# Parameters
Ra = Constant(100); Rk = Constant(1); Pr = Constant(10); Da = Constant(10E-7); Le = Constant(0.8);
Sr = Constant(0); Du = Constant(.1); N = Constant(0);
GrT = Ra/(Pr*Da); GrC = N*GrT
Sc = Le*Pr
g = Constant((1,0))
nu = Constant(1)
sigma = 1/Da # Reaction Domination
#D
DT = as_matrix([[Rk/Pr, Du],[Sr, 1/Sc]])
# T0 and T1
TD0 = Constant(-1); TD1 = Constant(1);
# Mollified at the ends
# TD0 = Expression('(x[1]>0 && x[1] < 1) ? -1/(exp(1/((x[1])*(1-x[1])))) : 0', degree = 4)
# TD1 = Expression('(x[1]>0 && x[1] < 1) ? 1/(exp(1/((x[1])*(1-x[1])))) : 0', degree = 4)
uD = Constant((0,0))
mesh = UnitSquareMesh(30,30)
# Finite element spaces
cell = triangle;
k = int(1)
P1v = VectorElement('CR', cell, k)
P1s = FiniteElement('CR', cell, k)
elem = MixedElement([P1v, P1s])
W = FunctionSpace(mesh, elem)
v, s = TestFunctions(W)
delta = Function(W)
u, T = split(delta)
# Boundary
class Left(SubDomain):
return near(x[0], 0.0)
class Right(SubDomain):
return near(x[0], 1.0)
class Bottom(SubDomain):
return near(x[1], 0.0)
class Top(SubDomain):
return near(x[1], 1.0)
# Initialize sub-domain instances
left = Left()
top = Top()
right = Right()
bottom = Bottom()
boundaries.set_all(0)
left.mark(boundaries, 1)
top.mark(boundaries, 2)
right.mark(boundaries, 3)
bottom.mark(boundaries, 4)
bc_uT = DirichletBC(W.sub(0), uD, boundaries, 2)
bc_uB = DirichletBC(W.sub(0), uD, boundaries, 4)
bc_uL = DirichletBC(W.sub(0), uD, boundaries, 1)
bc_uR = DirichletBC(W.sub(0), uD, boundaries, 3)
bc_TL = DirichletBC(W.sub(1), TD1, boundaries, 1)
bc_TR = DirichletBC(W.sub(1), TD0, boundaries, 3)
bc = [bc_uT, bc_uB, bc_uL, bc_uR,
bc_TL, bc_TR]
he = FacetArea(mesh)
StabC = sqrt(sigma)*10
# Penalty to handle reaction domination
PenaltyState = (StabC)/avg(he) * nu * dot((jump(u)),jump(v)) * dS + (StabC)/he*dot((nu*u),v) * ds
Eq1s = (inner(nu*grad(u), grad(v))*dx) + sigma*dot(u,v)*dx + PenaltyState
FY = (GrT*T)*g
Eq8s = inner(v,FY)*dx
# unwinding
upwindT = (abs(dot(avg(u),n('+')))*(jump(s)*jump(T)))*dS
Eq1Ts = dot((DT*grad(T)), grad(s))*dx + dot(u,grad(T))*s*dx + upwindT
F = Eq1s + Eq1Ts - Eq8s
# Solve
solve(F == 0, delta, bc, solver_parameters={"newton_solver":{"relative_tolerance": 1e-6}})
uh, Th = delta.split()
plt.figure(1)
plt.title('u_h')
pu = plot(uh)
plt.colorbar(pu)
plt.figure(2)
plt.title('T_h')
pT = plot(Th)
plt.colorbar(pT)
Observe that due to the choice of parameters, the boundary conditions T_0 = -1 and T_1 = 1 create singularities at the left and right corners of the domain, which the built in Newton solver is able to handle. Following is the output:
(fenicsproject) jaitushar@Jais-MacBook-Pro ~ % cd /Users/jaitushar ; /usr/bin/env /opt/anaconda3/envs/fenicsproject/bin/python /Users/jaitushar/.vscode/extens
ions/ms-python.python-2023.10.1/pythonFiles/lib/python/debugpy/adapter/../../debugpy/launcher 64109 -- /Users/jaitushar/Documents/myFEniCS/myExamples/MinimalEx
_II_Newton.py
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
Newton iteration 0: r (abs) = 2.329e+01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-06)
Newton iteration 1: r (abs) = 2.135e-01 (tol = 1.000e-10) r (rel) = 9.167e-03 (tol = 1.000e-06)
Newton iteration 2: r (abs) = 4.348e+00 (tol = 1.000e-10) r (rel) = 1.867e-01 (tol = 1.000e-06)
Newton iteration 3: r (abs) = 1.019e+00 (tol = 1.000e-10) r (rel) = 4.374e-02 (tol = 1.000e-06)
Newton iteration 4: r (abs) = 1.775e-01 (tol = 1.000e-10) r (rel) = 7.623e-03 (tol = 1.000e-06)
Newton iteration 5: r (abs) = 8.842e-03 (tol = 1.000e-10) r (rel) = 3.797e-04 (tol = 1.000e-06)
Newton iteration 6: r (abs) = 2.188e-05 (tol = 1.000e-10) r (rel) = 9.393e-07 (tol = 1.000e-06)
Newton solver finished in 6 iterations and 6 linear solver iterations.
However, when I code the same problem using a custom newton solver by providing Jacobian and residual manually and using a linear solver (mumps), the solver is not able to resolve the singularity and fluctuates. Following is the code:
# Import Libraries
Sc = Le*Pr
g = Constant((1,0))
nu = Constant(1)
sigma = 1/Da
cell = triangle;
k = int(1)
u, T = TrialFunctions(W)
# T0D = Expression('(x[1]>0.2+eps && x[1] < 0.8-eps) ? -1/(exp(1/((x[1]-0.2)*(0.8-x[1])))) : 0', eps = DOLFIN_EPS, degree = 2)
# T1D = Expression('(x[1]>0.2+eps && x[1] < 0.8-eps) ? 1/(exp(1/((x[1]-0.2)*(0.8-x[1])))) : 0', eps = DOLFIN_EPS, degree = 2)
# Boundary
left = Left()
top = Top()
right = Right()
bottom = Bottom()
bc_TL, bc_TR]
# Initial guesses satisfying the boundary conditions
u0 = Function(W)
T0 = Function(W)
bc_TL.apply(T0.sub(1).vector()); bc_TR.apply(T0.sub(1).vector())
for bcs in bc:
bcs.homogenize()
# Mesh info
# Assemble
iter = 0; Er = 1; a_tol = 1E-8
while (Er > a_tol) and (iter < 20):
iter += 1
############### Assemble non-linearities ###############
b = u0.sub(0)
FY = (GrT*T0.sub(1))*g
upwindT = (abs(dot(avg(b),n('+')))*(jump(s)*jump(T)))*dS
Eq1Ts = dot((DT*grad(T)), grad(s))*dx + dot(b,grad(T))*s*dx + upwindT
# System
J = Eq1s + Eq1Ts
res = - action(Eq1s, u0) + Eq8s - action(Eq1Ts, T0)
# Solve
delta = Function(W)
solve(J == res, delta, bc, solver_parameters={'linear_solver':'mumps'})
un, Tn= delta.split()
# Termination criterion
error = (delta)**2*dx
Er = sqrt(abs(assemble(error)))
# Update the solution
u0.vector()[:] += un.vector()[:]
T0.vector()[:] += Tn.vector()[:]
print('|delta| = %e, iteration %d \n' % (Er, iter))
## Visualize
plt.figure(1)
plt.title('u_h')
pu = plot(u0.sub(0))
plt.colorbar(pu)
plt.figure(2)
plt.title('T_h')
pT = plot(T0.sub(1))
plt.colorbar(pT)
Output:
ions/ms-python.python-2023.10.1/pythonFiles/lib/python/debugpy/adapter/../../debugpy/launcher 64168 -- /Users/jaitushar/Documents/myFEniCS/myExamples/MinimalEx
_II.py
Solving linear variational problem.
|delta| = 5.676462e-01, iteration 1
|delta| = 5.546556e+00, iteration 2
|delta| = 4.399264e-01, iteration 3
|delta| = 4.358093e+00, iteration 4
|delta| = 1.333091e-01, iteration 5
|delta| = 1.318313e+00, iteration 6
|delta| = 4.795220e-02, iteration 7
|delta| = 4.542295e-01, iteration 8
|delta| = 1.668294e-02, iteration 9
|delta| = 1.470277e-01, iteration 10
|delta| = 5.031541e-03, iteration 11
|delta| = 4.315923e-02, iteration 12
|delta| = 1.448626e-03, iteration 13
|delta| = 1.234712e-02, iteration 14
|delta| = 4.584585e-04, iteration 15
|delta| = 3.990136e-03, iteration 16
|delta| = 2.415253e-04, iteration 17
|delta| = 2.231978e-03, iteration 18
|delta| = 2.039454e-04, iteration 19
|delta| = 1.926179e-03, iteration 20
Questions:
I suspect ill conditioning is being introduced due to the boundary conditions and the problem. How is the Newton solver able to handle this but not the custom newton solve using the linear solver that I wrote?
Does the Newton solver introduce some kind of preconditioning in the system by default? If so how can I use it in my linear solve step?
Is there anyway to resolve this? Any hints or ideas in this direction will help.
Thanks!
