Demo Cahn-Hilliard not working on fresh installation
Hi all,
I’ve just installed dolfinx from scratch, using the conda build. I did so following the instructions, i.e. I created a a conda environment, activated it and then run this command within it:
conda install -c conda-forge fenics-dolfinx mpich pyvista
The Poisson demo works just fine and produces an output. However, the second demo, Cahn-Hilliard, gives this error:
pyvista and pyvistaqt are required to visualise the solution
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Do you know what can be happening? Thanks!
Ok, I was able to solve it myself. I didn’t recompile PETSC as suggested, given that I had not built from source in the first place, so I thought the problem might be elsewhere.
The message was complaining about pyvistaqt. I tried to install it, but then the demo was giving the error No Qt bindings could be found.
I installed pyqt5 using pip (it wasn’t available from conda):
python -m pip install pyqt5
I noticed matplotlib wasn’t in the environment, so I installed it (curiously, the first demo run).
After that, the demo worked. Leaving it here in case it helps someone else.
