Segmentation fault upon importing matplotlib into a dolfinx
Merely importing matplotlib into any file in my fenicsx conda environment on my machine was causing a segmentation fault. Here is the MWE code :
plt.plot(1,1)
and here was the error:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS to find memory corruption errors
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
system msg for write_line failure : Bad file descriptor
I’m on Ubuntu 22.04.1 LTS, using dolfinx 0.5.2 (python build #: py310h0d9d84b_100 from conda-forge) and matplotlib 3.6.2 (pypi package).
It seems that I had pip installed matplotlib, so I pip uninstalled matplotlib, then installed with conda via:
conda install -c conda-forge matplotlib
This fixed my issue. I’m not understanding why this pip vs conda install seems to make so much of a difference, but felt like these types of errors are not uncommon for people to see at some point using FEniCS or FEniCSx. Any explanation of why this was happening would be appreciated!
Mixing pip and conda is not adviced, as they are based on different binaries, see:
