Problems about dolfinx.plot with pyvista
I try to plot some points on function follow this tutorial.But I meet follow error messages :
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS to find memory corruption errors
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
system msg for write_line failure : Bad file descriptor
Here are my codes,errors happened after I add some codes about matplotlib:
import dolfinx.plot as plot
from dolfinx.fem import Function, FunctionSpace, VectorFunctionSpace
from dolfinx.mesh import (CellType, compute_midpoints, create_unit_cube,
                          create_unit_square, meshtags)
try:
    import pyvista
except ModuleNotFoundError:
    print("pyvista is required for this demo")
    exit(0)
def plot_higher_order():
    msh = create_unit_square(MPI.COMM_WORLD, 12, 12, cell_type=CellType.quadrilateral)
    # We continue using the mesh from the previous section, and find all
    # cells satisfying the condition below
    def in_circle(x):
        """Mark sphere with radius < sqrt(2)"""
        return np.array((x.T[0] - 0.5)**2 + (x.T[1] - 0.5)**2 < 0.2**2, dtype=np.int32)
    # Create mesh tags for all cells. If midpoint is inside the
    # circle, it gets value 1, otherwise 0.
    num_cells = msh.topology.index_map(msh.topology.dim).size_local
    midpoints = compute_midpoints(msh, msh.topology.dim, list(np.arange(num_cells, dtype=np.int32)))
    cell_tags = meshtags(msh, msh.topology.dim, np.arange(num_cells), in_circle(midpoints))
    # We start by interpolating a discontinuous function into a second order
    # discontinuous Lagrange space. Note that we use the `cell_tags` from
    # the previous section to get the cells for each of the regions
    V = FunctionSpace(msh, ("Discontinuous Lagrange", 2))
    u = Function(V, dtype=np.float64)
    u.interpolate(lambda x: x[0], cell_tags.find(0))
    u.interpolate(lambda x: x[1] + 1, cell_tags.find(1))
    u.x.scatter_forward()
    x = [0]
    y = [1]
    plt.scatter(x,y)
    # To get a topology that has a 1-1 correspondence with the
    # degrees-of-freedom in the function space, we call
    # `dolfinx.plot.create_vtk_mesh`.
    cells, types, x = plot.create_vtk_mesh(V)
    # Create a pyvista mesh from the topology and geometry, and attach
    # the coefficients of the degrees of freedom
    grid = pyvista.UnstructuredGrid(cells, types, x)
    grid.point_data["u"] = u.x.array
    grid.set_active_scalars("u")
    # We would also like to visualize the underlying mesh and obtain
    # that as we have done previously
    cell_entities = np.arange(num_cells, dtype=np.int32)
    cells, types, x = plot.create_vtk_mesh(msh, entities=cell_entities)
    org_grid = pyvista.UnstructuredGrid(cells, types, x)
    # We visualize the data
    plotter = pyvista.Plotter()
    plotter.add_text("Second-order (P2) discontinuous elements",
                     position="upper_edge", font_size=14, color="black")
    sargs = dict(height=0.1, width=0.8, vertical=False, position_x=0.1, position_y=0, color="black")
    plotter.add_mesh(grid, show_edges=False, scalar_bar_args=sargs, line_width=0)
    plotter.add_mesh(org_grid, color="white", style="wireframe", line_width=5)
    plotter.add_mesh(grid.copy(), style="points", point_size=15, render_points_as_spheres=True, line_width=0)
    plotter.view_xy()
    if pyvista.OFF_SCREEN:
        plotter.screenshot(f"DG_{MPI.COMM_WORLD.rank}.png",
                           transparent_background=transparent, window_size=[figsize, figsize])
        plotter.show()
plot_higher_order()
By the way,what should I do to change the font to Times new roman and plot the isopleth as follow figure shown:
Here are the codes that I add.
I would add
pyvista.start_xvfb() after importing it.
Hello @dokken, i am try ejecute test problem 1: Channel flow with this code
import pyvista
from tqdm import tqdm
from dolfinx import fem, mesh, io, plot
from dolfinx.fem import Constant, Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
from dolfinx.mesh import create_unit_square
from ufl import (FacetNormal, FiniteElement, Identity, TestFunction, TrialFunction, VectorElement,
                 div, dot, ds, dx, inner, lhs, nabla_grad, rhs, sym)
dt = 0.05
t = 0
T = 10
num_steps = 500
dt = T / num_steps
v_cg2 = VectorElement("Lagrange", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
def walls(x):
    return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1))
wall_dofs = locate_dofs_geometrical(V, walls)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
def inflow(x):
    return np.isclose(x[0], 0)
inflow_dofs = locate_dofs_geometrical(Q, inflow)
bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
def outflow(x):
    return np.isclose(x[0], 1)
outflow_dofs = locate_dofs_geometrical(Q, outflow)
bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
bcu = [bc_noslip]
bcp = [bc_inflow, bc_outflow]
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
mu = Constant(mesh, PETSc.ScalarType(1))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define strain-rate tensor
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2 * mu * epsilon(u) - p * Identity(len(u))
# Define the variational problem for the first step
p_n = Function(Q)
p_n.name = "p_n"
F1 = rho * dot((u - u_n) / k, v) * dx
F1 += rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
F1 += inner(sigma(U, p_n), epsilon(v)) * dx
F1 += dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds
F1 -= dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q)) * dx)
L2 = form(dot(nabla_grad(p_n), nabla_grad(q)) * dx - (rho / k) * div(u_) * q * dx)
A2.assemble()
b2 = create_vector(L2)
p_ = Function(Q)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
from pathlib import Path
folder = Path("/home/gerard/Escritorio/FEniCSx/results/Channel")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, folder / "poiseuille_u.bp", u_n, engine="BP4")
vtx_p = VTXWriter(mesh.comm, folder / "poiseuille_p.bp", p_n, engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
def u_exact(x):
    values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
    values[0] = 4 * x[1] * (1.0 - x[1])
    return values
u_ex = Function(V)
u_ex.interpolate(u_exact)
L2_error = form(dot(u_ - u_ex, u_ - u_ex) * dx)
for i in tqdm(range(num_steps)):
    # Update current time step
    # Step 1: Tentative veolcity step
    with b1.localForm() as loc_1:
        loc_1.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    u_.x.scatter_forward()
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc_2:
        loc_2.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc_3:
        loc_3.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_n.x.array[:] = u_.x.array[:]
    p_n.x.array[:] = p_.x.array[:]
    # Write solutions to file
    vtx_u.write(t)
    vtx_p.write(t)
    # Compute error at current time-step
    error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(L2_error), op=MPI.SUM))
    error_max = mesh.comm.allreduce(np.max(u_.vector.array - u_ex.vector.array), op=MPI.MAX)
    # Print error only every 20th step and at the last step
    if (i % 20 == 0) or (i == num_steps - 1):
        print(f"Time {t:.2f}, L2-error {error_L2:.2e}, Max error {error_max:.2e}")
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
topology, cell_types, geometry = vtk_mesh(V)
values = np.zeros((geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_n)] = u_n.x.array.real.reshape((geometry.shape[0], len(u_n)))
# Create a point cloud of glyphs
function_grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
function_grid["u"] = values
glyphs = function_grid.glyph(orient="u", factor=0.2)
# Create a pyvista-grid for the mesh
grid = pyvista.UnstructuredGrid(*vtk_mesh(mesh, mesh.topology.dim))
# Create plotter
plotter.add_mesh(grid, style="wireframe", color="k")
plotter.add_mesh(glyphs)
plotter.view_xy()
if not pyvista.OFF_SCREEN:
    plotter.show()
    fig_as_array = plotter.screenshot("glyphs.png")
but I dont see graph with glyphs like tutorial, and my code still working
but I dont see graph with glyphs like in the tutorial, and my code still ejecute
Please check what this variable is set too.
It would Also be helpful if you explain how you install dolfinx.
I print the variable pyvista.OFF_SCREEN and the result is false. I installed fenicsx with apt from this page
https://github.com/FEniCS/dolfinx?tab=readme-ov-file#installation
Now, I am trying to install fenicsx with conda but I have this problem
https://fenicsproject.discourse.group/t/problem-installing-conda/12321/2
Annex screenshot
@dokken I reinstalled dolfinx with conda and the problem persists. I run the code and it freezes at the next part of the code. Whose value is shown in the attached screenshot.
    plotter.show()
Any suggestions?
What kind of system are you running on? Sub-system for linux? Mac? Linux-distribution, if so which one?
I am using Linux-Mint 21.1, however, I also using other computer with Linux-Ubuntu 22.04.4 LTS. In the both system I have the same problem
@dokken I am running the code in debugger mode, and I see when execute the line plotter.show() the problem happen. I leave it running all the evening but not show the plot. I dont know have to do. I am reinstalled dolfinx two times with conda.
    plotter.show()
@dokken I should to reinstall ubuntu in my computer and install dolfinx with conda?
@dokken continuing with the tutorial channel flow from here. If I comment this line in my code
#pyvista-start_xvfb()
my kernel don’t die, but I have question the image is the solution at the last moment of time? Can I see some animation of the solution?
t = 0
T = 10
num_steps = 500
dt = T / num_steps
q = TestFunction(Q)
def walls(x):
def inflow(x):
def outflow(x):
bcu = [bc_noslip]
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
def sigma(u, p):
p_n = Function(Q)
p_n.name = "p_n"
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1.assemble()
u_ = Function(V)
A2.assemble()
p_ = Function(Q)
A3.assemble()
# Solver for step 1
# Solver for step 2
# Solver for step 3
folder = Path("results")
vtx_u.write(t)
vtx_p.write(t)
def u_exact(x):
    return values
u_ex = Function(V)
for i in range(num_steps):
        loc_1.set(0)
    set_bc(b1, bcu)
        loc_2.set(0)
    set_bc(b2, bcp)
        loc_3.set(0)
    vtx_u.write(t)
    vtx_p.write(t)
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
import pyvista
#pyvista.start_xvfb()
# Create plotter
plotter.view_xy()
print(pyvista.OFF_SCREEN)
    plotter.show()
To make an animation you would need to store steps throughout the loop,
see for instance
or
https://jsdokken.com/dolfinx-tutorial/chapter2/hyperelasticity.html
Or use pyvista qt:
https://docs.fenicsproject.org/dolfinx/v0.7.3/python/demos/demo_cahn-hilliard.html
