I’d like to apply a DirichletBC on subspaces but only on a set of subspaces.
My Function space from Fenics-Shell Naghdi non linear:
element = MixedElement([VectorElement("Lagrange", triangle, 1),
VectorElement("Lagrange", triangle, 2),
FiniteElement("Lagrange", triangle, 1),
FiniteElement("N1curl", triangle, 1),
RestrictedElement(FiniteElement("N1curl", triangle, 1), "edge")])
U = ProjectedFunctionSpace(mesh, element, num_projected_subspaces=2)
U.sub(0) are variables (x,y) in plane displacement and U.sub(2) is z the out of plane displacement. I’d like to apply a DirichletBC on displacement (x,y,z) as a UserExpresion of (x,y,z).
I want something like that :
DirichletBC([U.sub(0)[0],U.sub(0)[1],U.sub(2)],Constant((0.0,0.0,0.0)),rightFace)
With an Expression instead of the Consant. But it should work with this constant for testing what I want to do.
Thanks
