I use version 2019.01 on Ubuntu. When I try to set a DirichletBC with a ufl function for a subspace of a mixed function space, I get an error, see below. This does not happen when I use an Expression or when setting the DirichletBC like this for a complete function space (without the sub(0)).
Is there a way to fix this?
mesh = UnitSquareMesh(10,10)
x = SpatialCoordinate(mesh)
V_ele = VectorElement('CG', mesh.ufl_cell(), 2)
Q_ele = FiniteElement('CG', mesh.ufl_cell(), 1)
W = FunctionSpace(mesh, V_ele*Q_ele)
u_exact = as_vector([sin(4*pi*x[0])*cos(4*pi*x[1]), -cos(4*pi*x[0])*sin(4*pi*x[1])])
u_exact_expr = Expression(('sin(4*pi*x[0])*cos(4*pi*x[1])','-cos(4*pi*x[0])*sin(4*pi*x[1])'), degree = 3)
f = as_vector([28*pi*pi*sin(4*pi*x[0])*cos(4*pi*x[1]), -36*pi*pi*cos(4*pi*x[0])*sin(4*pi*x[1])])
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
a = inner(grad(u), grad(v))*dx - p*div(v)*dx + q*div(u)*dx
A = assemble(a)
L = inner(f, v)*dx
b = assemble(L)
bc = DirichletBC(W.sub(0), u_exact, 'on_boundary')
bc.apply(A, b)
Error message:
File “Fenics_test.py”, line 25, in
bc = DirichletBC(W.sub(0), u_exact, ‘on_boundary’)
File “/usr/lib/python3/dist-packages/dolfin/fem/dirichletbc.py”, line 76, in init
expr = project(args[1], args[0], solver_type = ‘mumps’) # FIXME: This should really be interpolaton (project is expensive)
File “/usr/lib/python3/dist-packages/dolfin/fem/projection.py”, line 137, in project
function = Function(V)
File “/usr/lib/python3/dist-packages/dolfin/function/function.py”, line 216, in init
self._cpp_object = cpp.function.Function(V._cpp_object)
RuntimeError:*** -------------------------------------------------------------------------
*** Error: Unable to create function.
*** Reason: Cannot be created from subspace. Consider collapsing the function space.
*** Where: This error was encountered inside Function.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
