Hello everyone, my code output is incorrect, and the visualizations using ParaView are even more wrong. I hope someone can help me, thank you.
import os
import time
from slepc4py import SLEPc
from dolfinx.fem.petsc import assemble_matrix
from ufl import inner, sym, grad, tr, Identity, dx, TestFunction, TrialFunction
from MMA import mmasub
# 1. Parameters: modify here for geometry, mesh, volume fraction, BCs
comm = MPI.COMM_WORLD
rank = comm.rank
# 3D design domain mesh size. Start with this coarse mesh; refine later.
nelx, nely, nelz = 60, 12, 12
# Element length. If unit is mm, rho_m=2.85e-9 corresponds to tonne/mm^3.
elem_len = 1.0
Lx, Ly, Lz = nelx * elem_len, nely * elem_len, nelz * elem_len
# Material properties: E0 / Emin / nu / rho_m from the 2D code
E0 = 78e3
Emin = 1e-6
nu = 0.30
rho_m = 2.85e-9
# Topology optimization parameters
volfrac = 0.30
q_ramp = 4.0
rmin = 2.5
tol = 0.01
maxloop = 80
objOrder = 1 # which eigenfrequency to maximize, 1 = first
nEig = 6 # number of eigenvalues to compute
save_interval = 10 # output ParaView every this many iterations; 0 = final only
# Output directory
out_dir = "paraview_3d_result"
os.makedirs(out_dir, exist_ok=True) if rank == 0 else None
comm.barrier()
r_helm = rmin / (2.0 * np.sqrt(3.0))
TWO_PI = 2.0 * np.pi
def log(msg: str):
if rank == 0:
print(msg, flush=True)
def ramp_ufl(r):
"""RAMP material interpolation, same as in 2D version."""
return Emin + (1.0 - Emin) * r / (1.0 + q_ramp * (1.0 - r))
# 2. Create 3D mesh and function spaces
domain = mesh.create_box(
comm,
[np.array([0.0, 0.0, 0.0]), np.array([Lx, Ly, Lz])],
[nelx, nely, nelz],
cell_type=mesh.CellType.hexahedron,
tdim = domain.topology.dim
fdim = tdim - 1
# Displacement space: 3D vector field
V = fem.functionspace(domain, ("Lagrange", 1, (3,)))
# Design variable / density space: CG1; cell‑wise density for ParaView: DG0
V_rho = fem.functionspace(domain, ("Lagrange", 1))
D0 = fem.functionspace(domain, ("DG", 0))
n_dofs = V.dofmap.index_map.size_local * V.dofmap.index_map_bs
n_rho = V_rho.dofmap.index_map.size_local
bs = V.dofmap.index_map_bs
# 3. Boundary conditions: clamped at both ends x=0 and x=Lx
# Modify the function below if you want a different support.
def is_fixed_boundary(x):
return np.isclose(x[0], 0.0) | np.isclose(x[0], Lx)
bc_facets = mesh.locate_entities_boundary(domain, fdim, is_fixed_boundary)
bc_dofs = fem.locate_dofs_topological(V, fdim, bc_facets)
bc = fem.dirichletbc(np.zeros(3, dtype=PETSc.ScalarType), bc_dofs, V)
constrained = np.array(bc.dof_indices()[0], dtype=np.int32)
all_dofs = np.arange(n_dofs, dtype=np.int32)
free_dofs = np.setdiff1d(all_dofs, constrained).astype(np.int32)
is_free = PETSc.IS().createGeneral(free_dofs, comm=comm)
# 4. Design variables and 3D elasticity constitutive model
x_design = fem.Function(V_rho, name="design")
x_design.x.array[:] = volfrac
x_design.x.scatter_forward()
xPhys = fem.Function(V_rho, name="density")
xPhys.x.array[:] = volfrac
xPhys.x.scatter_forward()
xPhys_dg0 = fem.Function(D0, name="density_cell")
u_eig = fem.Function(V, name="mode_shape")
return sym(grad(u))
def sigma(u, E_eff):
"""3D isotropic linear elasticity constitutive law."""
mu_ = E_eff / (2.0 * (1.0 + nu))
lam_ = E_eff * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
return lam_ * tr(epsilon(u)) * Identity(3) + 2.0 * mu_ * epsilon(u)
E_eff_ufl = E0 * ramp_ufl(xPhys)
u_tr = TrialFunction(V)
v_te = TestFunction(V)
# Stiffness matrix
K_ufl = inner(sigma(u_tr, E_eff_ufl), epsilon(v_te)) * dx
# Mass matrix = structural self‑mass (no added mass)
M_ufl = rho_m * xPhys * inner(u_tr, v_te) * dx
K_form = fem.form(K_ufl)
M_form = fem.form(M_ufl)
# Residual for eigenvalue sensitivity: d/dx [u^T K u - lambda u^T M u]
lam_const = fem.Constant(domain, PETSc.ScalarType(0.0))
psi = TestFunction(V_rho)
R_eig = (
inner(sigma(u_eig, E_eff_ufl), epsilon(u_eig)) * dx
- lam_const * rho_m * xPhys * inner(u_eig, u_eig) * dx
dlam_dxPhys_form = fem.form(ufl.derivative(R_eig, xPhys, psi))
# Volume constraint
vol_form = fem.form(xPhys * dx)
dvol_dxPhys_form = fem.form(ufl.derivative(xPhys * dx, xPhys, psi))
total_vol = Lx * Ly * Lz
# 5. Helmholtz density filter, same as in 2D version
rho_tr = TrialFunction(V_rho)
rho_te = TestFunction(V_rho)
a_filt = (r_helm**2 * inner(grad(rho_tr), grad(rho_te)) + rho_tr * rho_te) * dx
m_filt = rho_tr * rho_te * dx
A_filt = assemble_matrix(fem.form(a_filt))
A_filt.assemble()
M_filt = assemble_matrix(fem.form(m_filt))
M_filt.assemble()
filt_solver = PETSc.KSP().create(comm)
filt_solver.setOperators(A_filt)
filt_solver.setType("preonly")
_pc = filt_solver.getPC()
_pc.setType("lu")
_pc.setFactorSolverType("mumps")
filt_solver.setFromOptions()
_filt_x, _ = A_filt.createVecs()
_filt_rhs, _ = A_filt.createVecs()
_filt_sol, _ = A_filt.createVecs()
def apply_filter(src_array):
_filt_x.setArray(src_array)
_filt_x.assemble()
M_filt.mult(_filt_x, _filt_rhs)
filt_solver.solve(_filt_rhs, _filt_sol)
return _filt_sol.getArray().copy()
def filter_sensitivity(dobj_dxPhys_array):
_filt_rhs.setArray(dobj_dxPhys_array)
_filt_rhs.assemble()
M_filt.mult(_filt_sol, _filt_x)
return _filt_x.getArray().copy()
# 6. Eigenvalue solver and modal mass normalization
def solve_eigs(K_petsc, M_petsc, nev):
eps = SLEPc.EPS().create(comm)
eps.setOperators(K_petsc, M_petsc)
eps.setProblemType(SLEPc.EPS.ProblemType.GHEP)
eps.setDimensions(nev=nev, ncv=PETSc.DECIDE, mpd=PETSc.DECIDE)
eps.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_REAL)
eps.setTarget(0.0)
st = eps.getST()
st.setType("sinvert")
ksp = st.getKSP()
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
eps.setFromOptions()
eps.solve()
return eps
def modal_mass(M_petsc, phi_full_local):
"""Compute phi^T M phi, to avoid inconsistency due to SLEPc eigenvector scaling."""
v, _ = M_petsc.createVecs()
mv = v.duplicate()
v.setArray(phi_full_local)
v.assemble()
M_petsc.mult(v, mv)
den = float(np.real(v.dot(mv)))
v.destroy()
mv.destroy()
return max(den, 1e-30)
def write_paraview(loop_id, freq_hz):
"""Output ParaView‑readable file."""
xPhys_dg0.interpolate(xPhys)
xPhys_dg0.x.scatter_forward()
u_eig.x.scatter_forward()
# Keep original naming: itermm
fname = os.path.join(out_dir, f"topopt3d_itermm_{loop_id:03d}.xdmf")
with io.XDMFFile(comm, fname, "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(xPhys_dg0, 0.0)
xdmf.write_function(u_eig, 0.0)
log(f" [ParaView] Exported {fname}, current frequency f = {freq_hz:.6g} Hz")
# 7. MMA initialization
xval = x_design.x.array.reshape(-1, 1).copy()
xmin_ = 0.001 * np.ones((n_rho, 1))
xmax_ = np.ones((n_rho, 1))
xold1, xold2 = xval.copy(), xval.copy()
low, upp = xmin_.copy(), xmax_.copy()
loop = 0
change = 0.2
obj0 = None
log("========== 3D topology optimization (no added point mass) ==========")
log(f"mesh: {nelx} x {nely} x {nelz}, dofs(local)={n_dofs}, rho_dofs(local)={n_rho}")
log(f"domain: Lx={Lx}, Ly={Ly}, Lz={Lz}")
log(f"boundary: fixed at x=0 and x={Lx}")
# 8. Main optimization loop
while change > tol and loop < maxloop:
t0 = time.time()
loop += 1
# Density filtering
xPhys.x.array[:] = apply_filter(x_design.x.array)
xPhys.x.array[:] = np.clip(xPhys.x.array, 0.001, 1.0)
# Assemble K/M; boundary conditions handled by sub‑matrix on free DOFs
Kfull = assemble_matrix(K_form, bcs=[])
Kfull.assemble()
Mfull = assemble_matrix(M_form, bcs=[])
Mfull.assemble()
Kf = Kfull.createSubMatrix(is_free, is_free)
Mf = Mfull.createSubMatrix(is_free, is_free)
eps_solver = solve_eigs(Kf, Mf, nEig)
nconv = eps_solver.getConverged()
if nconv < nEig:
log(f" [Warning] iter {loop}: only {nconv}/{nEig} eigenpairs converged")
eigvals = np.zeros(nEig)
eigvecs_full = np.zeros((n_dofs, nEig))
vr, _ = Kf.createVecs()
n_read = min(nconv, nEig)
for i in range(n_read):
lam_i = eps_solver.getEigenpair(i, vr)
eigvals[i] = float(np.real(lam_i))
arr = np.zeros(n_dofs, dtype=PETSc.ScalarType)
arr[free_dofs] = vr.getArray()
eigvecs_full[:, i] = np.real(arr)
idx = objOrder - 1
if idx >= n_read:
raise RuntimeError(f"Target mode objOrder={objOrder} did not converge. Refine mesh, check BCs, or increase nEig.")
lam_obj = max(eigvals[idx], 1e-30)
omega = np.sqrt(lam_obj)
freq = omega / TWO_PI
# Store current target mode shape for sensitivity and ParaView output
u_eig.x.array[:] = eigvecs_full[:, idx]
# Sensitivity of eigenfrequency
lam_const.value = PETSc.ScalarType(lam_obj)
den_modal = modal_mass(Mfull, eigvecs_full[:, idx])
dlam_dxPhys = fem.assemble_vector(dlam_dxPhys_form).array / den_modal
dfreq_dxPhys = (1.0 / (2.0 * TWO_PI * omega)) * dlam_dxPhys
dfreq_dx = filter_sensitivity(dfreq_dxPhys)
# Volume constraint and its sensitivity
cur_vol = float(fem.assemble_scalar(vol_form))
g_val = cur_vol / total_vol - volfrac
dvol_dxPhys = fem.assemble_vector(dvol_dxPhys_form).array
dg_dx = filter_sensitivity(dvol_dxPhys) / total_vol
# Normalize objective
if loop == 1:
obj0 = freq
obj_n = 1.0
obj_n = freq / obj0
dobj_dx = dfreq_dx / max(obj0, 1e-30)
# MMA update: maximize=True as in the 2D code
df0dx = dobj_dx.reshape(-1, 1)
fval = np.array([[g_val]])
dfdx = dg_dx.reshape(1, -1)
m_con, n_var = 1, n_rho
a0 = 1.0
a_ = np.zeros((m_con, 1))
c_ = 10.0 * np.ones((m_con, 1))
d_ = np.zeros((m_con, 1))
xmma, *_, low, upp = mmasub(
m_con, n_var, loop, xval, xmin_, xmax_, xold1, xold2,
np.array([[obj_n]]), df0dx, fval, dfdx, low, upp,
a0, a_, c_, d_, maximize=True,
xnew = np.clip(xmma.ravel(), 0.001, 1.0)
xold2 = xold1.copy()
xold1 = xval.copy()
change = float(np.max(np.abs(xnew - x_design.x.array)))
x_design.x.array[:] = xnew
log(
f" It.:{loop:3d} Obj(f/f0):{float(obj_n):9.4f} "
f"Vol.:{cur_vol / total_vol:7.3f} ch.:{change:7.3f} "
f"f[Hz]:{freq:10.4f} ω:{omega:10.3f} "
f"mode#:{idx + 1} modal_mass:{den_modal:.3e} time:{time.time() - t0:6.2f}s"
if save_interval and (loop % save_interval == 0):
write_paraview(loop, freq)
# Release PETSc objects
Kfull.destroy()
Mfull.destroy()
Kf.destroy()
Mf.destroy()
eps_solver.destroy()
vr.destroy()
# 9. Output final structure
# Solve once more for the final mode shape using the final density
Kfull.assemble()
Mfull.assemble()
idx = objOrder - 1
if nconv > idx:
lam_obj = float(np.real(eps_solver.getEigenpair(idx, vr)))
final_phi = np.zeros(n_dofs, dtype=PETSc.ScalarType)
final_phi[free_dofs] = vr.getArray()
u_eig.x.array[:] = np.real(final_phi)
final_freq = np.sqrt(max(lam_obj, 1e-30)) / TWO_PI
final_freq = 0.0
log("[Warning] Final mode did not converge, only output final density.")
write_paraview(999, final_freq)
Kfull.destroy()
Mfull.destroy()
Kf.destroy()
Mf.destroy()
vr.destroy()
A_filt.destroy()
M_filt.destroy()
is_free.destroy()
log("========== Finished ==========")
log(f"Final file: {out_dir}/topopt3d_itermm_999.xdmf")
log("ParaView: File -> Open -> topopt3d_itermm_999.xdmf")
log("Recommended: density_cell -> Threshold (0.4~1.0); mode_shape -> Warp By Vector")
