Dear all,
I need to solve a nonlinear problem for a vector field \mathbf{p} that arises from minimising an energy that has terms that depend on the direction \hat{\mathbf{p}}= \mathbf{p}/|\mathbf{p}|. However, the solver never finishes (but also doesn’t complain of anything). The problem is coming from the normalisation, as I get a solution if I use \mathbf{p} instead of \hat{\mathbf{p}} in the energy. I guess there are points where |{\mathbf{p}}|=0. Any ideas on how to tackle this problem?
Here’s a MWE:
from dolfinx import fem, nls
from dolfinx.io import gmshio
model = gmsh.model; geom = gmsh.model.geo
mesh_comm = MPI.COMM_WORLD
def generateSphere3D(RR):
"""Create a Gmsh model of a sphere."""
gmsh.option.setNumber("General.Terminal", 0)
model.add("model_acorn")
sphere = model.occ.addSphere(0, 0, 0, RR, tag=1)
model.occ.synchronize()
model.add_physical_group(dim=3, tags=[sphere])
geom.synchronize()
model.mesh.generate(3)
return gmshio.model_to_mesh(model, mesh_comm, 0, gdim=3)
domain, _, _ = generateSphere3D(1)
#### define the space of funtions and the functions that we will use
element = ufl.VectorElement("CG", domain.ufl_cell(), 1, 3)
V = fem.FunctionSpace(domain, element) # space of vector functions with 3 components
m = fem.Function(V, name='m') # 3-dimensional vector OP
dm = ufl.TrialFunction(V) # variation of the OP
phi = ufl.TestFunction(V) # test function
#### derive the weak formulation directly from the energy functional
def ET(u):
# example energy
normu = ufl.sqrt(ufl.dot(u,u))
u1 = u/normu
fT = normu**2 * (ufl.div(u1))**2 + ufl.dot(ufl.grad(normu),ufl.grad(normu))
return fT*ufl.dx
F = ET(m)
dF = ufl.derivative(F, m, phi) # variation of the energy
JF = ufl.derivative(dF, m, dm) # Jacobian of the energy
#### define and solve the problem
problem = fem.petsc.NonlinearProblem(dF, m, J=JF)
def solveProblem(prob):
solver = nls.petsc.NewtonSolver(mesh_comm, prob)
solver.rtol = 1e-6
solver.max_it = 100
solver.report = True
minit = [1.,0,0] # initial guess for the unknown function
minit = ufl.as_vector([fem.Constant(domain, ScalarType(minit[0])),
fem.Constant(domain, ScalarType(minit[1])),
fem.Constant(domain, ScalarType(minit[2]))])
expr = fem.Expression(minit, V.element.interpolation_points())
m.interpolate(expr)
solver.nonzero_initial_guess = True
n, converged = solver.solve(m)
assert(converged)
solveProblem(problem)
