Hello, I want to use (P_1+RT0, P0) to solve the Stokes problem, which is
And what I’m wondering is how do I assemble
P_1+RT0.I’m using basix.ufl.enriched_element did not succeed.
File "/mnt/d/femcode/fem/Stokes_code/stokeseich.py", line 217, in <module>
enriched_element = basix.ufl.enriched_element(
...<2 lines>...
File "/home/zqaixj1234/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/basix/ufl.py", line 2091, in enriched_element
raise ValueError("Enriched elements on different map types not supported.")
ValueError: Enriched elements on different map types not supported.
ERROR conda.cli.main_run:execute(124): `conda run python /mnt/d/femcode/fem/Stokes_code/stokeseich.py` failed. (See above for error)
See the chart below for details
import matplotlib.pylab as plt
import basix.ufl
import dolfinx.fem.petsc
from dolfinx import fem, mesh
from ufl import (
SpatialCoordinate,
TestFunction,
TrialFunction,
as_vector,
cos,
div,
dx,
grad,
inner,
pi,
sin,
def u_ex(x):
sinx = sin(pi * x[0])
siny = sin(pi * x[1])
cosx = cos(pi * x[0])
cosy = cos(pi * x[1])
c_factor = 2 * pi * sinx * siny
return c_factor * as_vector((cosy * sinx, -cosx * siny))
def p_ex(x):
return sin(2 * pi * x[0]) * sin(2 * pi * x[1])
def source(x):
u, p = u_ex(x), p_ex(x)
return -div(grad(u)) + grad(p)
def create_bilinear_form(V, Q):
u, p = TrialFunction(V), TrialFunction(Q)
v, q = TestFunction(V), TestFunction(Q)
a_uu = inner(grad(u), grad(v)) * dx
a_up = inner(p, div(v)) * dx
a_pu = inner(div(u), q) * dx
return fem.form([[a_uu, a_up], [a_pu, None]])
def create_linear_form(V, Q):
domain = V.mesh
x = SpatialCoordinate(domain)
f = source(x)
return fem.form([inner(f, v) * dx, inner(fem.Constant(domain, 0.0), q) * dx])
def create_velocity_bc(V):
domain = V.mesh
g = fem.Constant(domain, [0.0, 0.0])
tdim = domain.topology.dim
domain.topology.create_connectivity(tdim - 1, tdim)
bdry_facets = mesh.exterior_facet_indices(domain.topology)
dofs = fem.locate_dofs_topological(V, tdim - 1, bdry_facets)
return [fem.dirichletbc(g, dofs, V)]
def create_nullspace(rhs_form):
null_vec = fem.petsc.create_vector_nest(rhs_form)
null_vecs = null_vec.getNestSubVecs()
null_vecs[0].set(0.0)
null_vecs[1].set(1.0)
null_vec.normalize()
nsp = PETSc.NullSpace().create(vectors=[null_vec])
return nsp
def create_preconditioner(Q, a, bcs):
p, q = TrialFunction(Q), TestFunction(Q)
a_p11 = fem.form(inner(p, q) * dx)
a_p = fem.form([[a[0][0], None], [None, a_p11]])
P = dolfinx.fem.petsc.assemble_matrix_nest(a_p, bcs)
P.assemble()
return P
def assemble_system(lhs_form, rhs_form, bcs):
A = fem.petsc.assemble_matrix_nest(lhs_form, bcs=bcs)
b = dolfinx.fem.petsc.assemble_vector_nest(rhs_form)
dolfinx.fem.petsc.apply_lifting_nest(b, lhs_form, bcs=bcs)
for b_sub in b.getNestSubVecs():
b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
spaces = fem.extract_function_spaces(rhs_form)
bcs0 = fem.bcs_by_block(spaces, bcs)
dolfinx.fem.petsc.set_bc_nest(b, bcs0)
return A, b
def create_block_solver(A, b, P, comm):
ksp = PETSc.KSP().create(comm)
ksp.setOperators(A, P)
ksp.setType("minres")
ksp.setTolerances(rtol=1e-9)
ksp.getPC().setType("fieldsplit")
ksp.getPC().setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
nested_IS = P.getNestISs()
ksp.getPC().setFieldSplitIS(("u", nested_IS[0][0]), ("p", nested_IS[0][1]))
# Set the preconditioners for each block
ksp_u, ksp_p = ksp.getPC().getFieldSplitSubKSP()
ksp_u.setType("preonly")
ksp_u.getPC().setType("gamg")
ksp_p.setType("preonly")
ksp_p.getPC().setType("jacobi")
# Monitor the convergence of the KSP
ksp.setFromOptions()
return ksp
def assemble_scalar(J, comm: MPI.Comm):
scalar_form = fem.form(J)
local_J = fem.assemble_scalar(scalar_form)
return comm.allreduce(local_J, op=MPI.SUM)
def compute_errors(u, p):
domain = u.function_space.mesh
error_u = u - u_ex(x)
H1_u = inner(error_u, error_u) * dx
H1_u += inner(grad(error_u), grad(error_u)) * dx
velocity_error = np.sqrt(assemble_scalar(H1_u, domain.comm))
error_p = -p - p_ex(x)
L2_p = fem.form(error_p * error_p * dx)
pressure_error = np.sqrt(assemble_scalar(L2_p, domain.comm))
return velocity_error, pressure_error
def solve_stokes(u_element, p_element, domain):
V = fem.functionspace(domain, u_element)
Q = fem.functionspace(domain, p_element)
lhs_form = create_bilinear_form(V, Q)
rhs_form = create_linear_form(V, Q)
bcs = create_velocity_bc(V)
nsp = create_nullspace(rhs_form)
A, b = assemble_system(lhs_form, rhs_form, bcs)
assert nsp.test(A)
A.setNullSpace(nsp)
P = create_preconditioner(Q, lhs_form, bcs)
ksp = create_block_solver(A, b, P, domain.comm)
u, p = fem.Function(V), fem.Function(Q)
w = PETSc.Vec().createNest([u.x.petsc_vec, p.x.petsc_vec])
ksp.solve(b, w)
assert ksp.getConvergedReason() > 0
u.x.scatter_forward()
p.x.scatter_forward()
return compute_errors(u, p)
def error_plot(element_u, element_p, convergence_u=None, convergence_p=None, refinements=5, N0=7):
hs = np.zeros(refinements)
u_errors = np.zeros(refinements)
p_errors = np.zeros(refinements)
comm = MPI.COMM_WORLD
for i in range(refinements):
N = N0 * 2**i
domain = mesh.create_unit_square(comm, N, N, mesh.CellType.triangle)
u_errors[i], p_errors[i] = solve_stokes(element_u, element_p, domain)
hs[i] = 1.0 / N
print(f"h: {hs[i]:.4e} Error: {u_errors[i]:.4e}")
legend = []
if convergence_u is not None:
y_value = u_errors[-1] * 1.4
plt.plot(
[hs[0], hs[-1]],
[y_value * (hs[0] / hs[-1]) ** convergence_u, y_value],
"k--",
legend.append(f"order {convergence_u}")
if convergence_p is not None:
y_value = p_errors[-1] * 1.4
plt.plot(
[hs[0], hs[-1]],
[y_value * (hs[0] / hs[-1]) ** convergence_p, y_value],
"k--",
legend.append(f"order {convergence_p}")
plt.plot(hs, u_errors, "bo-")
plt.plot(hs, p_errors, "ro-")
legend += [r"$H^1(\mathbf{u_h}-\mathbf{u}_{ex})$", r"$L^2(p_h-p_ex)$"]
plt.legend(legend)
plt.xscale("log")
plt.yscale("log")
plt.axis("equal")
plt.ylabel("Error in energy norm")
plt.xlabel("$h$")
plt.xlim(plt.xlim()[::-1])
plt.grid(True)
#分段恒压空间
# element_u = basix.ufl.element("Lagrange", "triangle", 1, shape=(2,))
# element_p = basix.ufl.element("DG", "triangle", 0)
# error_plot(element_u, element_p)
#P2-DG0
# element_u = basix.ufl.element("Lagrange", "triangle", 2, shape=(2,))
# error_plot(element_u, element_p, convergence_p=1)
#Crouzeix-Raviart
# element_u = basix.ufl.element("CR", "triangle", 1, shape=(2,))
# error_plot(element_u, element_p, 1)
#P1+RT0
basix.ufl.element("Lagrange", "triangle", 1),
basix.ufl.element("Raviart-Thomas", "triangle", 1),
element_u = basix.ufl.blocked_element(enriched_element, shape=(2,))
element_p = basix.ufl.element("DG", "triangle", 1)
error_plot(element_u, element_p, 2)
