class EQ_IPDG_Linear_Elliptic(AFEM_Base):
This is the EQ_IPDG_Linear_Elliptic problem class
def str(self):
return ‘EQ_IPDG_Linear_Elliptic’
def initialize(self):
self.alpha = Constant(30000.0)
self.mesh = self.Example.mesh
self.VErrorSpace = FunctionSpace(self.mesh, "DG", int(self.k + 2))
self.VecErrorSpace = VectorFunctionSpace(self.mesh, "DG", int(self.k + 1))
self.grad_error = Function(self.VecErrorSpace)
self.LocalSpace = FunctionSpace(self.mesh, "DG", 0)
V = FunctionSpace(self.mesh, "DG", self.k)
V_ = VectorFunctionSpace(self.mesh, "DG", self.k)
Space = V
while Space.dim() < self.MINIMUM_DOF:
for i in range(2):
markers = MeshFunction("bool", self.mesh, self.mesh.topology().dim())
for c in cells(self.mesh):
markers[c] = True
self.mesh = refine(self.mesh, markers)
Space = V
return None
def update(self):
# Update Solution Space
self.V = FunctionSpace(self.mesh, "DG", self.k)
self.V_ = VectorFunctionSpace(self.mesh, "DG", self.k)
self.SolutionSpace = FunctionSpace(self.mesh, "DG", self.k)
self.CURRENT_DOF = self.SolutionSpace.dim()
# Break Criteria
if (self.CURRENT_DOF > self.MAXIMUM_DOF) \
or (self.CURRENT_ERROR < self.MAXIMUM_ERROR):
return True
# Update Other Spaces
self.ScalarErrorSpace = FunctionSpace(self.mesh, "DG", int(self.k + 2))
self.VectorErrorSpace = VectorFunctionSpace(self.mesh, "DG", int(self.k + 1))
self.ScalarRHSSpace = FunctionSpace(self.mesh, "DG", int(self.k + 1))
self.VectorRHSSpace = VectorFunctionSpace(self.mesh, "DG", int(self.k + 1))
# Update Mesh Elements
#boundaries = FacetFunction('size_t', self.mesh)
#boundaries = MeshFunction('size_t', self.mesh)
boundaries = MeshFunction("size_t", self.mesh, self.mesh.topology().dim()-1, 0)
Gamma_D1 = DirichletBoundary_top()
Gamma_D1.mark(boundaries, 2)
Gamma_D2 = DirichletBoundary_bottom()
Gamma_D2.mark(boundaries, 4)
Gamma_N1 = NeumannBoundary_left()
Gamma_N1.mark(boundaries, 1)
Gamma_N2 = NeumannBoundary_right()
Gamma_N2.mark(boundaries, 3)
aa = interpolate(m(),self.LocalSpace)
self.alpha = Constant(self.alpha)
self.h_T = CellSize(self.mesh)
self.h_E = FacetArea(self.mesh)
self.h_T_avg = (self.h_T('+') + self.h_T('-'))/2.0
self.h_E_avg = (self.h_E('+') + self.h_E('-'))/2.0
self.n = FacetNormal(self.mesh)
return False
The code snippet above gives this error when executed
" self.h_T = self.CellSize(self.mesh)
AttributeError: ‘EQ_IPDG_Linear_Elliptic’ object has no attribute ‘CellSize’ "
