I am following the tutorial on mesh generation presented at Sorbonne this year.
When trying to plot the mesh defined in the beginning of the page,
import pyvista
nodes = np.array([[1., 0.], [2., 0.], [3., 2.], [1, 3]])
connectivity = np.array([[0, 1, 2], [0, 2, 3]])
c_el = ufl.Mesh(ufl.VectorElement("Lagrange", ufl.triangle, 1))
domain = dolfinx.mesh.create_mesh(MPI.COMM_SELF, connectivity, nodes, c_el)
def plot_mesh(mesh: dolfinx.mesh.Mesh):
plotter = pyvista.Plotter()
# ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.create_vtk_mesh(mesh))
ugrid = pyvista.UnstructuredGrid(*dolfinx.plot.vtk_mesh(mesh))
if mesh.geometry.cmap.degree > 1:
plotter.add_mesh(ugrid, style="points", color="b", point_size=10)
ugrid = ugrid.tessellate()
show_edges = False
show_edges = True
plotter.add_mesh(ugrid, show_edges=show_edges)
plotter.show_axes()
plotter.view_xy()
plotter.show()
plot_mesh(domain)
i get this error:
AttributeError: 'dolfinx.cpp.mesh.Geometry_float64' object has no attribute 'cmap'. Did you mean: 'cmaps'?
My fenicsx version is: 0.7.0 based on GIT commit: 2244eee852d6aa070a2bbbd76215ef78d84911e1 and i run it in a conda environment on linux.
I checked, and the current version of the dolfinx.mesh.Geometry
class does really not have this ‘cmap’ attribute. How can i make this code run?
Another remark: the definition of ugrid
in the code was broken. I replaced “create_vtk_mesh” with “vtk_mesh”.
