AttributeError: 'petsc4py.PETSc.Vec' object has no attribute '_cpp_object'
I switched to conda and installed fenicsx. However, orthonormalize is giving error of not compatible with input arguments. I am giving nullspace basis as list.
The MWE is:
# Create a mesh and a function space
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 8, 8)
V_l = dolfinx.fem.functionspace(mesh, basix.ufl.element(
    "CG", mesh.topology.cell_name(), 1, shape=(3, )))
# Create list of vectors for null space---------------------------------------------
index_map = V_l.dofmap.index_map
nullspace_basis = [dolfinx.la.create_petsc_vector(index_map, V_l.dofmap.index_map_bs) for i in range(3)]
with ExitStack() as stack:
    vec_local = [stack.enter_context(x.localForm()) for x in nullspace_basis]
    for i, local_array in enumerate(vec_local):
            np_array = np.asarray(local_array)
            dof_indices = V_l.sub(i).dofmap.list  # Get dof indices for x, y, z
            np_array[dof_indices] = 1.0  # Set relevant dofs to 1.0
dolfinx.la.orthonormalize(nullspace_basis)
Cell In[29], line 21
     18             dof_indices = V_l.sub(i).dofmap.list  # Get dof indices for x, y, z
     19             np_array[dof_indices] = 1.0  # Set relevant dofs to 1.0
---> 21 dolfinx.la.orthonormalize(nullspace_basis)
File ~/miniconda3/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/la.py:372, in orthonormalize(basis)
    370 def orthonormalize(basis: list[Vector]):
    371     """Orthogonalise set of PETSc vectors in-place."""
--> 372     _cpp.la.orthonormalize([x._cpp_object for x in basis])
File ~/miniconda3/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/la.py:372, in <listcomp>(.0)
I am stuck now and tried a lot by changing input, but it looks doflinx and petsc are incompatible. What should I make nullspace basis to make orthonormalize work.
Any help is greatly appreciated.
Are you sure you didn’t switch versions of DOLFINx during this transition?
It seems like you have hit the change in Re-order and edit (some) demos (Python) by garth-wells · Pull Request #2512 · FEniCS/dolfinx · GitHub
See updated api usage in dolfinx/python/demo/demo_elasticity.py at 1fbf7e1aa7ebc1315758589417db740e9fb5be5e · FEniCS/dolfinx · GitHub
