Error while trying to run finite strain FeFp plasticity tutorial
Hi! I am trying to run the finite strain FeFp plasticity tutorial, but I am getting some errors while running the script. I have installed FEniCSx (v.0.8) and Jax(v.0.5.2) using conda-forge.
JaxStackTraceBeforeTransformation         Traceback (most recent call last)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/runpy.py:198, in _run_module_as_main()
    197     sys.argv[0] = mod_spec.origin
--> 198 return _run_code(code, main_globals, None,
    199                  "__main__", mod_spec)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/runpy.py:88, in _run_code()
     81 run_globals.update(__name__ = mod_name,
     82                    __file__ = fname,
     83                    __cached__ = cached,
     86                    __package__ = pkg_name,
     87                    __spec__ = mod_spec)
---> 88 exec(code, run_globals)
     89 return run_globals
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/kernelapp.py:739, in start()
    738 try:
--> 739     self.io_loop.start()
    740 except KeyboardInterrupt:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/tornado/platform/asyncio.py:205, in start()
    204 def start(self) -> None:
--> 205     self.asyncio_loop.run_forever()
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/asyncio/base_events.py:683, in run_forever()
    682 while True:
--> 683     self._run_once()
    684     if self._stopping:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/asyncio/base_events.py:2040, in _run_once()
   2039     else:
-> 2040         handle._run()
   2041 handle = None
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/asyncio/events.py:89, in _run()
     88 try:
---> 89     self._context.run(self._callback, *self._args)
     90 except (SystemExit, KeyboardInterrupt):
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/kernelbase.py:545, in dispatch_queue()
    544 try:
--> 545     await self.process_one()
    546 except Exception:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/kernelbase.py:534, in process_one()
    533         return
--> 534 await dispatch(*args)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/kernelbase.py:437, in dispatch_shell()
    436     if inspect.isawaitable(result):
--> 437         await result
    438 except Exception:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/ipkernel.py:362, in execute_request()
    361 self._associate_new_top_level_threads_with(parent_header)
--> 362 await super().execute_request(stream, ident, parent)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/kernelbase.py:778, in execute_request()
    777 if inspect.isawaitable(reply_content):
--> 778     reply_content = await reply_content
    780 # Flush output before sending the reply.
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/ipkernel.py:449, in do_execute()
    448 if accepts_params["cell_id"]:
--> 449     res = shell.run_cell(
    450         code,
    451         store_history=store_history,
    452         silent=silent,
    453         cell_id=cell_id,
    454     )
    455 else:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/ipykernel/zmqshell.py:549, in run_cell()
    548 self._last_traceback = None
--> 549 return super().run_cell(*args, **kwargs)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:3077, in run_cell()
   3076 try:
-> 3077     result = self._run_cell(
   3078         raw_cell, store_history, silent, shell_futures, cell_id
   3079     )
   3080 finally:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:3132, in _run_cell()
   3131 try:
-> 3132     result = runner(coro)
   3133 except BaseException as e:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/async_helpers.py:128, in _pseudo_sync_runner()
    127 try:
--> 128     coro.send(None)
    129 except StopIteration as exc:
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:3336, in run_cell_async()
   3333 interactivity = "none" if silent else self.ast_node_interactivity
-> 3336 has_raised = await self.run_ast_nodes(code_ast.body, cell_name,
   3337        interactivity=interactivity, compiler=compiler, result=result)
   3339 self.last_execution_succeeded = not has_raised
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:3519, in run_ast_nodes()
   3518     asy = compare(code)
-> 3519 if await self.run_code(code, result, async_=asy):
   3520     return True
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:3579, in run_code()
   3578     else:
-> 3579         exec(code_obj, self.user_global_ns, self.user_ns)
   3580 finally:
   3581     # Reset our crash handler in place
Cell In[12], line 1
----> 1 get_ipython().run_line_magic('runfile', "'/disk6001/home/mq70fene/ppp-master/finite strain/bleyer/dolfinx_materials/demos/jax/finite_strain_elastoplasticity/finite_strain_elastoplasticity.py' --wdir")
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/IPython/core/interactiveshell.py:2482, in run_line_magic()
   2481 with self.builtin_trap:
-> 2482     result = fn(*args, **kwargs)
   2484 # The code below prevents the output from being displayed
   2485 # when using magics with decorator @output_can_be_silenced
   2486 # when the last Python token in the expression is a ';'.
File /disk6001/home/mq70fene/ppp-master/finite strain/bleyer/dolfinx_materials/demos/jax/finite_strain_elastoplasticity/finite_strain_elastoplasticity.py:165
    164 qmap.update_initial_state("be_bar", fem.Constant(domain, (1.0, 1.0, 1.0, 0, 0, 0)))
--> 165 qmap.update()
    167 # ## Resolution
    168 #
    169 # As in the MFront demo, we define the custom nonlinear problem, the corresponding Newton solver, the PETSc Krylov solver and its Geometric Algebraic MultiGrid preconditioner.
    170
    171 # +
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/quadrature_map.py:320, in update()
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/material/generic.py:179, in integrate()
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/material/jax/jax_material.py:13, in wrapper()
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/jax_materials/finite_strain_elastoplasticity.py:90, in constitutive_update()
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/material/jax/jax_newton_solver.py:145, in solve()
    144 tangent_solve = lambda g, y: _solve_linear_system(x, jax.jacfwd(g)(y), y)
--> 145 x_sol, data = jax.lax.custom_root(self.r, x, solve, tangent_solve, has_aux=True)
    147 # x_sol, data = newton_solve(x, self.r, self.dr_dx, self.params)
JaxStackTraceBeforeTransformation: TypeError: Custom JVP rule must produce primal and tangent outputs with corresponding shapes and dtypes, but got:
  primal int64[] with tangent int64[], expecting tangent ShapedArray(float0[])
The preceding stack trace is the source of the JAX operation that, once transformed by JAX, triggered the following exception.
The above exception was the direct cause of the following exception:
TypeError                                 Traceback (most recent call last)
    163 qmap.initialize_state()
    167 # ## Resolution
    168 #
    170
    171 # +
    172 problem = NonlinearMaterialProblem(qmap, Res, Jac, u, bcs)
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/quadrature_map.py:320, in QuadratureMap.update(self)
    317 Ct_vals = np.zeros_like(get_vals(self.jacobian_flatten)[self.dofs])
    319 # material integration
--> 320 flux_vals, isv_vals, Ct_vals = self.material.integrate(grad_vals)
    321 assert not (np.any(np.isnan(flux_vals)))
    322 assert not (np.any(np.isnan(isv_vals)))
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/material/generic.py:179, in Material.integrate(self, gradients, dt)
    176 def integrate(self, gradients, dt=0):
    177     vectorized_state = self.get_initial_state_dict()
--> 179     Ct_array, new_state = self.batched_constitutive_update(
    180         gradients, vectorized_state, dt
    181     )
    183     self.data_manager.s1.set_item(new_state)
    185     return (
    186         self.data_manager.s1.fluxes,
    187         self.data_manager.s1.internal_state_variables,
    188         Ct_array,
    189     )
    [... skipping hidden 20 frame]
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/material/jax/jax_material.py:13, in tangent_AD.<locals>.wrapper(self, *args)
     10 @wraps(constitutive_update_method)
     11 def wrapper(self, *args):
     12     constitutive_update_fun = partial(constitutive_update_method, self)
---> 13     return jax.jacfwd(constitutive_update_fun, argnums=0, has_aux=True)(*args)
    [... skipping hidden 15 frame]
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx_materials/jax_materials/finite_strain_elastoplasticity.py:90, in FeFpJ2Plasticity.constitutive_update(self, Fv, state, dt)
     88 x0 = jnp.zeros((7,))
     89 x0 = x0.at[:-1].set(to_vect(be_bar_trial, True))
---> 90 x, data = self.newton_solver.solve(x0)
     92 be_bar = to_mat(x[:-1])
     93 dp = x[-1]
    [... skipping hidden 31 frame]
File /disk6001/home/mq70fene/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/jax/_src/custom_derivatives.py:360, in _flatten_jvp(f, store, primal_name, jvp_name, in_tree, maybe_out_type, *args)
    353     msg = ("Custom JVP rule must produce primal and tangent outputs with "
    354            "corresponding shapes and dtypes, but got:\n{}")
    355     disagreements = (
    356         f"  primal {av_p.str_short()} with tangent {av_t.str_short()}, expecting tangent {av_et}"
    357         for av_p, av_et, av_t in zip(primal_avals_out, expected_tangent_avals_out, tangent_avals_out)
    358         if av_et != av_t)
--> 360     raise TypeError(msg.format('\n'.join(disagreements)))
    361 store.store((out_tree, primal_avals))
    362 return primals_out + tangents_out
Thanks for the help!
This is related to a JAX issue with recent versions. Try to revert to an older one <0.4.34
