Extracting mesh regions for gmsh mesh
Got it. For future simulation I need file XML, how I can get this file from XDMF then? I’ve thought that Dolfin can help me with this issue. And this code is created for this purpose.
And even if I use only XDMF type in code like this
#!/usr/bin/python
# -*- coding: utf-8 -*-
# Create mesh from XDMF file
mesh = Mesh()
    infile.read(mesh)
# Create a CellFunction to mark cell types
cell_markers = MeshFunction("size_t", mesh, 3)
# Iterate over cells and mark their types
for cell in cells(mesh):
    if CellType == "tetrahedron":
        cell_markers[cell] = 1  # tetrahedra are marked with value 1
    elif CellType == "triangle":
        cell_markers[cell] = 2  # triangles are marked with value 2
# Save cell information to XML file
with XDMFFile("cell_info.xml") as outfile:
    outfile.write(cell_markers)
# Create subdomain cell function for tetrahedra
mvc_tetra = MeshValueCollection("size_t", mesh, 3)
with XDMFFile("mes_20.xdmf") as infile:
    infile.read(mvc_tetra, "name_to_read")
subdomain_marker_tetra = cpp.mesh.MeshFunctionSizet(mesh, mvc_tetra)
# Save subdomain information to XML file
with XDMFFile("subdomain_info_tetra.xdmf") as outfile:
    outfile.write(subdomain_marker_tetra)
# Create boundary subdomain facet function for triangles
mvc_triangle = MeshValueCollection("size_t", mesh, 2)
with XDMFFile("mf_20.xdmf") as infile:
    infile.read(mvc_triangle, "name_to_read")
boundary_marker_triangle = cpp.mesh.MeshFunctionSizet(mesh, mvc_triangle)
# Save boundary information to XML file
with XDMFFile("boundary_info_triangle.xdmf") as outfile:
    outfile.write(boundary_marker_triangle)
I get this ERROR
  File "secondpartexam.py", line 27, in <module>
RuntimeError:
*** Error:   Unable to recognise cell type.
*** Reason:  Unknown value "".
*** Where:   This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** Git changeset:  unknown
Due to this message I realize that Dolfin cannot recognize cell type, but in my XDMF file cell’s type mention like tetra or triangle, however, this information saved as topology. Topology TopologyType=“Tetrahedron”
So, two questions:
  1. How I can get XML file if I have XDMF files?
  2. How help Dolfin recognize cell type if this information saved as topology?
Why? Anyhow, you then need to use the File class.
As you have not supplied your msh-file or xdmf-file or a reproducible example, I cannot do much else than point you to the resources I’ve already supplied.
Thank you for support. Could you say me where I can find information about File class?
This is my files xdmf
Files XDMF and MSH
And two questions more:
  • Using meshio.write I can create file XDMF from .msh file or I can create file .xml. Is it right?
  • Could I create one XML file which will contain the whole information about my mesh like domains, cell type etc. or I always have to create several files one of them contains information about facet, othet about domans and so on & so forth?
Hello, everyone. I have a question, during my study I have a problem like this
Assembling the weak form of operator 'Op1'...
Collecting data for assembler construction...
Data collection finished.
Precalculating singular integrals...
Precalculation of singular integrals took 12.1156 s
Assembly of the weak form of operator 'Op1' took 39.6848 s
Assembling the weak form of operator 'Op2'...
Assembly of the weak form of operator 'Op2' took 0.0617588 s
Calculating the (pseudo)inverse of operator 'Op2'...
Calculation of the (pseudo)inverse of operator 'Op2' took 0.0851854 s
Solving linear system of size 39585 x 39585 (PETSc Krylov solver).
  File "newtry.py", line 52, in <module>
    for i in range (300): llg.step(state, 2e-11)
  File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 151, in step
  File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 148, in step
  File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 134, in calculate_v
  File "/usr/local/lib/python2.7/dist-packages/magnumfe/integrators/llg_alouges_project.py", line 132, in calculate_v
  File "/usr/lib/python2.7/dist-packages/dolfin/fem/solving.py", line 279, in solve
    return cpp.la_solve(*args)
  File "/usr/lib/python2.7/dist-packages/dolfin/cpp/la.py", line 4279, in la_solve
    return _la.la_solve(*args)
RuntimeError:
***     fenics@fenicsproject.org
*** Error:   Unable to solve linear system using PETSc Krylov solver.
*** Reason:  Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = -nan).
*** Where:   This error was encountered inside PETScKrylovSolver.cpp.
*** Process: unknown
*** DOLFIN version: 1.5.0
Mesh file, XML and XDMF files
Could you explain me why it cannot solve linear system and how I can fix it? Thanks in advance.
Please create a separate post with a Minimal Reproducible example, as this is off-topic for the current thread.
