I would like to visualize the volume regions as labeled by GMSH. This is to verify that all material parameters are correctly applied. A simple toy problem illustrates what I am trying to do.
GMSH geo file:
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 3, 3, 1};
Box(2) = {0, 0, 1, 3, 3, 1};
Box(3) = {0, 0, 2, 3, 3, 1};
BooleanFragments{Volume{1,2,3}; Delete;}{};
Physical Volume("one", 1) = {1};
Physical Volume("two", 2) = {2};
Physical Volume("three", 3) = {3};
Mesh.Algorithm = 4;
Mesh.CharacteristicLengthMin = 0.5;
Each of three regions has a unique label.
Now I use Meshio to convert msh file to xdmf.
msh = meshio.read("TestVolumes.msh")
for cell in msh.cells:
if cell.type == "tetra":
tetra_cells = cell.data
if key == "tetra":
tetra_data = msh.cell_data_dict["gmsh:physical"][key]
tetra_mesh = meshio.Mesh(points=msh.points, cells={"tetra": tetra_cells},
cell_data={"VolumeRegions":[tetra_data]})
So far, so good. This runs without error. I now want to import the geometry into Fenics using
mesh = Mesh()
infile.read(mesh)
mvc = MeshValueCollection("size_t", mesh, 3)
info(mesh)
This runs without error, but when I use
File("VolSubDomains.pvd").write(cf)
File("Mesh.pvd").write(mesh)
I do not see the regions 1, 2 or 3 when I plot the resulting pvd files with Paraview. I only see the full mesh as one unified volume.
- What am I doing wrong?
- When building the variational form, is it enough to use dx(1), dx(2), dx(3), etc.?
