Hi I am installing FeniCS on windows 10. I downloaded Ubuntu and installed conda through Ubuntu. Once I open the jupyter notebook, I am trying this:
!conda config --add channels conda-forge
!conda install -c conda-forge/label/gcc7 mpmath -y (This process is completed)
!conda install fenics -y
When I do install fenics, I get this error
Solving environment: failed CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/pro/noarch/repodata.json.bz2 Elapsed: - An HTTP error occurred when trying to retrieve this URL. HTTP errors are often intermittent, and a simple retry will get you on your way. If your current network has https://www.anaconda.com blocked, please file a support request with your network engineering team. ConnectionError(MaxRetryError(“HTTPSConnectionPool(host=‘repo.anaconda.com’, port=443): Max retries exceeded with url: /pkgs/pro/noarch/repodata.json.bz2 (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7f45d02835c0>: Failed to establish a new connection: [Errno -2] Name or service not known’))”))
Before I was just trying to do the following and one of the post suggested adding “!conda install -c conda-forge/label/gcc7 mpmath -y” before installation of fenics:
and I was getting this error:
FileNotFoundError(2, “No such file or directory: ‘/home/fenics/anaconda3/bin/python3.8’”)
Attempting to roll back.
Rolling back transaction: done
Can anyone help with this and let me know what I am missing. I had followed this video to get to this point:
