Unable to install legacy fenics (2019.1.0) on Conda
I just switched to a new Mac and I am having trouble getting fenics (2019.1.0, I need to stick with this version for now) , I used the following command:
conda create -n fenicsproject -c conda-forge fenics
And I received this error:
Collecting package metadata (current_repodata.json): | DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): repo.anaconda.com:443
- DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/main/noarch/current_repodata.json HTTP/1.1" 304 0
DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/r/osx-arm64/current_repodata.json HTTP/1.1" 304 0
DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/r/noarch/current_repodata.json HTTP/1.1" 304 0
DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/main/osx-arm64/current_repodata.json HTTP/1.1" 304 0
done
Solving environment: unsuccessful attempt using repodata from current_repodata.json, retrying with next repodata source.
Collecting package metadata (repodata.json): \ DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): repo.anaconda.com:443
| DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/r/noarch/repodata.json HTTP/1.1" 304 0
/ DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/r/osx-arm64/repodata.json HTTP/1.1" 304 0
DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/main/osx-arm64/repodata.json HTTP/1.1" 304 0
DEBUG:urllib3.connectionpool:https://repo.anaconda.com:443 "GET /pkgs/main/noarch/repodata.json HTTP/1.1" 304 0
done
Solving environment: failed
PackagesNotFoundError: The following packages are not available from current channels:
  - fenics
Current channels:
  - https://conda.anaconda.org/conda-forge/osx-arm64
  - https://conda.anaconda.org/conda-forge/noarch
  - https://repo.anaconda.com/pkgs/main/osx-arm64
  - https://repo.anaconda.com/pkgs/main/noarch
  - https://repo.anaconda.com/pkgs/r/osx-arm64
  - https://repo.anaconda.com/pkgs/r/noarch
To search for alternate channels that may provide the conda package you're
looking for, navigate to
    https://anaconda.org
and use the search bar at the top of the page.
Does anyone know how to resolve this? I’d really appreciate your helps!
See: Fenics from Conda doesn't import - #16 by minrk
