Hi all! I am running a code to integrate a set of PDEs consisten of scalar fields on a spherical surface. One of the parameters, namely k10noise
in my code, is heterogeneous in space, and a valueError arises when computing its product with my variable u3. An MME is provided below:
import pygmsh
from tqdm import tqdm
from scipy.spatial.distance import cdist
from scipy.linalg import cholesky
from dolfinx import fem, io, default_real_type
from ufl import TestFunction, inner, dx, grad, split
def generate_noise(coordinates, correlation_length):
Generate a Gaussian correlated noise field on the surface of a sphere.
:param coordinates: Numpy array of spherical coordinates on the mesh.
:param correlation_length: Correlation length for the Gaussian noise.
:return: Interpolated noise field on the sphere.
# Calculate pairwise distances between points
distances = cdist(coordinates, coordinates)
# Exponential correlation function
noise_covariance = np.exp(-distances / correlation_length)
# Cholesky decomposition of the covariance matrix
try:
L = cholesky(noise_covariance, lower=True)
except np.linalg.LinAlgError:
# In case of numerical instability, fallback to regularization
L = cholesky(noise_covariance + 1e-10 * np.eye(len(coordinates)), lower=True)
# Generate uncorrelated Gaussian noise
rng = np.random.default_rng(42)
uncorrelated_noise = rng.standard_normal(coordinates.shape[0])
# Apply Cholesky decomposition to generate correlated noise
noise_values = L @ uncorrelated_noise
# Return the noise values
return noise_values
# Generate the spherical surface mesh with pygmsh
with pygmsh.geo.Geometry() as geom:
radius = 1.0 # Radius of the sphere
sphere = geom.add_ball([0, 0, 0], radius, mesh_size=0.035)
mesh = geom.generate_mesh(dim=2)
# Filter out mixed cells and retain only triangles
triangle_cells = mesh.cells_dict["triangle"]
mesh = meshio.Mesh(points=mesh.points, cells=[("triangle", triangle_cells)],)
meshio.write("SphericalSurfaceMesh.xdmf", mesh)
# Load the filtered mesh into FEniCSx
with io.XDMFFile(MPI.COMM_WORLD, "SphericalSurfaceMesh.xdmf", "r") as infile:
fenics_mesh = infile.read_mesh(name="Grid")
coordinates = fenics_mesh.geometry.x # Nodal coordinates
x, y, z = coordinates[:, 0], coordinates[:, 1], coordinates[:, 2]
# Parameters
cell_radius = 75
Du = fem.Constant(fenics_mesh, 0.08/(cell_radius**2))
Dv = fem.Constant(fenics_mesh, 0.4/(cell_radius**2))
Dw = fem.Constant(fenics_mesh, 0.001/(cell_radius**2))
k0 = fem.Constant(fenics_mesh, 0.00625)
k1 = fem.Constant(fenics_mesh, 0.3125)
k2 = fem.Constant(fenics_mesh, 1.)
k3 = fem.Constant(fenics_mesh, 0.0625)
k4 = fem.Constant(fenics_mesh, 0.05625)
k5 = fem.Constant(fenics_mesh, 0.0625)
k6 = fem.Constant(fenics_mesh, 0.02083)
k7 = fem.Constant(fenics_mesh, 0.001875)
k8 = fem.Constant(fenics_mesh, 0.140625)
k9 = fem.Constant(fenics_mesh, 0.25)
alpha = fem.Constant(fenics_mesh, 1.)
beta = fem.Constant(fenics_mesh, 0.3)
unit = fem.Constant(fenics_mesh, 1.)
noise_values = generate_noise(cell_radius*coordinates, 4)
k10noise = fem.Constant(fenics_mesh, 0.025) #No noise
k10noise = fem.Constant(fenics_mesh, 0.025*noise_values) #Noise
# Define the function space for the scalar fields in the mixed space
P1 = element("Lagrange", fenics_mesh.basix_cell(), 1, dtype=default_real_type)
ME = fem.functionspace(fenics_mesh, mixed_element([P1, P1, P1]))
u = fem.Function(ME) # Current solution
u_minus = fem.Function(ME) # Previous solution
v1, v2, v3 = TestFunction(ME) # Test functions
# Split mixed functions and assign initial conditions
u1, u2, u3 = split(u)
u1_minus, u2_minus, u3_minus = split(u_minus)
u.sub(0).interpolate(lambda x: 1 + 1.*(rng.random(x.shape[1]))-0.5)
u.sub(1).interpolate(lambda x: 1 + 1.*(rng.random(x.shape[1]))-0.5)
u.sub(2).interpolate(lambda x: 1 + 1.*(rng.random(x.shape[1]))-0.5)
u.x.scatter_forward()
u_minus.x.array[:] = u.x.array[:]
# Time-stepping parameters and data storage
iterations = 20000
dt = 0.025
samples = 100
u_values = np.empty([coordinates[:, 0].shape[0], samples])
# Define nonlinear functions
def f(u1, u2, u3, k0, k1, k2, k3, k4, alpha, beta):
return (k0+alpha*k1*np.pow(u1, 3)/(unit+k2*np.pow(u1, 2)))*u2-(k3+k4*(unit+beta)*u3)*u1
def g(u1, u2, u3, k0, k1, k2, k3, k4, k5, k6, alpha, beta):
return k5-k6*u2-((k0+alpha*k1*np.pow(u1, 3)/(unit+k2*np.pow(u1, 2)))*u2-(k3+k4*(unit+beta)*u3)*u1)
def h(u1, u2, u3, k7, k8, k9, k10noise):
return k7+k8*np.pow(u1, 2)/(unit+k9*np.pow(u1, 2))-k10noise*u3
# Construct the weak formulation
F1 = (inner(u1, v1) - inner(u1_minus, v1) + dt*Du*inner(grad(u1), grad(v1)) - dt*inner(f(u1, u2, u3, k0, k1, k2, k3, k4, alpha, beta), v1))*dx
F2 = (inner(u2, v2) - inner(u2_minus, v2) + dt*Dv*inner(grad(u2), grad(v2)) - dt*inner(g(u1, u2, u3, k0, k1, k2, k3, k4, k5, k6, alpha, beta), v2))*dx
F3 = (inner(u3, v3) - inner(u3_minus, v3) + dt*Dw*inner(grad(u3), grad(v3)) - dt*inner(h(u1, u2, u3, k7, k8, k9, k10noise), v3))*dx
F_total = F1 + F2 + F3
# Define the nonlinear problem
problem = NonlinearProblem(F_total, u)
# Configure the solver
solver.rtol = 1e-4
solver.report = True
# PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()
opts["ksp_type"] = "gmres"
opts["pc_type"] = "hypre"
opts["pc_hypre_type"] = "boomeramg"
opts["ksp_rtol"] = 1e-6
ksp.setFromOptions()
# Time-stepping loop
for it in tqdm(range(iterations)):
# Solve the nonlinear problem
n, converged = solver.solve(u) # Use u1 as the overall solution
if not converged:
raise RuntimeError(f"Newton solver did not converge at iteration {it}")
# Update previous solutions
if it%(iterations//samples) == 0:
u_values[:, int(it/(iterations//samples))] = u.sub(0).collapse().x.array[:]
np.save("u_values.npy", u_values)
Giving the following error:
File "/home/dlacasa/FEMSphere_CD.py", line 133, in <module>
File "/home/dlacasa/FEMSphere_CD.py", line 128, in h
File "/home/dlacasa/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/ufl/exproperators.py", line 231, in _sub
return Sum(self, -o)
File "/home/dlacasa/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/ufl/algebra.py", line 45, in __new__
raise ValueError("Can't add expressions with different shapes.")
ValueError: Can't add expressions with different shapes.
Thanks for your help!
