I am solving a system of ordinary differential equations. The dimension of the system is variable, and I need to be able to do high dimension (a few hundred). My code works when the dimension L is reasonably small, around 50. But if L is around 100 I get a segmentation fault error when compiling the TensorFunctionSpace. Below is a MWE.
import dolfin as df
L = 100
mesh = df.IntervalMesh(1000, 0, 1001)
TFS = df.TensorFunctionSpace(mesh, 'Lagrange', 1, shape=(L,L))
VFS = df.VectorFunctionSpace(mesh, 'Lagrange', 1, dim=L)
mat = np.random.rand(1001*L*L).reshape((1001, L, L))
mat_func = df.Function(TFS)
mat_func.vector()[:] = np.ravel(mat)
v = df.TestFunction(VFS)
u = df.TrialFunction(VFS)
LHS = (df.inner(df.grad(u), df.grad(v)) + df.dot(df.dot(mat_func, u), v) ) * df.dx
w = df.Function(VFS)
df.solve(LHS == 0, w)
mat is actually given by a numpy array. Below is the error.
/tmp/tmp1jko8lty/ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987.cpp: In member function 'virtual void ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987_finite_element_main::evaluate_basis_derivatives(std::size_t, std::size_t, double*, const double*, const double*, int, const ufc::coordinate_mapping*) const':
/tmp/tmp1jko8lty/ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987.cpp:1499402:0: note: -Wmisleading-indentation is disabled from this point onwards, since column-tracking was disabled due to the size of the code/headers
static const double coefficients0[2] = { 0.7071067811865475, 0.4082482904638631 };
/tmp/tmp1jko8lty/ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987.cpp: In function 'virtual void ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987_finite_element_main::evaluate_reference_basis_derivatives(double*, std::size_t, std::size_t, const double*) const':
/tmp/tmp1jko8lty/ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987.cpp:40145:6: internal compiler error: Segmentation fault
void ffc_element_0ea1b1872d8c05f63b973cf15ba23bec266f6987_finite_element_main::evaluate_reference_basis_derivatives(double * reference_values,
mmap: Cannot allocate memory
Any ideas for how to fix the above error? If not, then any ideas of ways to implement the matrix value assignment and multiplication without creating the TensorFunctionSpace? I will post the traceback below for reference as well.
DijitsoError Traceback (most recent call last)
/mnt/c/Users/leebs/Dropbox/MPL/infer-fenics-timetest.py in <module>
420
421 if __name__ == '__main__':
--> 422 main(sys.argv[1:])
423
424
/mnt/c/Users/leebs/Dropbox/MPL/infer-fenics-timetest.py in main(args)
281 print("time to define vector space:", vector_space_time - mesh_time)
282
--> 283 TFS = df.TensorFunctionSpace(mesh, 'Lagrange', 1, shape=(L,L)) # The tensor function space for the covariance matrix
284
285 if timed==2:
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/function/functionspace.py in TensorFunctionSpace(mesh, family, degree, shape, symmetry, constrained_domain, restriction)
232
233 # Return (Py)DOLFIN FunctionSpace
--> 234 return FunctionSpace(mesh, element, constrained_domain=constrained_domain)
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/function/functionspace.py in __init__(self, *args, **kwargs)
29 pass
30 elif len(args) == 2:
---> 31 self._init_from_ufl(*args, **kwargs)
32 else:
33 self._init_convenience(*args, **kwargs)
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/function/functionspace.py in _init_from_ufl(self, mesh, element, constrained_domain)
40
41 # Compile dofmap and element
---> 42 ufc_element, ufc_dofmap = ffc_jit(element, form_compiler_parameters=None,
43 mpi_comm=mesh.mpi_comm())
44 ufc_element = cpp.fem.make_ufc_finite_element(ufc_element)
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/jit/jit.py in mpi_jit(*args, **kwargs)
45 # Just call JIT compiler when running in serial
46 if MPI.size(mpi_comm) == 1:
---> 47 return local_jit(*args, **kwargs)
48
49 # Default status (0 == ok, 1 == fail)
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dolfin/jit/jit.py in ffc_jit(ufl_form, form_compiler_parameters)
95 p.update(dict(parameters["form_compiler"]))
96 p.update(form_compiler_parameters or {})
---> 97 return ffc.jit(ufl_form, parameters=p)
98
99
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/ffc/jitcompiler.py in jit(ufl_object, parameters, indirect)
215
216 # Inspect cache and generate+build if necessary
--> 217 module = jit_build(ufl_object, module_name, parameters)
218
219 # Raise exception on failure to build or import module
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/ffc/jitcompiler.py in jit_build(ufl_object, module_name, parameters)
128
129 # Carry out jit compilation, calling jit_generate only if needed
--> 130 module, signature = dijitso.jit(jitable=ufl_object,
131 name=module_name,
132 params=params,
~/miniconda3/envs/fenicsproject/lib/python3.8/site-packages/dijitso/jit.py in jit(jitable, name, params, generate, send, receive, wait)
214 if err_info:
215 # TODO: Parse output to find error(s) for better error messages
--> 216 raise DijitsoError("Dijitso JIT compilation failed, see '%s' for details"
217 % err_info['fail_dir'], err_info)
218
DijitsoError: Dijitso JIT compilation failed
