from basix.ufl import element
from dolfinx.fem import functionspace
from dolfinx import fem, io, mesh
from ufl import (Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
div, exp, inner)
from mesh_and_plot import create_nested_rectangles
# Time stepping parameters
num_steps = 100
dt = 1 / num_steps
max_iter = 10
tol = 1e-6
domain, markers = create_nested_rectangles()
# Physical constants
R = fem.Constant(domain, np.float64(287.05))
c_v = fem.Constant(domain, np.float64(718.0))
c_p = fem.Constant(domain, np.float64(1005.0))
mu = fem.Constant(domain, np.float64(1.81e-5))
kappa = fem.Constant(domain, np.float64(0.025))
# Create mesh
length = 0.4
height = 0.4
nx = 40
ny = 40
# Create mesh and markers using the previously defined function
# Define function spaces
# Create elements
P1_pressure = element("Lagrange", domain.basix_cell(), degree=1, dtype=dolfinx.default_real_type)
P1_velocity = element("Lagrange", domain.basix_cell(), degree=1, shape=(domain.geometry.dim,), dtype=dolfinx.default_real_type)
P1_temperature = element("Lagrange", domain.basix_cell(), degree=1, dtype=dolfinx.default_real_type)
V_u, V_p, V_T = functionspace(domain, P1_velocity), functionspace(domain, P1_pressure),functionspace(domain, P1_temperature)
V_fluid = mixed_element([P1_pressure, P1_velocity, P1_temperature])
V_fluid_fs=functionspace(domain,V_fluid)
p_init = fem.Function(V_p)
u_init = fem.Function(V_u)
T_init = fem.Function(V_T)
this is the code that defines function space and mixed element space, then I want to define an initial condition, for example, for p_init, such that when in a Circular Region( Definition:A circular region is defined with its center at (0.0, 0.2) and a radius of 0.06.This is determined by the equation: (x - center_x)^2 + (y - center_y)^2 < radius^2), the pressure in this circular region is high pressure (6,746,268.65 Pa),Outside the circle is the Low pressure (100,000 Pa), how to do this in latest version of dolfinx?
