How to get the solution obtained by fenics as a vector?
Please make a minimal example, as your original question is not clear on what kind of vector you would like to use. What you can do is to get each of the components of a VectorFunctionSpace by collapsing each of its components.
mesh = UnitSquareMesh(10, 10)
V = VectorFunctionSpace(mesh, "CG", 1)
u = Function(V)
u.interpolate(Expression(("3*x[0]", "2*x[1]"), degree=1))
num_dofs_per_component = int(V.dim()/V.num_sub_spaces())
num_sub_spaces = V.num_sub_spaces()
print(num_dofs_per_component, num_sub_spaces)
vector = np.zeros((num_sub_spaces, num_dofs_per_component))
for i in range(num_sub_spaces):
    vector[i] = u.sub(i, deepcopy=True).vector().get_local()
x = V.sub(0).collapse().tabulate_dof_coordinates()
vector = vector.T
for coord, vec in zip(x, vector):
    print(coord, vec)
