How to import tetgen data into dolfinx 0.7.2?
import sys
import os
sys.path.append(os.getcwd())
from dolfinx.fem import FunctionSpace, assemble_matrix
from dolfinx import mesh
from ufl import dx, grad, inner, TestFunction, TrialFunction
from ufl import Cell
import dolfinx.cpp
def read_node_file(filename):
    with open(filename, 'r') as f:
        num_nodes = int(f.readline().split()[0])
        nodes = np.empty((num_nodes, 3))
        for i in range(num_nodes):
            line = f.readline().split()
            nodes[i] = [float(x) for x in line[1:4]]
    return nodes
def read_ele_file(filename):
        num_elements = int(f.readline().split()[0])
        elements = np.empty((num_elements, 4), dtype=int)
        for i in range(num_elements):
            elements[i] = [int(x) for x in line[1:5]]
    return elements
def read_face_file(filename):
        num_faces = int(f.readline().split()[0])
        faces = np.empty((num_faces, 3), dtype=int)
        for i in range(num_faces):
            faces[i] = [int(x) for x in line[1:4]]
    return faces
def read_edge_file(filename):
        num_edges = int(f.readline().split()[0])
        edges = np.empty((num_edges, 2), dtype=int)
        for i in range(num_edges):
            edges[i] = [int(x) for x in line[1:3]]
    return edges
# Usage:
nodes = read_node_file('cylinder.1.node')
elements = read_ele_file('cylinder.1.ele')
faces = read_face_file('cylinder.1.face')
edges = read_edge_file('cylinder.1.edge')
print('nodes~~~')
print(nodes)
print('elements~~~')
print(elements)
print('faces~~~')
print(faces)
print('edges~~~')
print(edges)
A snapshot of the data looks like:
nodes~~~
[[ 4.99378471e+01  2.49229431e+00  1.00000000e+03]
 [ 4.97515373e+01  4.97839212e+00  1.00000000e+03]
 [ 4.94415398e+01  7.45211315e+00  1.00000000e+03]
 [ 4.90086250e+01  9.90730762e+00  0.00000000e+00]
 [ 4.84538651e+01  1.23378696e+01  1.00000000e+03]
 [ 4.84538651e+01  1.23378696e+01  0.00000000e+00]
 [ 2.91871834e+01  4.05969009e+01  1.00000000e+03]]
elements~~~
[[223  45  49  47]
 [  6 241   3   4]
 [128 173 124 166]
 [189 196 200   3]
 [ 28  35  27 243]
 [243  31  28  35]]
faces~~~
[[142 240   1]
 [  2 187 188]
 [188 142   1]
 [ 16 230  25]
 [230  40  25]
 [ 17  19  16]]
edges~~~
[[240 142]
 [141 142]]
I tried to create a dolfinx mesh from the data but I was not able to do it yet. Is there a way to compose a dolfinx mesh from the data set that was generated on cylinder.stl from tetgen?
Meshio supports converting the data.
However, if you want to read the data directly into dolfinx, i would suggest reading
http://jsdokken.com/FEniCS23-tutorial/src/mesh_generation.html
# Convert elements to zero-based indexing
elements = elements - 1
# Now create the mesh
c_el = ufl.Mesh(ufl.VectorElement("Lagrange", ufl.tetrahedron, 1))
domain = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, elements, nodes, c_el)
So I was able to get things through the system without an error like this. Not sure yet if that is 100% percent what is needed but it does seem to work so far.
It is possible to install version dolfinx 0.7.3? I installed dolfinx version 0.8 and the tutorial (tutorial does not work
I change the line
FiniteElement by finiteelement
but I have not found what is the change of
VectorElement
for this reason I would like to install dolfinx 0.7 version
See: What happened to VectorElement? - #2 by dokken
for updated syntax.
The tutorial is being updated, see:
