I have to solve steady-state heat flow problem with radiation boundary conditions. I begin by considering a simple 2D MWE in which there is a heat source with left and right facets of the domain imposed with radiation condition. However, the nonlinear solver converges to a uniform heat map which obviously does not satisfy the radiation condition -dT(x=0)/dx = dT(x=1)/dx = T^4. I would appreciate if experts here could help me out.
Below is a MWE evaluated in FEniCSx 0.5.0 installed through Conda:
import ufl, dolfinx, mpi4py, petsc4py, pyvista
# create a unit square geometry
mesh = dolfinx.mesh.create_unit_square(mpi4py.MPI.COMM_WORLD, 20, 20)
# tag mesh boundaries, https://jorgensd.github.io/dolfinx-tutorial/chapter3/robin_neumann_dirichlet.html
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
(2, lambda x: np.isclose(x[0], 1)),
(3, lambda x: np.isclose(x[1], 0)),
(4, lambda x: np.isclose(x[1], 1))]
fdim = mesh.topology.dim - 1
facets = dolfinx.mesh.locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_tag = dolfinx.mesh.meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
# define variational form
V = dolfinx.fem.FunctionSpace(mesh, ("CG", 2))
uh2 = dolfinx.fem.Function(V)
# source heat flux
Qs = dolfinx.fem.Constant(mesh, petsc4py.PETSc.ScalarType(1))
ds = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag)
F = ufl.inner(ufl.grad(uh2), ufl.grad(v))*ufl.dx - v*Qs*ufl.dx
# apply radiation boundary on left and right edges
F += (uh2**4 * v)*ds(1) + (uh2**4 * v)*ds(2)
# create nonlinear solver
# https://jorgensd.github.io/dolfinx-tutorial/chapter2/nonlinpoisson_code.html
problem = dolfinx.fem.petsc.NonlinearProblem(F, uh2)
solver = dolfinx.nls.petsc.NewtonSolver(mpi4py.MPI.COMM_WORLD, problem)
solver.rtol = 1e-6
solver.report = False
ksp = solver.krylov_solver
opts = petsc4py.PETSc.Options()
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "pardiso"
ksp.setFromOptions()
# dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
# dolfinx.log.set_log_level()
n, converged = solver.solve(uh2)
assert(converged)
# visualize result
u_topology, u_cell_types, u_geometry = dolfinx.plot.create_vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data["u"] = uh2.x.array.real
u_grid.set_active_scalars("u")
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=False)
u_plotter.view_xy()
if not pyvista.OFF_SCREEN:
u_plotter.show()
Thanks!
