Hey All,
I am trying to setup unaxial extension (z-axis) on an annulus generated with gmsh. I want to use incompressible Mooney-Rivlin or at least nearly-incompressible. I have been scouring the discussion board and found quite a few examples of people doing similar things (i.e. Neo-Hookean, Component Wise BCs, Mooney-Rivlin).
However, my current setup is causing errors on running:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I imagine my errors are occurring in either my FunctionSpace setup:
n.ufl_cell(), degree=2)
FE1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), degree=1)
state_space = fem.FunctionSpace(domain, VE2 * FE1)
V, _ = state_space.sub(0).collapse()
Or BCs:
base_dofs_z = fem.locate_dofs_topological((state_space.sub(0).sub(2), V), facet_tag.dim, facet_tag.find(1))
u0_bc = fem.Function(V)
u0 = lambda x: np.zeros_like(x, dtype=default_scalar_type)
u0_bc.interpolate(u0)
bc_base_z = fem.dirichletbc(u0_bc, base_dofs_z, state_space.sub(0).sub(2))
But I am unsure, thank you for your help. The full code is below. Sorry for the superfluous commenting, I am trying to learn how it all works.
# Setup
# += Imports
from dolfinx import mesh, fem, io, default_scalar_type
from numpy import linalg as LNG
import argparse
# += Parameters
MESH_DIM = 3
LEN_Z = 1
R0 = 1
R1 = 1.5
P = 1.5
def gen_annulus(test_name, test_type, test_order, refine_check):
# Initialise and begin geometry
gmsh.model.add(test_name)
# += Setup base of annulus, surface
innerCircle = gmsh.model.occ.addCircle(x=0, y=0, z=0, r=R0, tag=1)
outerCircle = gmsh.model.occ.addCircle(x=0, y=0, z=0, r=R1, tag=2)
innerCircleCurve = gmsh.model.occ.addCurveLoop([innerCircle], 1)
outerCircleCurve = gmsh.model.occ.addCurveLoop([outerCircle], 2)
baseSurface = gmsh.model.occ.addPlaneSurface(wireTags=[outerCircle, innerCircle], tag=1)
# += Synchronize and add physical group
basePhysicalGroup = gmsh.model.addPhysicalGroup(dim=2, tags=[baseSurface], tag=100, name="Annulus Base Surface")
gmsh.model.occ.synchronize()
# += Extrude from geometry
baseExtrusion = gmsh.model.occ.extrude(dimTags=[(2, baseSurface)], dx=0, dy=0, dz=LEN_Z)
# += Create Physical Group on volume
volumePhysicalGroup = gmsh.model.addPhysicalGroup(3, [baseExtrusion[1][1]], tag=1000, name="Internal Volume")
innerPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[3][1]], tag =101, name="Inner Surface")
outerPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[2][1]], tag =102, name="Outer Surface")
topPhysicalGroup = gmsh.model.addPhysicalGroup(2, [baseExtrusion[0][1]], tag =103, name="Annulus Top Surface")
# += Create Mesh
gmsh.model.mesh.generate(MESH_DIM)
if refine_check == "True":
gmsh.model.mesh.refine()
gmsh.model.mesh.setOrder(test_order)
# += Write File
gmsh.write("gmsh_msh/" + test_name + ".msh")
gmsh.finalize()
def main(test_name, test_type, test_order, refine_check):
# Mesh Generation
# gen_annulus(test_name, test_type, test_order, refine_check)
# Load Domain & Interpolation
# += Read .msh into domain for FEniCSx
# (1): File name .msh
# (2): Multiprocessing assignment
# (3): Rank of multiprocessing
# (4): Dimension of mesh
domain, _, facet_markers = io.gmshio.read_from_msh("gmsh_msh/" + test_name + ".msh", MPI.COMM_WORLD, 0, gdim=MESH_DIM)
# += Create Vector Element
# (1): Interpolation style
# (2): Cell from mesh domain
# (3): Degree of interpolation style
VE2 = ufl.VectorElement("Lagrange", domain.ufl_cell(), degree=2)
# += Create Function Space
# (1): Mesh domain space
# (2): Finite element setup
# += Find total Function Space which contains both interpolation schemes
# Collapse into just Geometric Space
# Determine Boundaries
fdim = MESH_DIM-1
# (1): Base
base_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[2], 0))
# (2): Top
top_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[2], LEN_Z))
# (3): Inner Cylinder Surface
def inner_bound(x):
return np.isclose(np.sqrt(x[0]**2+x[1]**2), R0)
inner_facets = mesh.locate_entities_boundary(domain, fdim, inner_bound)
# (4): Outer Cylinder Surface
def outer_bound(x):
return np.isclose(np.sqrt(x[0]**2+x[1]**2), R1)
outer_facets = mesh.locate_entities_boundary(domain, fdim, outer_bound)
# += Collate Marked boundaries
marked_facets = np.hstack([base_facets, top_facets, inner_facets, outer_facets])
# += Assign boundaries IDs
marked_values = np.hstack([
np.full_like(base_facets, 1),
np.full_like(top_facets, 2),
np.full_like(inner_facets, 3),
np.full_like(outer_facets, 4)
# += Sort and assign
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
# Boundary Conditions
# += Base Dirichlet BCs but broken per subspace
# (1): Interpolation space
# (2): Internal function to determine if on z = 0
# base_dofs_x = fem.locate_dofs_topological((state_space.sub(0), V.sub(0)), facet_tag.dim, facet_tag.find(1))
# base_dofs_y = fem.locate_dofs_topological((state_space.sub(0), V.sub(1)), facet_tag.dim, facet_tag.find(1))
# += Set Dirichlet BCs of (1) on (2)
# bc_base_x = fem.dirichletbc(default_scalar_type(0), base_dofs_x, (state_space.sub(0), V.sub(0)))
# bc_base_y = fem.dirichletbc(default_scalar_type(0), base_dofs_y, (state_space.sub(0), V.sub(1)))
# += Top Dirichlet BCs
top_dofs_z = fem.locate_dofs_topological((state_space.sub(0).sub(2), V), facet_tag.dim, facet_tag.find(2))
u1_bc = fem.Function(V)
u1 = lambda x: np.zeros_like(x, dtype=default_scalar_type)
u1_bc.interpolate(u1)
bc_top_z = fem.dirichletbc(u1_bc, top_dofs_z, state_space.sub(0).sub(2))
# bc_top_z = fem.dirichletbc(default_scalar_type(0.05), top_dofs_z, (state_space.sub(0), V.sub(2)))
# += Concatenate boundaries
bc = [bc_base_z, bc_top_z]
## FOR LATER
# # Pressure Setup
# # += Pressure expression, contribution of pressure at internal radius
# p = ufl.exp(('p*x[0]/R', 'p*x[1]/R'), R = R0)
# # += Pressure Space (decreasing order of interpolation by 1)
# pre_interp = fem.FunctionSpace(domain, ("Lagrange", test_order-1))
# pressure = fem.Function(pre_interp)
# # += Interpolate expression over points
# pre_expr = fem.Expression(p, pre_interp.element.interpolation_points())
# pressure.interpolate(pre_expr)
# Setup Parameteres for Variational Equation
# += Test and Trial Functions
state = fem.Function(state_space, name="state")
test_state = ufl.TestFunctions(state_space)
v, q = test_state
u, p = ufl.split(state)
# += Identity Tensor
I = ufl.variable(ufl.Identity(MESH_DIM))
# += Deformation Gradient Tensor
# F = ∂u/∂X + I
F = ufl.variable(I + ufl.grad(u))
# += Right Cauchy-Green Tensor
C = ufl.variable(F.T * F)
# += Invariants
# (1): λ1^2 + λ2^2 + λ3^2; tr(C)
# (3): λ1^2*λ2^2*λ3^2; det(C) = J^2
Ic = ufl.variable(ufl.tr(C))
# uniMod_Ic = ufl.variable(J**(-2/3) * Ic)
# (2): λ1^2*λ2^2 + λ2^2*λ3^2 + λ3^2*λ1^2; 0.5*[(tr(C)^2 - tr(C^2)]
IIc = ufl.variable((Ic**2 - ufl.inner(C,C))/2)
# uniMod_IIc = ufl.variable(J**(-4/3) * IIc)
J = ufl.variable(ufl.det(F))
# IIIc = ufl.variable(ufl.det(C))
# += Material Parameters
c1 = 2
c2 = 6
# kappa = 1
# += Mooney-Rivlin Strain Energy Density Function
# psi = c1 * (Ic - 3) + c2 *(IIc - 3) + kappa*(IIIc-1)**2
# Terms
gamma1 = ufl.diff(psi, Ic) + Ic * ufl.diff(psi, IIc)
gamma2 = -ufl.diff(psi, IIc)
# sPK_term1 = ufl.diff(psi, Ic) + ufl.diff(Ic, E) + ufl.diff(psi, IIc) + ufl.diff(IIc, E)
# sPK_term2 = ufl.diff(psi, Ic) + ufl.diff(Ic, E.T) + ufl.diff(psi, IIc) + ufl.diff(IIc, E.T)
# sPK = 0.5 (sPK_term1 + sPK_term2)
firstPK = F * 2 * ufl.diff(psi, C)
# += First Piola Stress
# piola = ufl.diff(psi, F)
firstPK = 2 * F * (gamma1*I + gamma2*C) + p * J * ufl.inv(F).T
# Setup Variational Problem Solver
# += Gaussian Quadrature
# += Domains of integration
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# += Residual Equation (Variational, for solving)
R = ufl.inner(ufl.grad(v), firstPK) * dx + q * (J - 1) * dx
# += Problem Setup and Solver
problem = NonlinearProblem(R, state, bc)
solver = NewtonSolver(domain.comm, problem)
# += Tolerances for convergence
solver.atol = 1e-8
solver.rtol = 1e-8
# += Convergence criteria
num_its, converged = solver.solve(state)
u_sol, p_sol = state.split()
if converged:
print(f"Converged in {num_its} iterations.")
print(f"Not converged after {num_its} iterations.")
# ParaView export
with io.VTXWriter(MPI.COMM_WORLD, test_name + ".bp", [u], engine="BP4") as vtx:
vtx.write(0.0)
# Main check for script operation.
# Will operate argparse to take values from terminal.
# Then runs main() program for script execution
if __name__ == '__main__':
# +==+ Intake Arguments
argparser = argparse.ArgumentParser("FEniCSz Program for Passive Annulus Inflation")
# += Name for file writing
argparser.add_argument("test_ID")
# += Type of generation, i.e. Tetrahedral or Hexagonal
argparser.add_argument("gen_type")
# += Order of generated mesh
argparser.add_argument("gen_order", type=int)
# += Refinement level
argparser.add_argument("refinement", type=bool)
# += Capture arguments and store accordingly
args = argparser.parse_args()
test_name = args.test_ID
test_type = args.gen_type
test_order = args.gen_order
refine_check = args.refinement
# +==+ Feed Main()
