Hello, I want to calculate the linear form L manually, which contains interpolated initial condition. I have faced some difficulties which related to integration, code:
import sympy as sym
mesh = Mesh('untitled.xml')
parameters["reorder_dofs_serial"] = False
plot(mesh)
initial_condition = Expression('5*x[0]', degree=2) #Constant(1)
u_1 = interpolate(initial_condition, V)
print('fenics interpolation:', u_1.vector().get_local())
L = u_1*v*dx
b = assemble(L)
print('fenics b vector:', b.get_local())
################## integration ####################
n, e = sym.symbols('n e')
#basis functions
phi_local0 = e
phi_local1 = n
phi_local2 = 1-e-n
#element 0, points 0, 4, 7
i = [0, 1]
j = [0.5, 1]
k = [0, 0.5]
detJacobian = abs(np.linalg.det(np.array([[1, i[0], i[1]], [1, j[0], j[1]], [1, k[0], k[1]]])))
b_new = sym.zeros(1, 1)
b_new = sym.integrate(u_1.vector().get_local()[0] * phi_local0 * detJacobian, (n, 0, 1-e), (e, 0, 1))
print('\nb vector (index 0):', b_new)
############################### dofs ###################################
gdim = mesh.geometry().dim()
print('\nDof:', V.dofmap().dofs())
dofmap = V.dofmap()
dofs = dofmap.dofs()
dofs_x = V.tabulate_dof_coordinates().reshape((-1, gdim))
x, y = [], []
#dof of point
for dof, dof_x in zip(dofs, dofs_x):
print('Point', dof, ':', dof_x)
x.append(dof_x[0]), y.append(dof_x[1])
untitled.xml
<?xml version="1.0" encoding="UTF-8"?>
<dolfin xmlns:dolfin="http://www.fenicsproject.org">
<mesh celltype="triangle" dim="2">
<vertices size="9">
<vertex index="0" x="0.0000000000000000e+00" y="1.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="1" x="0.0000000000000000e+00" y="-0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="2" x="1.0000000000000000e+00" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="3" x="1.0000000000000000e+00" y="1.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="4" x="4.9999999999869210e-01" y="1.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="5" x="1.0000000000000000e+00" y="5.0000000000205946e-01" z="0.0000000000000000e+00"/>
<vertex index="6" x="5.0000000000205946e-01" y="0.0000000000000000e+00" z="0.0000000000000000e+00"/>
<vertex index="7" x="0.0000000000000000e+00" y="4.9999999999869210e-01" z="0.0000000000000000e+00"/>
<vertex index="8" x="5.0000000000037581e-01" y="5.0000000000037570e-01" z="0.0000000000000000e+00"/>
</vertices>
<cells size="8">
<triangle index="0" v0="0" v1="4" v2="7"/>
<triangle index="1" v0="7" v1="4" v2="8"/>
<triangle index="2" v0="7" v1="8" v2="1"/>
<triangle index="3" v0="1" v1="8" v2="6"/>
<triangle index="4" v0="4" v1="3" v2="8"/>
<triangle index="5" v0="8" v1="3" v2="5"/>
<triangle index="6" v0="8" v1="5" v2="6"/>
<triangle index="7" v0="6" v1="5" v2="2"/>
</cells>
</mesh>
</dolfin>
After interpolating initial condition we get vector of this interpolated function on mesh. And in assembling vector b, b_new = sym.integrate(u_1.vector().get_local()[0] * phi_local0 * detJacobian, (n, 0, 1-e), (e, 0, 1)) what we need to integrate an vector, an element of the vector? I can’t figure out. Thanks for your help
