Issue on corners with dolfinx_mpc
Dear community,
I’m solving a 2D Stokes problem with a Brinkman-type penalization using FEniCSx and dolfinx_mpc.
The domain is the unit square [0,1]×[0,1] with fully periodic boundary conditions applied via multipoint constraints mpc. Velocity and pressure are both discretized with P1 elements, with a stabilization. The system is assembled using nested matrices and solved with a field-split preconditioner, following some topics posted on the forum previously (for example).
While periodicity works as expected on the edges, I’m encountering issues at the domain corners: the DOFs there seem not to be properly constrained, resulting in discontinuities or mismatches. I’ve implemented a third periodic constraint to handle the corners, but the issue persists. Any ideas on what might be going wrong or how to correctly handle corner DOFs with dolfinx_mpc?
Here I attached the full code, thank you in advance.
from dolfinx import fem, mesh
from dolfinx.fem import Function, functionspace, Constant, dirichletbc, form, assemble_scalar
from dolfinx.mesh import create_rectangle, CellType, DiagonalType, locate_entities_boundary, meshtags
from dolfinx_mpc import (MultiPointConstraint,
                         assemble_matrix, assemble_vector,
                         create_matrix_nest, create_vector_nest,
                         assemble_matrix_nest, assemble_vector_nest)
# --- Periodic MPC utility functions ---
def define_periodic_space_bcs(domain, Lx, Ly, f_space, dim, value):
    toll = 1e-6
    point_dof = fem.locate_dofs_geometrical(
        f_space, lambda x: np.isclose(x[0], 0.0, atol=toll) & np.isclose(x[1], 0.0, atol=toll)
    if dim == 1:
        return [dirichletbc(Constant(domain, PETSc.ScalarType(value)), point_dof, f_space)]
        return [dirichletbc(np.zeros(dim, dtype=PETSc.ScalarType), point_dof, f_space)]
def define_periodic_space(domain, Lx, Ly, f_space, bcs):
    toll = 1e-6
    mpc = MultiPointConstraint(f_space)
    def is_slave_x(x): return np.isclose(x[0], Lx, atol=toll)
    def is_master_x(x): return np.isclose(x[0], 0.0, atol=toll)
    def is_slave_y(x): return np.isclose(x[1], Ly, atol=toll)
    def is_master_y(x): return np.isclose(x[1], 0.0, atol=toll)
    def map_slave_x(x):
        out = x.copy()
        out[0] -= Lx
        idx_corner = np.logical_or(is_slave_y(x), is_master_y(x))
        out[:, idx_corner] = np.nan
        return out
    def map_slave_y(x):
        out = x.copy()
        out[1] -= Ly
        idx_corner = np.logical_or(is_slave_x(x), is_master_x(x))
        return out
    def map_corner(x):
        out = x.copy()
        idx = np.logical_and(is_slave_x(x), is_slave_y(x))
        out[:, ~idx] = np.nan
        out[0, idx] -= Lx
        out[1, idx] -= Ly
        return out
    tag_x, tag_y, tag_corner = 2, 3, 4
    facets_x = locate_entities_boundary(domain, fdim, is_slave_x)
    facets_y = locate_entities_boundary(domain, fdim, is_slave_y)
    mt_x = meshtags(domain, fdim, facets_x, np.full(len(facets_x), tag_x, dtype=np.int32))
    mt_y = meshtags(domain, fdim, facets_y, np.full(len(facets_y), tag_y, dtype=np.int32))
    mpc.create_periodic_constraint_topological(f_space, mt_x, tag_x, map_slave_x, bcs)
    mpc.create_periodic_constraint_topological(f_space, mt_y, tag_y, map_slave_y, bcs)
    facets_corner = locate_entities_boundary(domain, fdim,
                        lambda x: np.isclose(x[0], Lx, atol=toll) & np.isclose(x[1], Ly, atol=toll)
    mt_corner = meshtags(domain, fdim, facets_corner,
                        np.full(len(facets_corner), tag_corner, dtype=np.int32))
    mpc.create_periodic_constraint_topological(f_space, mt_corner, tag_corner, map_corner, bcs)
    mpc.finalize()
    return mpc
# --- Main execution ---
if __name__ == "__main__":
    # Create mesh
    Lx = Ly = 1.0
    n = 80
    domain = create_rectangle(MPI.COMM_WORLD, [[0.0, 0.0], [Lx, Ly]], [n, n], CellType.triangle)
    # Define function spaces
    V = functionspace(domain, ("Lagrange", 1, (2,)))
    Q = functionspace(domain, ("Lagrange", 1))
    # Periodic MPCs
    bcs_V = define_periodic_space_bcs(domain, Lx, Ly, V, 2, 0.0)
    bcs_Q = define_periodic_space_bcs(domain, Lx, Ly, Q, 1, 0.0)
    mpc_V = define_periodic_space(domain, Lx, Ly, V, bcs_V)
    mpc_Q = define_periodic_space(domain, Lx, Ly, Q, bcs_Q)
    # Trial and test functions
    p, q = ufl.TrialFunction(Q), ufl.TestFunction(Q)
    # Density and material interpolation
    rho = Function(functionspace(domain, ("DG", 0)))
    rho.interpolate(lambda x: np.where((x[0] - 0.5)**2 + (x[1] - 0.5)**2 < 0.2 ** 2, 1.0, 0.0))
    z_min, z_max = 0.0, 1e6
    qRAMP = 0.01
    zeta = z_max + (z_min - z_max) * (1 - rho) * (1 + qRAMP) / (1 - rho + qRAMP)
    dx = ufl.dx(domain)
    alpha_stab = 1.0 / 6.0
    # Bilinear forms
    a_uu = (ufl.inner(ufl.grad(u), ufl.grad(v)) + zeta * ufl.inner(u, v)) * dx
    a_up = -ufl.inner(ufl.grad(p), v) * dx
    a_pu = -ufl.inner(ufl.grad(q), u) * dx
    a_pp = -alpha_stab * ufl.CellDiameter(domain)**2 * ufl.inner(ufl.grad(p), ufl.grad(q)) * dx
    a = [[form(a_uu), form(a_up)], [form(a_pu), form(a_pp)]]
    # RHS for unit forcing in x-direction
    Lx_u = ufl.inner(ufl.as_vector([1.0, 0.0]), v) * dx
    Lp = Constant(domain, PETSc.ScalarType(0.0)) * q * dx
    L = [form(Lx_u), form(Lp)]
    # Assemble system matrix
    A = create_matrix_nest(a, [mpc_V, mpc_Q])
    A00 = A.getNestSubMatrix(0, 0)
    A01 = A.getNestSubMatrix(0, 1)
    A10 = A.getNestSubMatrix(1, 0)
    A11 = A.getNestSubMatrix(1, 1)
    assemble_matrix(a[0][0], (mpc_V, mpc_V), bcs=[], A=A00)
    assemble_matrix(a[0][1], (mpc_V, mpc_Q), bcs=[], A=A01)
    assemble_matrix(a[1][0], (mpc_Q, mpc_V), bcs=bcs_Q, A=A10)
    assemble_matrix(a[1][1], (mpc_Q, mpc_Q), bcs=bcs_Q, A=A11)
    for block in [A00, A01, A10, A11]:
        block.assemble()
    # Assemble RHS
    b = create_vector_nest(L, [mpc_V, mpc_Q])
    assemble_vector_nest(b, L, [mpc_V, mpc_Q])
    for b_sub in b.getNestSubVecs():
        b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    # Create preconditioner (block-diagonal)
    P = PETSc.Mat().createNest([[A00, None], [None, A11]])
    P.assemble()
    # Solve system
    x = b.copy()
    ksp = PETSc.KSP().create(domain.comm)
    ksp.setOperators(A, P)
    ksp.setType("fgmres")
    pc = ksp.getPC()
    pc.setType("fieldsplit")
    pc.setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
    nested_IS = P.getNestISs()
    pc.setFieldSplitIS(("u", nested_IS[0][0]), ("p", nested_IS[0][1]))
    ksp_u, ksp_p = pc.getFieldSplitSubKSP()
    ksp_u.setType("preonly")
    ksp_u.getPC().setType("hypre")
    ksp_u.getPC().setHYPREType("boomeramg")
    ksp_p.setType("preonly")
    ksp_p.getPC().setType("hypre")
    ksp_p.getPC().setHYPREType("boomeramg")
    ksp.setTolerances(rtol=1e-8, atol=1e-8)
    ksp.setFromOptions()
    ksp.solve(b, x)
    for x_sub in x.getNestSubVecs():
        x_sub.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
    # Extract velocity and pressure
    u_sol = Function(mpc_V.function_space)
    u_sol.x.petsc_vec.setArray(x.getNestSubVecs()[0].array)
    u_sol.x.scatter_forward()
    mpc_V.backsubstitution(u_sol)
    p_sol = Function(mpc_Q.function_space)
    p_sol.x.petsc_vec.setArray(x.getNestSubVecs()[1].array)
    p_sol.x.scatter_forward()
    mpc_Q.backsubstitution(p_sol)
    # Output
    with XDMFFile(domain.comm, "velocity.xdmf", "w") as xdmf_u:
        xdmf_u.write_mesh(domain)
        xdmf_u.write_function(u_sol)
    with XDMFFile(domain.comm, "pressure.xdmf", "w") as xdmf_p:
        xdmf_p.write_mesh(domain)
        xdmf_p.write_function(p_sol)
Hello @GiacomoSperoni97 , I think I might know the issue here. When trying to impose periodic boundary conditions onto a domain in \mathbb{R}^n, one has to be careful with the coinciding elements in all \mathbb{R}^i \subset \mathbb{R}^n \quad \forall i \in \{0,...,n-2\} . In your case, as it is a [0,1]x[0,1] domain, the vertices of such a domain, i.e., P(0,0), P(1,0), P(0,1) and P(1,1) need to be properly constrained. In your piece of code, I can see that you have imposed the multipoint constraint to the edges separately. I am not sure if the mpc.create_periodic_constraint_topological function can handle collisions of different calls when imposing a np.nan value during the mapping. To this end, I suggest to combine all those three calls in one (cleanest way in my opinion), or simply substract the corresponding vector during each sequential mapping as in 2D periodicity.
