Hello all,
The set of equations I’m simulating describe the time evolution of the 2 dimensional hydrogel gel subjected to the osmotic stress due to presence of the chemical ions inside. On the top of the gel, there exists a supernatant domain and chemical ions can move in or out of the gel due to diffusion as well as advection. The fluid flow in the supernatant domain (governed by Stokes equation) is coupled to the fluid flow in the gel domain(governed by Darcy’s flow) by flux continuity at the gel-supernatant domain boundary. The supernatant domain on top of the gel is flipped at the gel-supernatant boundary, such that the whole system can be simulated with one rectangular mesh describing both gel domain and supernatant domain.
I run the code in parallel on HPC cluster(with mpirun -np 2 python3 hydrogel_swelling.py). The code works fine for the mesh size 10x10 and 20x20 but for higher mesh sizes it hangs. I could still see the processes running but I think it fails to solve the equations even in the first iteration. Initially I thought it could be memory issue but I never got out of memory error and there seem to be plenty of memory remaining on the cluster node (only 5 GB utilized out of 256 GB) when checked with htop command.
I would really appreciate any insight or help. I have attached the code below along with the output before it hangs
code -
#importing required libraries
from ufl import tanh
from ufl import nabla_div
from ufl import exp
from time import perf_counter
from datetime import date
t1_start = perf_counter()
Tf = 1 #final time
dt = Constant(1e-7) #initial timestep
#constants
lambda_ = Constant(1.)
mu = Constant(1.)
epsilon_p = Constant(0.1)
chi = Constant(50.)
gamma = Constant(100.)
xi = Constant(1.)
zeta = Constant(100.)
Cudiff = Constant(10.)
Hdiff = Constant(10000.)
r = Constant(5.*pow(10., 5.))
phi0 = Constant(0.006)
phiac = Constant(0.003)
phiac_hcl = Constant(0.006)
phiac_hcl2 = Constant(0.006)
delta = Constant(2.)
alpha = Constant(1000.)
beta = Constant(1e-9)
ccn = Constant(-1.)
ccn_1 = Constant(0.)
ccn_2 = Constant(0.)
ccn_3 = Constant(0.)
ccn_4 = Constant(0.)
ccr = Constant(1.)
#defining the mesh
mesh = RectangleMesh(Point(0,0),Point(10,1),50,50)
P1 = FiniteElement('P', mesh.ufl_cell(), 1)
P2 = VectorElement('P', mesh.ufl_cell(), 2)
element = MixedElement([P2,P1,P1,P1,P1,P1,P1,P1,P2,P1])
V1 = FunctionSpace(mesh,'P',1)
V2 = VectorFunctionSpace(mesh,'P',2)
v1, v2, v3, v4, v5, v6, v7, v8, v9, v10 = TestFunctions(V)
un = Function(V)
un_1 = Function(V)
un_2 = Function(V)
un_3 = Function(V)
un_4 = Function(V)
du = TrialFunction(V)
dv = TrialFunction(V)
d = u.geometric_dimension()
#u1 = deformation
#u2 = pore pressure
#u3 = Free copper volume fraction in the gel
#u4 = Free acid volume fraction in the gel
#u5 = Bound copper volume fraction in the gel
#u6 = Bound acid volume fraction in the gel
#u7 = Free copper volume fraction in the supernatant domain
#u8 = Free acid volume fraction in the supernatant domain
#u9 = Flow velocity in the supernatant domain
#u10 = Pressure in the supernatant domain
#defining initial conditions
class InitialCondition(UserExpression):
def eval(self, values, x):
values[0] = 0.
values[1] = -x[1]
values[2] = 0.
values[3] = 0.
values[4] = 0.
values[5] = phiac
values[6] = 0.
values[7] = 0.
values[8] = (1/(2*1.7724))*exp(-(x[0]-5)*(x[0]-5)/4)*phiac_hcl2*0.5*(1-tanh(20*(x[1]-0.5)))
values[9] = 0.
values[10] = 0.
values[11] = 0.
def value_shape(self):
return(12,)
u0 = InitialCondition()
un = interpolate(u0,V)
u1, u2, u3, u4, u5, u6, u7, u8, u9, u10 = split(u); #splitting u
un1, un2, un3, un4, un5, un6, un7, un8, un9, un10 = split(un);
un_11, un_12, un_13, un_14, un_15, un_16, un_17, un_18, un_19, un_110 = split(un_1);
un_21, un_22, un_23, un_24, un_25, un_26, un_27, un_28, un_29, un_210 = split(un_2);
un_31, un_32, un_33, un_34, un_35, un_36, un_37, un_38, un_39, un_310 = split(un_3);
un_41, un_42, un_43, un_44, un_45, un_46, un_47, un_48, un_49, un_410 = split(un_4);
#defining bdf functions
def BDFparameters(nn, ccn, ccn_1, ccn_2, ccn_3, ccn_4, ccr):
if nn==0:
ccn.assign(Constant(-1.)); ccr.assign(Constant(1.)); ccn_1.assign(Constant(0.))
ccn_2.assign(Constant(0.)); ccn_3.assign(Constant(0.)); ccn_4.assign(Constant(0.))
elif nn==1:
ccn.assign(Constant(-4./3.)); ccr.assign(Constant(2./3.)); ccn_1.assign(Constant(1./3.))
elif nn==2:
ccn.assign(Constant(-18./11.)); ccr.assign(Constant(6./11.)); ccn_1.assign(Constant(9./11.))
ccn_2.assign(Constant(-2./11.)); ccn_3.assign(Constant(0.)); ccn_4.assign(Constant(0.))
elif nn==3:
ccn.assign(Constant(-48./25.)); ccr.assign(Constant(12./25.)); ccn_1.assign(Constant(36./25.))
ccn_2.assign(Constant(-16./25.)); ccn_3.assign(Constant(3./25.)); ccn_4.assign(Constant(0.))
ccn.assign(Constant(-300./137.)); ccr.assign(Constant(60./137.)); ccn_1.assign(Constant(300./137.))
ccn_2.assign(Constant(-200./137.)); ccn_3.assign(Constant(75./137.)); ccn_4.assign(Constant(-12./137.))
def BDFvariables(nn, u, un, un_1, un_2, un_3, un_4):
if nn==0:
un.assign(u)
elif nn==1:
un_1.assign(un); un.assign(u)
elif nn==2:
un_2.assign(un_1); un_1.assign(un); un.assign(u)
elif nn==3:
un_3.assign(un_2); un_2.assign(un_1); un_1.assign(un); un.assign(u)
un_4.assign(un_3); un_3.assign(un_2); un_2.assign(un_1); un_1.assign(un); un.assign(u)
def an1(uud):
return 1./2. *(1+tanh(pow(10,3)*uud))
#defining boundaries
boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
class BoundaryL(SubDomain):
return on_boundary and near(x[0], 0, DOLFIN_EPS)
bxL = BoundaryL()
bxL.mark(boundary_markers, 0)
class BoundaryR(SubDomain):
return on_boundary and near(x[0], 10, DOLFIN_EPS)
bxR = BoundaryR()
bxR.mark(boundary_markers, 2)
class BoundaryD(SubDomain):
return on_boundary and near(x[1], 0, DOLFIN_EPS)
bxD = BoundaryD()
bxD.mark(boundary_markers, 1)
class BoundaryU(SubDomain):
return on_boundary and near(x[1], 1, DOLFIN_EPS)
bxU = BoundaryU()
bxU.mark(boundary_markers, 3)
#defining stress and strain
def epsilon(u1):
return 0.5*(nabla_grad(u1) + nabla_grad(u1).T)
def sigma(u1):
return (lambda_*epsilon_p*nabla_div(u1) - u2 + chi*u6 + gamma*u5)*Identity(d) + 2*mu*epsilon_p*epsilon(u1)
#boundary values in the weak statement
T = Constant((0,0))
f = Constant((0,0))
g0 = Constant(0.)
g_p = Constant(0.)
g3 = -u9[1] - alpha*u3.dx(1).dx(1)
flux_copper = Constant(0.)
flux_acid = Constant(0.)
#boundary constants for pressure eq
flux_copper_sup = -xi*Cudiff/(delta)*dot(grad(u3),n)
flux_acid_sup = -xi*Hdiff/(delta)*dot(grad(u4),n)
#weak statement of the equations
F1 = inner(sigma(u1), epsilon(v1))*dx-dot(T,v1)*ds(0) - dot(T,v1)*ds(2) - dot(T,v1)*ds(3)
F2 = epsilon_p*inner((u1 + ccn*un1 + ccn_1*un_11 + ccn_2*un_21 + ccn_3*un_31 + ccn_4*un_41),grad(v2))*dx - dt*(ccr*g0*v2*ds(0) + ccr*g0*v2*ds(2) + ccr*g0*v2*ds(1) + ccr*g3*v2*ds(3) + ccr*inner(grad(u2),grad(v2))*dx - ccr*g_p*v2*ds(0) -ccr*g_p*v2*ds(1) - ccr*g_p*v2*ds(2))
F3 = (u3 + ccn*un3 + ccn_1*un_13 + ccn_2*un_23 + ccn_3*un_33 + ccn_4*un_43)*v3*dx + epsilon_p*inner((u1 + ccn*un1 + ccn_1*un_11 + ccn_2*un_21 + ccn_3*un_31 + ccn_4*un_41),grad(u3))*v3*dx + dt*(-ccr*inner(grad(u2),grad(u3))*v3*dx + ccr*xi*Cudiff*(inner(grad(u3),grad(v3)))*dx- ccr*r*u4*u5*v3*dx + ccr*r*u3*(phi0-2.*u5-u6)*an1(phi0-2.*u5-u6)*v3*dx - ccr*flux_copper*v3*ds(1) - ccr*flux_copper*v3*ds(0) - ccr*flux_copper*v3*ds(2))
F4 = (u4 + ccn*un4 + ccn_1*un_14 + ccn_2*un_24 + ccn_3*un_34 + ccn_4*un_44)*v4*dx + epsilon_p*inner((u1 + ccn*un1 + ccn_1*un_11 + ccn_2*un_21 + ccn_3*un_31 + ccn_4*un_41),grad(u4))*v4*dx + dt*(-ccr*inner(grad(u2),grad(u4))*v4*dx + ccr*xi*Hdiff*(inner(grad(u4),grad(v4)))*dx + ccr*r*u4*(phiac_hcl-u6)*v4*dx-ccr*flux_acid*v4*ds(1) - ccr*flux_acid*v4*ds(0) -ccr*flux_acid*v4*ds(2))
F5 = (u5 + ccn*un5 + ccn_1*un_15 + ccn_2*un_25 + ccn_3*un_35 + ccn_4*un_45)*v5*dx + dt*(ccr*r*u4*u5*v5*dx - ccr*r*u3*(phi0-2.*u5-u6)*an1(phi0-2.*u5-u6)*v5*dx)
F6 = (u6 + ccn*un6 + ccn_1*un_16 + ccn_2*un_26 + ccn_3*un_36 + ccn_4*un_46)*v6*dx - dt*(ccr*u4*(phiac_hcl-u6)*v6*dx)
F7 = (u7 + ccn*un7 + ccn_1*un_17 + ccn_2*un_27 + ccn_3*un_37 + ccn_4*un_47)*v7*dx + dt*(ccr*(zeta*Cudiff/delta*delta)*inner(grad(u7),grad(v7))*dx + ccr*inner(u9,grad(u7))*v7*dx - ccr*flux_copper*v7*ds(0) - ccr*flux_copper*v7*ds(1) - ccr*flux_copper*v7*ds(2) - ccr*flux_copper_sup*v7*ds(3))
F8 = (u8 + ccn*un8 + ccn_1*un_18 + ccn_2*un_28 + ccn_3*un_38 + ccn_4*un_48)*v8*dx + dt*(ccr*(zeta*Hdiff/delta*delta)*inner(grad(u8),grad(v8))*dx + ccr*inner(u9,grad(u8))*v8*dx - ccr*flux_acid*v8*ds(0) - ccr*flux_acid*v8*ds(1) - ccr*flux_acid*v8*ds(2) - ccr*flux_acid_sup*v8*ds(3))
F9 = beta*inner(grad(u9),grad(v9))*dx + u10*div(v9)*dx + div(u9)*v10*dx - inner(f,v9)*dx
F = F1 + F2 + F3 + F4 + F5 + F6 + F7 + F8 + F9
#creating a VTK file for visualization output
vtkfile_u1 = File('./deform.pvd')
vtkfile_u2 = File('./pressure.pvd')
vtkfile_u3 = File('./phi_o.pvd')
vtkfile_u4 = File('./phi_o_hcl.pvd')
vtkfile_u5 = File('./phi_b.pvd')
vtkfile_u6 = File('./phi_b_hcl.pvd')
vtkfile_u7 = File('./phi_a.pvd')
vtkfile_u8 = File('./phi_a_hcl.pvd')
vtkfile_u9 = File('./sol_vel.pvd')
vtkfile_u10 = File('./sol_pressure.pvd')
#Boundary conditions
noflux = Constant((0.,0.))
bc1 = DirichletBC(V.sub(0), Constant((0.,0.)),bxD)
bc5 = DirichletBC(V.sub(8), Constant((0.,0.)),bxR)
bc6 = DirichletBC(V.sub(8), Constant((0.,0.)),bxL)
bc7 = DirichletBC(V.sub(9), Constant(0.),bxD)
t = 0
nn = 0
J = derivative(F,u,dv)
reflection = as_tensor([[1,0],
[0,-1]])
#time integration
while t < Tf:
_un1,_un2,_un3,_un4,_un5,_un6,_un7,_un8,_un9,_un10 = un.split() # saving files
vtkfile_u1 << (_un1,t)
vtkfile_u2 << (_un2,t)
vtkfile_u3 << (_un3,t)
vtkfile_u4 << (_un4,t)
vtkfile_u5 << (_un5,t)
vtkfile_u6 << (_un6,t)
vtkfile_u7 << (_un7,t)
vtkfile_u8 << (_un8,t)
vtkfile_u9 << (_un9,t)
vtkfile_u10 << (_un10,t)
t += float(dt)
#continuity in the copper concentration as DirichletBC
class Copper_cont(UserExpression):
def eval(self,values,x):
values[:] = u[7](x)
copper_cont = Copper_cont()
bc2 = DirichletBC(V.sub(2),copper_cont,bxU)
#continuity in the acid concentration as DirichletBC
class Acid_cont(UserExpression):
values[:] = u[8](x)
acid_cont = Acid_cont()
bc3 = DirichletBC(V.sub(3),acid_cont,bxU)
#Osmotic pressure
u3_der = project(u[3].dx(1),V1,solver_type="cg")
class Osmotic_p(UserExpression):
values[:] = -alpha*u3_der(x)
osmotic_p = Osmotic_p()
bc4 = DirichletBC(V.sub(1),osmotic_p,bxU)
#velocity continuity at the gel boundary
vel_flip = reflection*(-grad(u2) + epsilon_p*((u1 + ccn*un1 + ccn_1*un_11 + ccn_2*un_21 + ccn_3*un_31 + ccn_4*un_41)/(dt*ccr)))
rel_vel = project(vel_flip ,V2,solver_type="cg")
class Solvent_vel(UserExpression):
values[:] = rel_vel(x)
return(2,)
solvent_vel = Solvent_vel()
bc8 = DirichletBC(V.sub(8), solvent_vel, bxU)
bcs = [bc1,bc2,bc3,bc4,bc5,bc6,bc7,bc8]
problem = NonlinearVariationalProblem(F,u,bcs,J=J)
prm = solver.parameters
prm['nonlinear_solver']='newton'
prm["newton_solver"]["absolute_tolerance"]= 1e-7
prm["newton_solver"]["relative_tolerance"] = 1e-6
prm["newton_solver"]["maximum_iterations"] = 25
prm['newton_solver']['relaxation_parameter'] = 1.0
prm["newton_solver"]["error_on_nonconvergence"]=True
prm['newton_solver']['linear_solver'] = 'superlu_dist'
solver.solve()
nn += 1
t1_end = perf_counter()
print(f"Total runtime in seconds =", t1_end-t1_start)
The output -
Process 0: Solving nonlinear variational problem.
Process 1: Solving nonlinear variational problem.
/home/chinobangs/.conda/envs/fenicsproject/lib/python3.9/site-packages/ufl/exproperators.py:336: FutureWarning: elementwise comparison failed; returning scalar instead, but in the future will perform elementwise comparison
if arg in ("+", "-"):
