Linear Equation from FFC generated from variational formulation
Hi FEniCS family,
I am working on on the following variational statement taken from
https://comet-fenics.readthedocs.io/en/latest/demo/periodic_homog_elas/periodic_homog_elas.html
Ve = VectorElement("CG", mesh.ufl_cell(), 2)
Re = VectorElement("R", mesh.ufl_cell(), 0)
W = FunctionSpace(mesh, MixedElement([Ve, Re]), constrained_domain=PeriodicBoundary(vertices, tolerance=1e-10))
V = FunctionSpace(mesh, Ve)
v_,lamb_ = TestFunctions(W)
dv, dlamb = TrialFunctions(W)
w = Function(W)
dx = Measure('dx')(subdomain_data=subdomains)
Eps = Constant(((0, 0), (0, 0)))
F = sum([inner(sigma(dv, i, Eps), eps(v_))*dx(i) for i in range(nphases)])
a, L = lhs(F), rhs(F)
a += dot(lamb_,dv)*dx + dot(dlamb,v_)*dx
For the variational statement a, L = lhs(F), rhs(F), the FEniCS find a linear equation (using FFC ) and after solve (a==L,w,[]) give output of fluctuation function, w for each node.
I wanted to find the linear system of equation generated by FEniCS (like Ax=b, with x=w being the fluctuation function). I want to use coefficient matrix A for my post processing.
I know that, FFC forms a C++ code from symbolic variational statement, and after solution gives back, function w in python format. So, there must be some linear equation which is generated to solve the variational form (a==L). Kindly tell me, how I can get access to the linear system of equation (coeff matrix, A being assembled over all elements of mesh, through guassian quadrature) and interpret it for usage.
Any help is greatly appreciated.
Try
A = assemble(a)
Thanks @dokken for your response.
I am getting as object type A, and I am not able to use or extract any information from A.
A=assemble(a)
print(A)
<dolfin.cpp.la.Matrix object at 0x7ff36b8cc950>
Also, for general view, when we got this hexadecimal location. How can we get the object data/ value?
Following Transform dolfinx assemble matrix to numpy array - #11 by Samuel_Groth, but adapted to legacy DOLFIN, I would do something along the lines of
from scipy.sparse import csr_matrix
ai, aj, av = as_backend_type(A).mat().getValuesCSR()
Asp = csr_matrix((av, aj, ai))
to get a SCIPY CSR matrix.
A=assemble(a)
Asp
<19851x19851 sparse matrix of type '<class 'numpy.float64'>
	with 535905 stored elements in Compressed Sparse Row format>
Can you tell me little more about ai,aj,av. I read about csr_matrix(data,(row,column)) and I was trying to relate with ai, aj and av based on their size.
len(ai)
19852
len(aj)
535905
len(av)
535905
Asp = csr_matrix((av, aj, ai)).toarray()
# giving Asp as matrix of size 19851 X 19851
But, I am getting difficulty of what they try to interpret. I tried with mesh data.
mesh.num_vertices()
6771
mesh.num_cells()
13232
Can you tell me how Asp is interpreted with respect to form a (bilinear variation form used in Assemble(a))?
Also, in as_backend_type, Does Asp gives coefficent matrix (K) from Kx=f (say in general with x as fluctuation function to be evaluated) ?
and can we evaluate the vector f, since, as_backend_type also return a vector.
Thanks for your help.
Please read the scipy docs: scipy.sparse.csr_matrix โ€” SciPy v1.11.4 Manual
You are using a second order Lagrange space, with the addition of a real space dof. You cannot relate those to mesh entities.
b =assemble(L).get_local()
x = w.vector().get_local()
aligns as Ax=b.
Note that his would only work in serial, as numpy/scipy based matrices do not have parallel support (as in being distributed).
Thanks @dokken for your response. It helped me to identify the linear system.
The Asp (coefficient matrix) formed is of very large size even with linear elements.
A=assemble(a)
# Asp: 19851x19851 sparse matrix of type '<class 'numpy.float64'>
	#with 535905 stored elements in Compressed Sparse Row format>
Is there any suitable method/ function in FEniCS to invert Asp (coefficient) matrix efficiently and accurately ? (Mainly the numerical method)
I tried the following:
from scipy.sparse import csc_matrix
from scipy.sparse.linalg import inv
A = csc_matrix(Asp)
inv(A)
But, it crashes the kernel
The whole point of using dolfin is that it invert this matrix (using petsc), and gives you a solution to the problem. You will never want to store the actual inverse, as this is a dense system
if you use a direct solver (LUSolver), one can store the LU factorization, which makes the solve step quick. See for instance: https://fenicsproject.org/qa/6045/repeated-use-of-matrix-with-lu-decomposition/
https://fenicsproject.org/pub/tutorial/html/._ftut1017.html
Thanks @dokken for your response. I have few doubts:
  1. The linear system which FFC gives is of form Aw=b, where FFC performs some calculation to get A^{-1} to solve for
    w=A^{-1}b.
    Is there any way to work on FFC code / PETSc solver to get that A^{-1} ?
  2. Can I know the intermediate linear form which comes just after minimization of variational statement (a), which later FFC convert to Aw=b form.
For example : \int \:\sigma(w)\:\ grad(v)\:dvol \: where
w : trial function (fluctuation function), v: test function, dvol: volume
gives the minimization output of U\:w\:=\:P\:\epsilon ....(1) analytically, where epsilon is given macro-strain [6X1] vector given as Eps.
[in periodic homogenization code (FEniCs example)].
However, the output given by FFC through sparse csr is
A w =b;
instead of initial U\:w\:=\:P\:\epsilon , where
U= A and P \epsilon=b
How can I get the intermediate term P ?
Can we know the form generated by FFC eqn โ€ฆ(1) instead of direct A w =b ?
Any help is appreciated.
Lets make some things clear here:
  1. FFC does not create the in inverse. FFC takes a ufl form, and generates code for integrating over a cell/facet to return the local tensor (scalar, vector, matrix) for a single cell/facet.
  2. A= assemble(a) generates the sparse matrix by calling the kernels from step 1 for all cells/facets specified in the form.
  3. this matrix is sent to a linear algebra backend, such as PETSc, that uses a direct or iterative solver to get the solution to the problem Ax=b. At no point is the inverse matrix actually formed. See: KSP: Linear System Solvers โ€” PETSc 3.20.1 documentation
    For instance it states
To solve a linear system with a direct solver (currently supported by PETSc for sequential matrices, and by several external solvers through PETSc interfaces, see Using External Linear Solvers) one may use the options -ksp_type preonly (or the equivalent -ksp_type none) -pc_type lu (see below).
For instance you can use the LU factorizer UMFPACK (MATSOLVERUMFPACK โ€” PETSc 3.20.1 documentation) or mumps (MATSOLVERMUMPS โ€” PETSc 3.20.1 documentation)
An LU factorization never forms the full inverse, see: LU decomposition - Wikipedia
I am facing problem with integrating float type tensor over all the cells.
Em = 50e3
num = 0.2
Er = 210e3
nur = 0.3
material_parameters = [(Em, num), (Er, nur)]
nphases = len(material_parameters)
def Com(i):
    E, nu = material_parameters[i]
    lmbda = E*nu/(1+nu)/(1-2*nu)
    mu = E/2/(1+nu)
    C1=lmbda+2*mu
    return Constant([(C1,lmbda,lmbda,0,0,0),(lmbda,C1,lmbda,0,0,0),(lmbda,lmbda,C1,0,0,0),(0,0,0,mu,0,0),(0,0,0,0,mu,0),(0,0,0,0,0,mu)])
D= np.zeros((6,6))
for j in range(6):
    for k in range(6):
       D[j,k]= assemble(sum([(Com(i)[j,k])*dx(i) for i in range(nphases)]))/vol
This integral is missing an integration domain.
UFLException                              Traceback (most recent call last)
/tmp/ipykernel_455/2734975225.py in <module>
      2 for j in range(6):
      3     for k in range(6):
----> 4        D[j,k]= assemble(sum([(Com(i)[j,k])*dx(i) for i in range(nphases)]))/vol
/tmp/ipykernel_455/2734975225.py in <listcomp>(.0)
/usr/lib/python3/dist-packages/ufl/measure.py in __rmul__(self, integrand)
    430                 domain, = domains
    431             elif len(domains) == 0:
--> 432                 error("This integral is missing an integration domain.")
    433             else:
    434                 error("Multiple domains found, making the choice of integration domain ambiguous.")
/usr/lib/python3/dist-packages/ufl/log.py in error(self, *message)
    156         "Write error message and raise an exception."
    157         self._log.error(*message)
--> 158         raise self._exception_type(self._format_raw(*message))
    159
    160     def begin(self, *message):
UFLException: This integral is missing an integration domain.
Can you help me to compute the assemble command ?
I am getting error with multiple attempts like changing Com function
return as_tensor([(C1,lmbda,lmbda,0,0,0),(lmbda,C1,lmbda,0,0,0),(lmbda,lmbda,C1,0,0,0),(0,0,0,mu,0,0),(0,0,0,0,mu,0),(0,0,0,0,0,mu)])
or
return ([(C1,lmbda,lmbda,0,0,0),(lmbda,C1,lmbda,0,0,0),(lmbda,lmbda,C1,0,0,0),(0,0,0,mu,0,0),(0,0,0,0,mu,0),(0,0,0,0,0,mu)])
The code you have posted is not complete, as you have not defined dx and it is unclear what dx(i) is supposed to represent.
Please see:Read before posting: How do I get my question answered? - #4 by nate for examples following the forum guidelines
dx is taken from the above step and subdomain is similar to the periodic homogenization example.
%matplotlib notebook
a = 1.         # unit cell width
b = sqrt(3.)/2. # unit cell height
c = 0.5        # horizontal offset of top boundary
R = 0.2        # inclusion radius
vol = a*b      # unit cell volume
# we define the unit cell vertices coordinates for later use
vertices = np.array([[0, 0.],
                     [a, 0.],
                     [a+c, b],
                     [c, b]])
fname = "hexag_incl"
mesh = Mesh(fname + ".xml")
subdomains = MeshFunction("size_t", mesh, fname + "_physical_region.xml")
facets = MeshFunction("size_t", mesh, fname + "_facet_region.xml")
plt.figure()
plot(subdomains)
I apologize for the incomplete step.
Then change
To
dx = Measure('dx')(domain=mesh, subdomain_data=subdomains)
