Meshconnectivity
How can use mesh connectivity in the following code?
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
msh = meshio.read("ji-brace-2011.msh")
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh=Mesh()
   infile.read(mesh)
geo file is
am = 0.00003;
lm = 0.005;
wp = 0.01;
ds = 0.05;
Point(1) = {0, -0.013, 0, am};
Point(2) = {0.000255, -0.013, 0, am};
Point(3) = {0.000255, wp, 0, am};
Point(4) = {0.00084, wp, 0, am};
Point(5) = {0.00084, 0, 0, am};
Point(6) = {0.0011, 0, 0, am};
Point(7) = {0.0011, ds, 0, lm};
Point(8) = {0.05, ds, 0, lm};
Point(9) = {0.05, -ds, 0, lm};
Point(10) = {0, -ds, 0, lm};
Point(11) = {0.000255, 0, 0, am};
Line(1) = {1, 2};
Line(2) = {2, 11};
Line(3) = {11, 3};
Line(4) = {3, 4};
Line(5) = {4, 5};
Line(6) = {5, 11};
Line(7) = {5, 6};
Line(8) = {6, 7};
Line(9) = {7, 8};
Line(10) = {8, 9};
Line(11) = {9, 10};
Line(12) = {10, 1};
Line Loop(13) = {12, 1, 2, -6, 7, 8, 9, 10, 11};
Plane Surface(14) = {13};
Line Loop(15) = {3, 4, 5, 6};
Plane Surface(16) = {15};
Physical Line(1) = {12};
Physical Line(2) = {9, 10, 11};
Physical Line(4) = {4};
Physical Line(5) = {9, 10, 11};
Physical Surface(2) = {16};
Physical Surface(1) = {14};
You need to be more specific. What kind of mesh connectivity do you want, and what would you like to use it for?
There are already posts regarding how to initialize mesh connectivity in the forum, see for instance:
or
