Hello, FEniCS community,
I am encountering an issue when trying to read a MeshFunction from an XDMF file in FEniCS 2019.1.0. The error message indicates a “Mismatched number of entities” inside XDMFFile.cpp.
Here’s a brief overview of my setup:
- I created the mesh and physical groups using GMSH and exported them to XDMF files.
- I’m trying to tag facets for boundary conditions on a 3D domain.
After loading my domain mesh and facets into FEniCS, I attempt to read my facets with:
mesh = Mesh()
with XDMFFile(“domain_mesh.xdmf”) as infile:
infile.read(mesh)
facet_mesh = MeshFunction(“size_t”, mesh, mesh.topology().dim() - 1)
with XDMFFile(“facet_mesh.xdmf”) as infile:
infile.read(facet_mesh)
V = FunctionSpace(mesh, ‘P’, 1)
This is where I encounter the error. Below the error message can be seen:
*** Error: Unable to read MeshFunction.
*** Reason: Mismatched number of entities.
*** Where: This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: ba376b6aebd7a9bc089be46b50bdd9f5c548fb91
I’ve verified that the mesh and facet files are consistent, but the issue persists. Could this be related to the way physical groups are defined in GMSH, or is there a step I might have missed?
Below is the github link for you to examine the mesh files:
Any insights or suggestions on how to resolve this mismatch would be greatly appreciated. Thank you!
