Thanks for the changelog but I couldn’t use it to figure out my issue. It’s getting recreated on all my scripts, so I’ve linked a M(ish)WE, that I hope helps locate the error. It seems to stem from the solver now expecting a sequence of Forms, rather than just a Form. But I can’t find much on creating Form sequences.
from scipy.interpolate import RegularGridInterpolator as rgi
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import dolfinx as df
k = 100
box_dim = [0.1, 0.1, 0.01]
box_res = 20
cube = mesh.create_box(MPI.COMM_WORLD, [[0.,0.,0.], box_dim], [box_res]*3, mesh.CellType.hexahedron)
tdim = cube.topology.dim
fdim = tdim - 1
cube.topology.create_connectivity(fdim, tdim)
# PARAMETERS
t_0 = fem.Constant(cube, 10.0)
V = fem.functionspace(cube, ("Lagrange", 1))
def left(x):
return np.isclose(x[2], 0)
def right(x):
return np.isclose(x[2], box_dim[2])
boundary_facets = mesh.exterior_facet_indices(cube.topology)
left_facets = mesh.locate_entities_boundary(cube, 2, left)
right_facets = mesh.locate_entities_boundary(cube, 2, right)
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tags = mesh.meshtags(cube, 2, marked_facets[sorted_facets], marked_values[sorted_facets])
left_dbc_value = 0
left_dbc = np.array(left_dbc_value, dtype=PETSc.ScalarType)
left_dofs = fem.locate_dofs_topological(V, 2, facet_tags.find(1))
right_dbc_value = 0
right_dbc = np.array(right_dbc_value, dtype=PETSc.ScalarType)
right_dofs = fem.locate_dofs_topological(V, 2, facet_tags.find(2))
bc = []
#bc.append(fem.dirichletbc(left_dbc, left_dofs, V))
bc.append(fem.dirichletbc(right_dbc, right_dofs, V))
# Create initial condition
def initial_condition(x):
return np.zeros_like(x).flatten()
def heat_load(coord):
rangex = np.linspace(0, box_dim[0], 200)
rangey = np.linspace(0, box_dim[1], 200)
rangez = np.linspace(0, box_dim[2], 2)
heatload = np.ones(shape=(2, 200, 200)) * 20
heat_interpolator = rgi([rangez, rangey, rangex], heatload, "linear", False, 99)
out_array = []
for x, y, z in coord.T:
a = heat_interpolator([x, y, z])[0]
out_array.append(a)
return np.array(out_array)
heat_function = fem.Function(V, dtype=df.default_scalar_type)
heat_function.interpolate(heat_load)
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
(2, lambda x: np.isclose(x[0], box_dim[0])),
(3, lambda x: np.isclose(x[1], 0)),
(4, lambda x: np.isclose(x[1], box_dim[1])),
(5, lambda x: np.isclose(x[2], 0)),
(6, lambda x: np.isclose(x[2], box_dim[2])),]
fdim = cube.topology.dim - 1
facets = mesh.locate_entities(cube, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(cube, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure('ds', domain=cube, subdomain_data=facet_tags, metadata={"quadrature_degree":4})
x = ufl.SpatialCoordinate(cube)
g = -4 * x[0]
f = fem.Constant(cube, PETSc.ScalarType(-6))
neuman_bc = g * v * ufl.ds
t_surr = fem.Constant(cube, PETSc.ScalarType(10))
r = 100 * x[0]
tdiff = u - t_surr
robin_coeff = r*tdiff
robin_bc = robin_coeff * v * ds(5)
heat_input = heat_function * v * ufl.dx
F = (
u * v * ufl.dx + k * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
- heat_input
a, L = ufl.lhs(F), ufl.rhs(F)
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = assemble_matrix(bilinear_form, bcs=bc)
b = create_vector(linear_form)
solver = PETSc.KSP().create(cube.comm)
solver.setOperators(A)
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [bc])
set_bc(b, bc)
# Solve linear problem
solver.solve(b, uh.x.petsc_vec)
uh.x.scatter_forward()
Thanks in advanced!
