Non-convergence issue in the Newton solver while solving the hydrogen diffusion equation in a phase-field model for hydrogen-assisted cracking under tensile loading
I am implementing a phase-field model for hydrogen-assisted cracking under tensile load in FEniCS. The model includes displacement, phase-field, and hydrogen diffusion equations. However, I am encountering a Newton solver non-convergence issue while solving the hydrogen diffusion equation. The error message is:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
o address this, I have:
  • Used MUMPS as the linear solver.
  • Set strict absolute/relative tolerances.
  • Reduced the time step dynamically when the residual is too large.
  • Initialized the hydrogen concentration (C.interpolate(Constant(0.1))) before solving.
Despite these steps, the solver still fails after several iterations. What strategies or solver settings can I try to improve convergence?
Here is the code snippet.
# Hydrogen diffusion (nonlinear problem with stress-driven term)
E_C = (( (C - C_old) / Constant(deltaT) ) * q * dx
       + D_eff * dot(grad(C), grad(q)) * dx
       - (D_eff * VH * C) / (R * T) * dot(grad(sigma_H), grad(q)) * dx
       + 1e-3 * dot(grad(C), grad(q)) * dx)  # Preconditioning term
# Jacobian for nonlinear solver
J_C = derivative(E_C, C)
# Define nonlinear problem and solver
problem_C = NonlinearVariationalProblem(E_C, C, bc_C, J_C)
solver_C = NonlinearVariationalSolver(problem_C)
# Solver parameters
solver_C.parameters["newton_solver"]["linear_solver"] = "mumps"
solver_C.parameters["newton_solver"]["absolute_tolerance"] = 1e-10
solver_C.parameters["newton_solver"]["relative_tolerance"] = 1e-8
solver_C.parameters["newton_solver"]["maximum_iterations"] = 100  # Increase if needed
solver_C.parameters["newton_solver"]["relaxation_parameter"] = 0.5  # Reduce step size
solver_C.parameters["newton_solver"]["error_on_nonconvergence"] = False  # Prevent crash
# Time-stepping loop
for step in range(num_steps):
    t += deltaT
    tension.t = t
    solver_disp.solve()
    u_old.assign(u)
    Hold.assign(project(psi(u), V))
    phi_old.assign(phi)
    solver_phi.solve()
    # Check residual before solving for C
    residual_C = assemble(E_C)
    residual_norm_C = norm(residual_C, 'l2')
    if residual_norm_C > 1e6:
        print(f"Warning: Large residual ({residual_norm_C}) in hydrogen diffusion solver at step {step}, reducing Δt.")
        deltaT *= 0.5  # Dynamically reduce time step if divergence occurs
        if deltaT < 1e-6:
            print("Time step too small, stopping simulation.")
            break
    # Ensure C starts from a reasonable value
    C_old.assign(C)
    solver_C.solve()
Could you maybe provide a full MWE so that it can be run by other people?
But just looking at this, I’m wondering, shouldn’t you not update your C_old when your Newton solver doesn’t converge and you reduce the time step?
Thanks for your response!
When the Newton solver fails to converge and we reduce the time step (Δt), we should NOT update C_old. Otherwise, we are moving forward with a bad solution, making convergence even harder.
Please correct me if i am wrong.
Here is my code for your kind perusal.
Thanks in advance.
# Define and refine the mesh
mesh = RectangleMesh(Point(-0.5, -0.5), Point(0.5, 0.5), 200, 200, "crossed")
# Refine mesh around the initial horizontal crack (y=0, x <=0)
class CrackDomain(SubDomain):
        return abs(x[1]) < 0.01 and x[0] <= 0.0  # Horizontal crack at y=0
crack_domain = CrackDomain()
cell_markers = MeshFunction("bool", mesh, mesh.topology().dim(), False)
crack_domain.mark(cell_markers, True)
mesh = refine(mesh, cell_markers)
# Function spaces
V = FunctionSpace(mesh, 'CG', 1)  # Phase-field
W = VectorFunctionSpace(mesh, 'CG', 1)  # Displacement
Q = FunctionSpace(mesh, 'CG', 1)  # Hydrogen concentration
du, v = TrialFunction(W), TestFunction(W)
dphi, w = TrialFunction(V), TestFunction(V)
dC, q = TrialFunction(Q), TestFunction(Q)
# Functions
u, u_old = Function(W), Function(W)
phi, phi_old = Function(V), Function(V)
C, C_old = Function(Q), Function(Q)
Hold = Function(V)
# Material parameters
E = 210e9  # Young's modulus (Pa)
nu = 0.3   # Poisson's ratio
lmbda = E * nu / ((1 + nu) * (1 - 2*nu))  # Lamé parameter λ
mu = E / (2 * (1 + nu))  # Lamé parameter μ
Gc_0 = 2.7  # Initial fracture energy (N/m)
l = 0.001   # Phase-field length scale (m)
D0 = 1e-9   # Baseline diffusion coefficient (m²/s)
VH = 2e-6   # Partial molar volume (m³/mol)
R = 8.314   # Gas constant (J/(mol·K))
T = 300     # Temperature (K)
chi = 0.89  # Hydrogen embrittlement coefficient
Delta_g0 = 30000  # Gibbs free energy difference (J/mol)
# Boundary conditions
bcbot = DirichletBC(W, Constant((0.0, 0.0)), "near(x[1], -0.5) && on_boundary")
tension = Expression(("0.0", "u_r * t / total_time"), u_r=0.007, t=0.0, total_time=3.0, degree=1)
bctop = DirichletBC(W, tension, "near(x[1], 0.5) && on_boundary")
bc_u = [bcbot, bctop]
bc_C = DirichletBC(Q, Constant(0.1), "on_boundary")
class Crack(SubDomain):
        return abs(x[1]) < 1e-3 and x[0] <= 0.0
crack_surface = Crack()
bc_phi = DirichletBC(V, Constant(1.0), crack_surface)
# Initial crack
class InitialCrack(UserExpression):
    def eval(self, values, x):
        if abs(x[1]) < 1e-3 and x[0] <= 0.0:
            values[0] = 1.0
            values[0] = 0.0
    def value_shape(self):
        return ()
phi.interpolate(InitialCrack())
# Constitutive relations
    return sym(grad(u))
def sigma(u):
    return 2 * mu * epsilon(u) + lmbda * tr(epsilon(u)) * Identity(len(u))
def psi(u):
    return 0.5 * lmbda * (tr(epsilon(u)))**2 + mu * inner(epsilon(u), epsilon(u))
sigma_H = tr(sigma(u))
theta = C / (C + exp(-Delta_g0 / (R * T)))
Gc = Gc_0 * (1 - chi * theta)
D_eff = (1 - chi * theta) * D0
# Variational forms
# Displacement
E_du = ((1.0 - phi_old**2) * inner(sigma(du), grad(v)) - inner(Constant((0.0, 0.0)), v)) * dx
# Phase-field
def H(u_old, u_new, Hold):
    psi_new = psi(u_new)
    return conditional(gt(psi_new, Hold), psi_new, Hold)
F_phi = (Gc * l * inner(grad(phi), grad(w)) + (Gc / l) * phi * w - 2 * (1 - phi_old) * H(u_old, u, Hold) * w) * dx
J_phi = derivative(F_phi, phi)
F_C = (( (C - C_old)/Constant(0.01) ) * q * dx
       - (D_eff * VH * C) / (R * T) * dot(grad(sigma_H), grad(q)) * dx )
J_C = derivative(F_C, C)
# Solvers
problem_disp = LinearVariationalProblem(lhs(E_du), rhs(E_du), u, bc_u)
solver_disp = LinearVariationalSolver(problem_disp)
problem_phi = NonlinearVariationalProblem(F_phi, phi, bc_phi, J=J_phi)
solver_phi = NonlinearVariationalSolver(problem_phi)
prm_phi = solver_phi.parameters
prm_phi['newton_solver']['linear_solver'] = 'gmres'
prm_phi['newton_solver']['preconditioner'] = 'ilu'
prm_phi['newton_solver']['absolute_tolerance'] = 1e-10
prm_phi['newton_solver']['relative_tolerance'] = 1e-8
problem_C = NonlinearVariationalProblem(F_C, C, bc_C, J=J_C)
prm_C = solver_C.parameters
prm_C['newton_solver']['linear_solver'] = 'gmres'
prm_C['newton_solver']['preconditioner'] = 'ilu'
prm_C['newton_solver']['absolute_tolerance'] = 1e-10
prm_C['newton_solver']['relative_tolerance'] = 1e-8
# Time-stepping parameters
t = 0.0
deltaT = 0.001
num_steps = 3000
# Output
conc_file = XDMFFile("results.xdmf")
conc_file.parameters["flush_output"] = True
# Time loop
max_attempts = 5
successful_step = False
current_deltaT = deltaT
    t += current_deltaT
    tension.t = t
    attempts = 0
    while attempts < max_attempts:
        try:
            # Solve displacement using u_old (previous step's solution)
            solver_disp.solve()
            # Update history variable using u and u_old
            Hold.assign(project(H(u_old, u, Hold), V))
            # Solve phase-field using phi_old (previous) and u (current)
            solver_phi.solve()
            # Solve hydrogen diffusion using C_old (previous) and current variables
            solver_C.solve()
            # Update old variables for next time step
            u_old.assign(u)
            phi_old.assign(phi)
            C_old.assign(C)
            successful_step = True
            break  # Break out of the retry loop if all solves succeed
        except RuntimeError as e:
            print(f"Solver failed at time {t} with deltaT {current_deltaT}. Retrying with reduced time step.")
            current_deltaT *= 0.5  # Reduce time step by half
            attempts += 1
    if not successful_step:
        print(f"Failed to converge after {max_attempts} attempts. Terminating simulation.")
        break
    # Write output
    C.rename("HydrogenConcentration", "label")
    phi.rename("PhaseField", "label")
    conc_file.write(C, t)
    conc_file.write(phi, t)
conc_file.close()
print("Simulation completed.")
