Hi all, I want to compute the maximum von Mises stress over all the elements and compute the derivative in the future.
In order to use the automatic differentiation, I want to express the maximum von Mises stress with an integration via p-norm (not sure if we have any better choices?) as ( \int{ v^p(\mathbf{x}) \text{d}\mathbf{x}} )^{1/p} where v is the von-Mises stress. Here is the minimal code.
from dolfinx.cpp.mesh import CellType
mesh = dolfinx.RectangleMesh(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([4, 2, 0])], \
[4,2], CellType.quadrilateral)
V = dolfinx.VectorFunctionSpace(mesh, ('CG', 1))
def clamped_boundary(x):
return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = dolfinx.Function(V)
with u_D.vector.localForm() as loc:
loc.set(0)
bc = dolfinx.DirichletBC(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
T = dolfinx.Constant(mesh, (0, 1)) # traction
f = dolfinx.Constant(mesh, (0, 0)) # body force
boundaries = [(1, lambda x: np.isclose(x[0], 4))]
# loop through all the boundary conditions to identify the facets
facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, locator)
facet_indices.append(facets)
facet_indices = np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers = np.array(np.hstack(facet_markers), dtype=np.int32)
facet_tag = dolfinx.MeshTags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure('ds', domain=mesh, subdomain_data=facet_tag)
lambda_ = 1 # first Lame constant
mu = 1 # second Lame constant (shear modulus)
epsilon = lambda u: ufl.sym(ufl.grad(u))
sigma = lambda u: lambda_*ufl.nabla_div(u)*ufl.Identity(len(u)) + 2*mu*epsilon(u)
u = ufl.TrialFunction(V)
L = ufl.dot(f, v) * ufl.dx + ufl.dot(T, v) * ds(1)
problem = dolfinx.fem.LinearProblem(a, L, bcs=[bc], petsc_options={'ksp_type': 'preonly', 'pc_type': 'lu'})
uh = problem.solve()
s = lambda u: sigma(u) - 1/3*ufl.tr(sigma(u))*ufl.Identity(len(u)) # deviatoric stress
vonStress = lambda u: ufl.sqrt(3/2*ufl.inner(s(u), s(u))) # von Mises stress
# we want to construct this integration with p-norm:
von_stress = vonStress(u)
p = 12.0
integral = (von_stress**p * ufl.dx) ** (1/p)
However, an error message appears:
File "/shared/test.py", line 56, in <module>
TypeError: unsupported operand type(s) for ** or pow(): 'Form' and 'float'
Although we can compute the integrand first and then consider the power later, it might induce the overflow problem. So do we have any remedies? Thanks!
