Here I’m using FEniCS 2019.1.0. For the MWE pasted below, the performance I see upon executing the program using mpirun -np 4 python3 program.py is actually worse than when I run the program in serially.
What do I have to change to see a meaningful speedup?
import fenics as fe
comm = fe.MPI.comm_world
rank = fe.MPI.rank(comm)
T = 2.0 # final time
num_steps = 1000 # number of time steps
nx = ny = 30
mesh = fe.RectangleMesh(comm, fe.Point(-2, -2), fe.Point(2, 2), nx, ny)
V = fe.FunctionSpace(mesh, 'P', 1)
# Define boundary condition
def boundary(x, on_boundary):
return on_boundary
bc = fe.DirichletBC(V, fe.Constant(0), boundary)
# Define initial value
u_0 = fe.Expression('exp(-a*pow(x[0], 2) - a*pow(x[1], 2))',
degree=2, a=5)
u_n = fe.interpolate(u_0, V)
u = fe.TrialFunction(V)
v = fe.TestFunction(V)
f = fe.Constant(0)
bilin = u*v*fe.dx + dt*fe.dot(fe.grad(u), fe.grad(v))*fe.dx
lin = (u_n + dt*f)*v*fe.dx
A = fe.assemble(bilin)
b = fe.assemble(lin)
solver = fe.KrylovSolver("cg", "hypre_amg")
solver.set_operator(A)
outfile = fe.XDMFFile(comm, "solution.xdmf")
outfile.parameters["flush_output"] = True
outfile.parameters["functions_share_mesh"] = True
outfile.parameters["rewrite_function_mesh"] = False
# Time-stepping
u = fe.Function(V)
t = 0
for n in range(num_steps):
# Update current time
# Compute solution
bc.apply(A, b)
solver.solve(u.vector(), b)
# Update previous solution
u_n.assign(u)
# Save to file
outfile.write(u_n, t)
