Periodic conditions 3D gmsh
Good day! I have tube channel:
I import my mesh from gmsh.
msh = meshio.read("gmsh/3D_channel.msh")
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
tetra_mesh = create_mesh(msh, "tetra", prune_z=True)
meshio.write("facet_mesh.xdmf", triangle_mesh)
mesh = Mesh()
    infile.read(mesh)
Q = FunctionSpace(mesh, 'P', 1)
dim = mesh.topology().dim()
print('Dim:',dim)
mvc = MeshValueCollection("size_t", mesh, dim-1)
with XDMFFile("facet_mesh.xdmf") as infile:
facet_domains = cpp.mesh.MeshFunctionSizet(mesh, mvc)
How i can realize periodic conditions wia facet_domains ? Numbers domains for periodic contitions are 6 and 7. Thanks for you answer.
In dolfin, you need to be able to describe the mapping geometrically, as shown in: Bitbucket
In dolfinx, I have made a package that relies on MeshTags (an integer marking one boundary, as obtained from GMSH) and a geometrical mapping (mapping to the other surface): dolfinx_mpc/demo_periodic3d.py at master · jorgensd/dolfinx_mpc · GitHub.
